Olevia 242-S11 keeps blowing fuse
  • orosado79
    • Aug 2014
    • 8
    Ok guys I'm new here and did some research but don't have an answer yet. I have an Olevia 242-S11 that keeps blowing the fuse on the power supply. Capacitors all look in good shape so I'm not sure what is driving it.
    I found a cheap seller on ebay selling a functioning power supply, same exact model as mine: FSP271-4F02 but to my luck all the pin connectors (CNS1 through CNS4) appear to be different.
    What are my options? Should I go back to my original power supply and if so what should I check since the Caps are all good. Is there any easy way to swap the pin connectors as I'm sure once I connect the used power supply I bought I should be up and running.
    Thanks for your help!
    Re: Olevia 242-S11 keeps blowing fuse
    Start by uploading good clear pictures of the board both side. The two power supplies must not be the same revision.
    • orosado79
      • Aug 2014
      • 8
      Thanks for the reply. I have uploaded pictures of my original psup.
      You would think the revision is different but it is not. Same rev 1. 03 on both boards but yet the pin connectors ended up slightly different. They are wired the same way, but the shape of them, particularly the open fastener slots are different.
        The pictures are for the original or the new one? I cannot compare then without see both of them.
        • orosado79
          • Aug 2014
          • 8
          The pictures above are my original power supply that came in the TV. The picture attached below is of the "used" power supply I bought from ebay.
          • selldoor
            Slow Learner
            • 7870
            Quick test on the original - There seem to be a few bad solder joints
            I have marked some . Some may be on heatsinks so hard to re solder.
            NO power to board
            Where I have marked 1234 can you put our meter on ohms 200 and test
            1 to 2 then reverse the probes and test again
            Then do the same for 3 to 4
            Then the same for 2 to 3
            Also can you mark on the bottom of the board where the BIG cap is soldered.
            • selldoor
              Slow Learner
              • 7870
              The flash has obliterated part of the writing we need to see - with the output info and as bud is trying to compare them it would have been thoughtful if you turned the picture so they are at least in the same orientation.
              • orosado79
                • Aug 2014
                • 8
                I marked where the big cap is soldered on the back of the board. I'll start the testing in a few.
                As for the flash and orientation, my apologies I'll see if I can get a clear picture of both boards side by side. My basement is dark so without flash you don't get the detailed writing on the board. Photography was never my skill.
                  • 31298
                  there is a soot mark next to the bridge rectifier.
                  • orosado79
                    • Aug 2014
                    • 8
                    Thanks STJ, I'm a rookie at this sort of thing so could you point me to the Bridge Rectifier?
                    • selldoor
                      Slow Learner
                      • 7870
                      Its the 1234 you are testing!
                      • orosado79
                        • Aug 2014
                        • 8
                        NO power to board
                        Selldoor,
                        I ran the test and i'm getting several readings on the DMM when I'm testing but here are the average numbers, I hope the format makes sense:
                        2 3 4
                        - 1 -
                        + 1 145
                        - 2 45.6
                        + 2 -
                        - 3 -
                        + 3 143.4
                        • selldoor
                          Slow Learner
                          • 7870
                          Sorry makes no sense to me at all
                          report it as
                          1 to2 = ?? ohms
                          2 to1 = ?? ohms and so on
                          If it says 1 on the left of your meter for any put OL
                          • orosado79
                            • Aug 2014
                            • 8
                            Good news, I fixed the TV! Since I'm not very good at testing, I bit the bullet and desoldered all 4 pin connectors from the PSUP boards and swapped them. Plugged it in and woala! We have picture!
                            Thanks again to everyone for your help!
                            • selldoor
                              Slow Learner
                              • 7870
                              You mean the lamp connectors?
                              • Dannyx
                                UC3842 Power Adapter Blowing Fuse
                                by Dannyx
                                Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                12-05-2023, 12:06 PM
                              • Tips
                                Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                by Tips
                                Looking for some assistance please.
                                Trying to repair a PD27AOQ samsung power board.
                                Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                Testing it the fuse blows immediately power is turned on.
                                diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                any assistance, guidance would be appreciated.
                                04-11-2024, 11:24 AM
                              • RogerH58
                                Samsung 46" TV LE46B530 blowing fuse
                                by RogerH58
                                I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                06-10-2023, 10:27 AM
                              • corrize
                                A funny fuse story – Lumix LX100 II
                                by corrize
                                Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                10-19-2023, 09:58 AM
                              • Bootleg1
                                Samsung UN65KS9800FXZA T-con fuse blowing
                                by Bootleg1
                                Hi all, so i was watching tv acreen went black and no sound. Traced problem to blown tcon fuse. Replaced and it blows replaced again samething. So my tcon fuse keeps blowing. I bought a new board havent installed yet infear its just going to keep blowing the fuse. If i only connect the right side ribbon cable the fuse doesnt blow but as soon as i connect the left cable my tcon fuse instantly blows and no picture. The right side picture works clear as day and left side picture is grey (picture attatched) im hoping its a bad tcon board itself or a cable or anything and not the panel. Thank you for...
                                02-04-2020, 01:05 AM
