I checked the back of the power board (and the front, and both sides of the main board) under magnification and nothing is obviously broken. Both boards look pristine. I could randomly check components but I dont't know what the correct values are. The only thing I have found that I know if incorrect is the standby voltage should be 5v and it is not.
Panasonic TH-50PX80 killed by lightning strike, help me save her!
Forget voltages for now, check those components, tv unplugged from power. Just do a quick check and see if any of the transistors which are labeled starting with a Q, have any of the three pins shorted to each other as meter probes on pin 1 and 2, 1 and 3, 2 and 3, and just check the diodes in diode mode.Comment
What may have happened, did to me once. A strike nearby borked the firmware, fixed with a firmware update with a usb drive. Being old you may not be able to find the firmware tho.Comment
Update: I found a better service manual for the TV, which pointed out where to test for th STB voltage, and it IS present on the power board.
I put the old main board back in and it did what it always did.- With the original main board in, when you turn the TV on, it turns on, the power light stays steady, there is no picture. It will just sit like this.
- With the new main board in, when you turn the TV on, after a few seconds, it goes into an "SOS" mode, turns itself off, and gives a single blink. According to this manual, one blink means "Communication Error with Microcomputer". The manual gives no other info besides this on that error, other than the source of that error is on the main board itself, not the power board
Did I get a bad main board off eBay? It at least detects what is going on enough to go into it;s safety mode but the blink code seems to indicate the new board is faulty.Comment
I might have found the issue... I might have bought the wrong main board off eBay
My original has a model number of TNPH07163A. The one they sent me was TNPH0716ABS. They look identical and seem to have the same chips on them, but perhaps they have different firmware or software?
So my assumption now is that my power board is fine, it was my main board that got damaged, the main board I was sent is fine, but it's the wrong one for my TV, because of that it triggers the SOS condition and gives the single red light blink indicating an issue with the main board.
I ordered the correct one from another seller, and it's a new old stock unit not even used, so back to the "waiting for shipping" game.Last edited by SluggerB; 06-06-2025, 03:31 PM.Comment
So I have just learned about the beauty of Panasonic "Suffix's"
My dead board is an AH suffix. The replacement board I ordered is an AB suffix. These are indicated by a resistor on the board on a bank of spots a resistor could go
If I moved the resistor on the new board from AB to AH, would it work?Comment
Well after all the waiting, the correct main board I ordered off eBay finally showed up. I opened the box all excited ... and the box didn't even have a main board in it, it was a power board to a completely different TV. So that's going back.
I may have tracked down a store that has one but they are being hilariously unresponsive. I'm also fed up with this mess and am going to go looking at new TV's this weekend. I would like to fix this one but I'm sick of waiting weeks for parts to ship only to show up and be the wrong part.Comment
I think you're on the right path now, R.I.P. to those old heavy 720p dinosaurs.Last edited by nomoresonys; 06-14-2025, 09:31 AM.Comment
Hi, the kind faulty part is a standby memory, that is somewhere on the main board, you posted a very undecent picture, can you post a good one following directions in my sticky post ? it is maybe the 14pin ic, but have you got a simple eprom writer? Need to find the dump too... PS: the memory could be erased by electro magnetic waves of the lightning, thus wireless, this is kindly what happened...Comment
I've heard a few people saying the EM from the lightning could be the culprit, which is interesting. I do not have an eeprom writer, and even if I did the firmware is not online anymore. I've been looking
Either way it's a moot point, the new board showed up, it's the correct suffix version, I put it in the TV, and it's working again just fine. And it was only $46. I returned the other boards. Case closed.Comment
by Bardou KariHi,
I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
– Charger is OK and 19V is present at the motherboard.
– No charging LED, no fan, no reaction.
– I don’t see any 3.3V or 5V near the coils.
– Battery is unplugged.
– I’m new to board repair but can use a multimeter.
I added a clear photo of the board.
Any idea where to start or what to check next?
Thanks a lot for your help!...07-01-2025, 10:45 AM -
by karthurWe had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
Here is what I have checked.
On the power supply board, 14pin connector:
1 :12.7 Vdc
3 :12.7
5 :12.7
7 :12.7
9 :0
11 :5.
13 :5.... -
by MrCreosoteTHE LIGHTNING:
This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
Very close and probably a very strong EMP.
THE TV:
No standby LED. Some voltage from PSB (not totally dead).
But found a kit of ALL 4 circuit boards for $55.
At first thought, this will fix my TV.
But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given... -
by pbighi everyone,
my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
- the 450V/150uF capacitor voltage when plugged is normal at 394V
- from connector CN6150 (15 poles)
STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...06-28-2023, 02:43 AM -
by pflHello Everyone.
This powerful amplified subwoofer doesn't make any sound after lightning striked near the house were it was plugged in.
It consists in :- a power board were the full H bridge class D amplifier and main power rails are located
- a preamp board (ref. F.01U.299.771) receiving 2 symetrical inputs(IN1, IN2), a digital chain (A-D converter -> Digital Signal Processor -> D-A converter) and a micro controler in charge (at least) of the human interface (lcd display and 1 rotating button)
human interface is working fine
Input levels are...-
01-23-2024, 10:21 AM - Loading...
