Panasonic DMP-BDT220 Wont power
  • meshuggah27
    • Aug 2014
    • 9
    Hey guys. New here but looking to help as much as i can aswell.
    Recently was given a Panasonic DMP-BDT220 Bluray player. Does not power on whatsoever. When i plug the unit in, i can hear an eletronic whine coming from the power supply unit. I opened up the player, and looked at the fuse and all the caps, and they all seem to be intact (I dont have a meter or any knowledge for testing caps). By intact i mean no obvious buldging or exploding caps. Pretty lost with this, but id love to get it working. I can provide high-res images of the power board if needed. Thanks for anyone who can offer any wisdom or knowledge on this situation
    Re: Panasonic DMP-BDT220 Wont power
    You do not have a multimeter available? You can't hope to do any testing without one.
    • meshuggah27
      • Aug 2014
      • 9
      I was told I need an ESR meter. I have a multimetwe but have no idea how to properly test the caps with it.
        Well, you do not need to test the capacitors yet, first step is to see if the power supply is working. How about a picture of the power board, and are there any labels for various voltages?
        • meshuggah27
          • Aug 2014
          • 9
          Ill take some pictures when I get home. I already have the power board removed.
          • selldoor
            Slow Learner
            • 7870
            "Hi Res"?? we like pictures jpgs less than 3mb posted using manage attachments.
            Easier to view and will stay with the thread
            • meshuggah27
              • Aug 2014
              • 9
              • selldoor
                Slow Learner
                • 7870
                You do not NEED an ESR meter.
                • meshuggah27
                  • Aug 2014
                  • 9
                  Any instructions on how to test caps with a multimeter? I found a guide elsewhere on the forum but it was vert vague. Also not sure what to set the multimeter to in order to test.
                    • 31289
                    just take the damned foto's
                      Originally posted by meshuggah27
                      Any instructions on how to test caps with a multimeter/
                      You can't test ESR with a multimeter. Only capacitance, if your meter supports it, and that is a misleading measurement in many cases.
                      • meshuggah27
                        • Aug 2014
                        • 9
                        So I should be testing that then right....
                          As I said, testing capacitance is usually misleading. It's not necessary.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            Why you are so sure, that you have problems with capacitors? This in not Samsung
                            This player is fairly new to have capacitor issues, but course it could have issues.
                            I have found a SM, haven't checked it out, if it's the right one though:
                            I believe, that I have the same player, but mine it's working great.
                            • meshuggah27
                              • Aug 2014
                              • 9
                              Heres the pictures sorry for the delay
                              • martino
                                Not so "senior"
                                • Aug 2013
                                • 997
                                • canada
                                Might be the light but pin7 of T1001 seems like a bad solder
                                Proud owner of dozens of broken TV's and many,many,many boards.
                                Our website and passion:http://hollenhundshepherds.com/
                                • meshuggah27
                                  • Aug 2014
                                  • 9
                                  gave it a look, doesnt look like a bad solder. must have been the flash. any ideas? >_<
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5095
                                    • New Zealand
                                    Q1171 looks like it has bad soldering too, and some components nearby. Also C1081 next to the optoisolator, and D1110
                                    It seems that P1102 is the main output connector. You can measure the voltages there and see if they come up right. The service manual should show which pins are which rails and what the voltages are supposed to be.
                                    -David VanHorn
                                    • PantherDave
                                      by PantherDave
                                      Hi all!
                                      05-29-2024, 02:01 PM
                                    • GLISIT
                                      by GLISIT
                                      01-16-2025, 02:29 PM
                                      by sam_sam_sam
                                      03-31-2024, 02:12 PM
                                    • oldschoolgamer
                                      Panasonic TX-50EX700B Won't Power On
                                      by oldschoolgamer
                                      Hi. I have a Panasonic TX-50EX700B which hadn't been used very often for some time. Recently it started getting used a little more often, until one day it just refused to power on with the red LED blinking 13 times. Upon researching, it turned out it apparently had something to do with the 5v power line, so I assumed it was probably the power supply.
                                      I purchased a power supply for the TV from a seller that claims that it works fine and was just taken from a TV with a broken screen. After fitting the new power supply and trying the TV, I was greeted with the power LED being red for...
                                      10-26-2022, 04:15 PM
