Philips 40PFL3505D/F7 Blows fuse when plugged in
    Re: Philips 40PFL3505D/F7 Blows fuse when plugged in
    When you use the lamp and try to power up the TV, if the TV uses 200W then using 200W lamp will not be enough, it is like you have 200W lamps in series so each lamp will only get half the Voltage to run.
    When I test the power supply board, I will test the board by itself first since the only circuit will draw the power will be the standby power supply, if the lamp lights up brightly and stays bright then I know I still have bad circuits some where, for example with shorted MOSFET for the PFC, that shorts will be there without turning on the PFC circuit.
    I then force on the power supply while monitoring the Voltage on the main cap to see if I see the boosted Voltage or not, If do see the boosted Voltage and other Voltages that are turned on by the PS-ON the more likely the power supply is OK.
    So using 200W is not going to be enough to run the TV since the TV consumes 200W of power.
    • Shane711
      • 493
      I have a Bad 1M200Z diode on my board. This is the only part I can find bad that may be causing the fuse to blow. So I found the equivalent to be 1N4741A or NTE5105A. It seems these are 1 amp. I want to install an equivalent that will not blow as easy.
      It is just after the rectifier diodes so it must be for power spikes. I have some P6KE220CA Bidirectional Diodes 600W 220v TVS. I wonder if I add one of these will it help or hurt?
      Basically I want to upgrade the circuit, make it better.
      • Shane711
        • 493
        I figured it would be safe if I powered on the TV without the diode so I replaced the fuse and it didn't blow a fuse. TV turned on right away and big crack right in the center.
        I am still going to fix the power board.
        And that diode is at location D1208 if anyone is curios.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          #44
          The problem with modification is that you can make the failure even more traumatic should the fault condition repeat. So unless it's a manufacturers update I'd be a little wary.
          If you are selling the set or it's a paid for repair I would not want it going pear shape and come back at me.
          Just my five-pence worth.
          The 1N4741A as you have found is a substitute device for it.
          • Shane711
            • 493
            I went and ordered the 1N4741A diode.
            • Shane711
              • 493
              Ah, problem here. The 1N4741A diode was not the right diode. I put it in and it blew. So I think I figured out why. The diode is suppose to be 190V or 200V and this diode is 11V. I don't think that is going to work.
              I see in the previous listing someone said Z4KE200A should be used. Is this correct? Looks good to me. It works between 190V to 210V
                1M200Z is 200V ZENER DIODE, so where does the 11V spec come from, 1N4741? How did the 1N4741 (11V) come about to be the replacement for the 1M200Z?
                http://www.mouser.com/ProductDetail/...Zq9JC0ow%3D%3D
                How is the original diode being used? As a snubber?
                • Shane711
                  • 493
                  Look at this eBay search link. All the listings say 11V.
                  http://www.ebay.com/sch/i.html?_from...4741A&_sacat=0
                  I bought mine off eBay. I also searched online and they all say 11V everywhere I look.
                    I corrected my typo.
                    • Shane711
                      • 493
                      I guess it was my mistake and dick_Barton said it was right. It is not right. Not even close.
                      The Z4KE200A sounds better than the 1M200Z, what do you think?
                        The Z4KE200 will be fine.
                        • Shane711
                          • 493
                          OK, I will order the Z4KE200A
                          I can't seem to find any 1M200Z. That Mouser page says you have to order 5,000 pieces. I can order 100 Z4KE200A for about $26.00 from Mouser.
                          • Shane711
                            • 493
                            So they are ordered. I just retested the board and everything else seems to be OK. Now I just have to wait for them to be delivered. Yesterday was my birthday, as you can tell by my user name.
                            • Shane711
                              • 493
                              OK, so I got the Z4KE200A diode today and installed it. Working great. Not blowing the fuse. This TV is a closed case
                              • BlackScreen_22
                                Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                by BlackScreen_22
                                Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                I had no problems connecting mosfets and capacitors,...
                                08-27-2024, 12:46 PM
                              • corrize
                                A funny fuse story – Lumix LX100 II
                                by corrize
                                Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                10-19-2023, 09:58 AM
                              • Michale32086
                                LG 60LN5400 Blows TCON Fuse
                                by Michale32086
                                I could have sworn I posted about this before, but I can't seem to find the post..
                                To whit..
                                I have a 60LN5400 that came in.. Backlights work fine.. No display..
                                Traced the problem to the TCON board.. Blown fuse..
                                Replaced the fuse.. Blows again.. Replaced the fuse again... This time it fries the marked part on the Main Video board...
                                Got a new Main Video Board.. Replaced the fuse on the TCON..
                                The fuse is fine and the backlights come on fine if I don't have the cellophane connectors from the TCON to the...
                                10-30-2019, 09:21 AM
                              • jesterace
                                Samsung UE46ES8000 Blown fuse but no other signs of short
                                by jesterace
                                Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                09-11-2024, 03:14 PM
                              • Shinju
                                Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                                by Shinju
                                Hey All!
                                Long time forum member here with a problematic laptop issue!
                                I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                                The laptop would not power on with the new battery installed without the power supply being plugged in.
                                When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                                TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                                10-20-2021, 04:58 PM
