samsung 32 inch lcd
  • finntricky
    • Jan 2014
    • 449
    samsung 32 inch lcd
    any ideas on this problem guys,
    don't get any image on screen, just gets brighter untill almost white.
  • selldoor
    Slow Learner
    • 7870
    Re: samsung 32 inch lcd
    Make /model - is supposed to be in title!!
    Bad panel or tcon or cable
      I would say bad panel or T-CON, more likely to be panel due to bad TFT driver ICS. Try having one ribbon between the T-CON and the LCD panel connected one at a time to see what you will get.
      • finntricky
        • Jan 2014
        • 449
        finaly got to strip this tv down, it samsung Le32B450C4W.
        found the problem, it is the ribbon cable between the T-con and screen, looks like liquid damage,
        so i cleaned it all up and and found the ribbon cable was burnt, and contacts missing, also burnt hole in it.
        i found a T- con on ebay for £3, but cant find the cable for it,
        any ideas fellas
        • sordids999
          • May 2013
          • 2161
          http://www.ebay.co.uk/itm/LVDS-Cable...item3ce649fcaf
          do you mean this one ?
          • finntricky
            • Jan 2014
            • 449
            no not that one fella,
            i need the short one from T-con to screen,
            but thanks for looking.
            • philliesfan30m
              • Aug 2013
              • 542
              that is part of the panel. you will either need to buy a new panel or fix that connector which isn't very likely. some people have attempted it but not sure on the success rate. buying a new panel isn't an option in my opinion cause a new tv is cheaper than a new panel.
              • finntricky
                • Jan 2014
                • 449
                no fella, it's a 2 inch ribbon cable that connects the screen board to the T-con,
                it's not what your thinking of,
                i think you are talking about the screen tabs.
                • ChristianBr01
                  LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                  by ChristianBr01
                  I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                  The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                  What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                  04-23-2025, 01:48 AM
                • kca
                  by kca
                  Hello all ~
                  08-31-2025, 06:38 AM
                • thesame
                  Samsung UE40F6670SS messed tcon type in service mode.
                  by thesame
                  Hy guys i have this Samsung Tv model UE40F6670SS and i have messed with the service menu and selected the wrong tcon type .Is there a way to reset the service menu to defaults or how can i find the right tcon type since i didnt took a picture or remember the original setting?
                  Since i have selected the wrong tcon type the colors are a bit strange and sometimes the backlight it looks like its auto adjusting... ...
                  11-22-2023, 03:04 PM
                • THXFX
                  samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                  by THXFX
                  Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                  I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                  When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                  What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                  I check capacitors and diodes and didn't find any short IN MAINBOARD.
                  Measured all power supply...
                  03-20-2024, 03:21 AM
                • triplefour
                  Samsung UN55ES7003 has blown fuse on TCON and short to ground.
                  by triplefour
                  Samsung UN55ES7003
                  made house call.
                  red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
                  psu has self test feature.
                  disconnected from mainboard.
                  determined PSU ok BL ok.
                  suspect mainboard.
                  disconnecting tcon has no change on operation.
                  markings on mainboard:
                  BN97-06531P 0151
                  BN94-06123R
                  found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
                  for 54$
                  second house call:
                  with replacement mainboard, tv turns on, has sound,...
                  07-13-2022, 03:53 PM
