Re: Philips 40PFL3505D/F7 Blows fuse when plugged in
When you use the lamp and try to power up the TV, if the TV uses 200W then using 200W lamp will not be enough, it is like you have 200W lamps in series so each lamp will only get half the Voltage to run.
When I test the power supply board, I will test the board by itself first since the only circuit will draw the power will be the standby power supply, if the lamp lights up brightly and stays bright then I know I still have bad circuits some where, for example with shorted MOSFET for the PFC, that shorts will be there without turning on the PFC circuit.
I then force on the power supply while monitoring the Voltage on the main cap to see if I see the boosted Voltage or not, If do see the boosted Voltage and other Voltages that are turned on by the PS-ON the more likely the power supply is OK.
So using 200W is not going to be enough to run the TV since the TV consumes 200W of power.
