Dynex DX-LCD37-09
  • buzzstpoint
    • Aug 2010
    • 15
    Dynex DX-LCD37-09
    Having some trouble with my LCD. While watching tv it shut down. I kept turning it on but would shut off. It still turns on and the screen lights up but there is some arcing on wires inside and a burnt plug.
    Video of arcing
    Anything I should start to test?
  • 1beertap
    • Mar 2009
    • 219
    Re: Dynex DX-LCD37-09
    In short, the arcing is the reason for the shutdown. The carbon tracing (from the burnt places) will provide a path for high voltage to flow or leak easily. You need to clean or replace all burnt components.
    • buzzstpoint
      • Aug 2010
      • 15
      But then my 2nd question would be... Why would that plug burn up? I should be able to solder the wires direct to the board, Correct?
        "Why would that plug burn up?" poor connection with contact resistance so you get arcing and heat. You can solder the wire directly to the pads but the main key will be that you must remove all the carbonized section of that board otherwise it will conduct and cause arcing, the voltage on those connectors can be as high as 2500V.
        • buzzstpoint
          • Aug 2010
          • 15
          Originally posted by budm
          ...... main key will be that you must remove all the carbonized section of that board otherwise it will conduct and cause arcing, the voltage on those connectors can be as high as 2500V.
          Got ya.. Time to warm up my soldering iron..
          • buzzstpoint
            • Aug 2010
            • 15
            Results...
            I pulled the plug off. Rounded off the burnt spot and soldered the wires on the board.
            Plugged the set in and it still had the arcing. But I ended cleaning the wires off. Actually washing the wire with a paper towel. It felt like something was on the wires. Doing that drastically cut the arcing.
            Tv has been on for over an hour now..
              You should have no arcing at all, if you do, that means you still have insulation break down by the high voltage.
              • Shane711
                • 493
                I always insulate the wires because they ground to the frame of the TV. If you do it in the dark you can see it and sometimes the wires will glow, NOT good! So I insulate the wires and if 1 wire is doing it then you best insulate all the wires. If the wires are too close to each other or any metal they will spark and arch like a spark plug.
                • dicky96
                  Zotac GTX 260 burnt component - can anyone identify?
                  by dicky96
                  Hi guys
                  This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
                  This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
                  Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
                  I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
                  The good phase...
                  12-01-2021, 01:02 PM
                • mferna14
                  Apple MacBook Pro A2338 820-02773-A AON Rail burnt
                  by mferna14
                  Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
                  06-25-2025, 11:26 AM
                • nobbnobb1
                  Bose Acoustimass 10 IV Subwoofer No Sound. Help with burnt component identification?
                  by nobbnobb1
                  I picked up this used Bose Acoustimass 10 IV speaker system. Speakers seem to work fine, but the subwoofer does not make any noise. So I took apart the unit and found some obviously failed (burnt) components:
                  - 1x 3.14 A @ 250V main circuit fuse
                  - 1x bridge rectifier GBU601. there's actually two of these on the board, one is obviously burnt and the other does not seem to have any anomalies like shorts. However I figure may as well replace both.
                  - 2x diode. This is tricky because the only markings I see on it are: "617 402". No current rating or anything else....
                  11-16-2024, 09:56 PM
                • mosfetratus
                  macbook A2918, orange light off when shut off
                  by mosfetratus
                  When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
                  Works with battery and charges, but when i shut off i get this problem.
                  It had liquid spill. Board has no corrosion, keyboard is working, power button...
                  05-31-2024, 03:34 AM
                • CG2
                  LED uplighter dimmer burnt resistor
                  by CG2
                  I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple...
                  02-14-2024, 09:23 AM
