Panasonic TH-50PX80 killed by lightning strike, help me save her!
  • SluggerB
    • Aug 2020
    • 749
    • US
    You need to do testing, remove powerboard, check the underside for anything obvious. here's a few things to check Q151, Q171, D601, D602, D603, D607, D615, youtube is your friend for testing procedures if needed.
    I checked the back of the power board (and the front, and both sides of the main board) under magnification and nothing is obviously broken. Both boards look pristine. I could randomly check components but I dont't know what the correct values are. The only thing I have found that I know if incorrect is the standby voltage should be 5v and it is not.
    • nomoresonys
      • 12370
      • U.S.
      Forget voltages for now, check those components, tv unplugged from power. Just do a quick check and see if any of the transistors which are labeled starting with a Q, have any of the three pins shorted to each other as meter probes on pin 1 and 2, 1 and 3, 2 and 3, and just check the diodes in diode mode.
      • nomoresonys
        • 12370
        • U.S.
        A bit of testing there: https://www.youtube.com/watch?v=i4jTHhXuKLA
        • nomoresonys
          • 12370
          • U.S.
          And there: https://www.youtube.com/watch?v=qhPZD9avoac
          • nomoresonys
            • 12370
            • U.S.
            What may have happened, did to me once. A strike nearby borked the firmware, fixed with a firmware update with a usb drive. Being old you may not be able to find the firmware tho.
            • SluggerB
              • Aug 2020
              • 749
              • US
              #26
              Update: I found a better service manual for the TV, which pointed out where to test for th STB voltage, and it IS present on the power board.
              I put the old main board back in and it did what it always did.
              • With the original main board in, when you turn the TV on, it turns on, the power light stays steady, there is no picture. It will just sit like this.
              • With the new main board in, when you turn the TV on, after a few seconds, it goes into an "SOS" mode, turns itself off, and gives a single blink. According to this manual, one blink means "Communication Error with Microcomputer​". The manual gives no other info besides this on that error, other than the source of that error is on the main board itself, not the power board
              Did I get a bad main board off eBay? It at least detects what is going on enough to go into it;s safety mode but the blink code seems to indicate the new board is faulty.
              • SluggerB
                • Aug 2020
                • 749
                • US
                #27
                I might have found the issue... I might have bought the wrong main board off eBay
                My original has a model number of TNPH07163A. The one they sent me was TNPH0716ABS. They look identical and seem to have the same chips on them, but perhaps they have different firmware or software?
                So my assumption now is that my power board is fine, it was my main board that got damaged, the main board I was sent is fine, but it's the wrong one for my TV, because of that it triggers the SOS condition and gives the single red light blink indicating an issue with the main board.
                I ordered the correct one from another seller, and it's a new old stock unit not even used, so back to the "waiting for shipping" game.
                • lotas
                  • Jan 2016
                  • 5383
                  • Russia
                  #28
                  Check...
                  • SluggerB
                    • Aug 2020
                    • 749
                    • US
                    #29
                    So I have just learned about the beauty of Panasonic "Suffix's"
                    My dead board is an AH suffix. The replacement board I ordered is an AB suffix. These are indicated by a resistor on the board on a bank of spots a resistor could go
                    If I moved the resistor on the new board from AB to AH, would it work?
                    • SluggerB
                      • Aug 2020
                      • 749
                      • US
                      #30
                      Well after all the waiting, the correct main board I ordered off eBay finally showed up. I opened the box all excited ... and the box didn't even have a main board in it, it was a power board to a completely different TV. So that's going back.
                      I may have tracked down a store that has one but they are being hilariously unresponsive. I'm also fed up with this mess and am going to go looking at new TV's this weekend. I would like to fix this one but I'm sick of waiting weeks for parts to ship only to show up and be the wrong part.
                      • nomoresonys
                        • 12370
                        • U.S.
                        #31
                        I think you're on the right path now, R.I.P. to those old heavy 720p dinosaurs.
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8724
                          Many years ago I had repaired the similar issue on a lightning struck Panasonic. It would turn on for a split second and then turn off. It was the HDMI IC that was shorted and got hot fast.
                          • SluggerB
                            • Aug 2020
                            • 749
                            • US
                            #33
                            New main board shows up today. I am 99% sure it is the right version and right suffix. Assuming the seller's listing was correct, hopefully that gets her going again
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4789
                              • Italy - Milan
                              #34
                              Hi, the kind faulty part is a standby memory, that is somewhere on the main board, you posted a very undecent picture, can you post a good one following directions in my sticky post ? it is maybe the 14pin ic, but have you got a simple eprom writer? Need to find the dump too... PS: the memory could be erased by electro magnetic waves of the lightning, thus wireless, this is kindly what happened...
                              • SluggerB
                                • Aug 2020
                                • 749
                                • US
                                #35
                                I've heard a few people saying the EM from the lightning could be the culprit, which is interesting. I do not have an eeprom writer, and even if I did the firmware is not online anymore. I've been looking
                                Either way it's a moot point, the new board showed up, it's the correct suffix version, I put it in the TV, and it's working again just fine. And it was only $46. I returned the other boards. Case closed.
                                • SluggerB
                                  Panasonic TH-50PX80 re-killed by lightning strike, Ugh. Can I save my non HDMI inputs?
                                  by SluggerB
                                  So this happened before https://www.badcaps.net/forum/troubl...save-her/page2
                                  I had replaced the board and that rescued the TV. Until yesterday when a new lighting storm rolled through. Ugh.
                                  This time however I have a lot more experience, and AI to help me, so I pulled the TV open, took out the board, and was able to find some things out.
                                  After the lightning strike, if you turn the TV, it never comes all the way on,...
                                  07-10-2026, 08:15 AM
                                • Bardou Kari
                                  HP EliteBook 840 G6 – no power after lightning strike
                                  by Bardou Kari
                                  I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                                  – Charger is OK and 19V is present at the motherboard.
                                  – No charging LED, no fan, no reaction.
                                  – I don’t see any 3.3V or 5V near the coils.
                                  – Battery is unplugged.
                                  – I’m new to board repair but can use a multimeter.
                                  I added a clear photo of the board.
                                  Any idea where to start or what to check next?
                                  Thanks a lot for your help!...
                                  07-01-2025, 10:45 AM
                                • karthur
                                  Samsung UN60EH6000 wont come on after lightning strike.
                                  by karthur
                                  We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                                  I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                                  When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                                  Here is what I have checked.
                                  On the power supply board, 14pin connector:
                                  1 :12.7 Vdc
                                  3 :12.7
                                  5 :12.7
                                  7 :12.7
                                  9 :0
                                  11 :5.
                                  13 :5....
                                  11-01-2023, 06:18 PM
                                • pbig
                                  advices for repairing Sony Bravia 32EX600 after lightning strike
                                  by pbig
                                  hi everyone,
                                  my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                                  On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                                  - the 450V/150uF capacitor voltage when plugged is normal at 394V
                                  - from connector CN6150 (15 poles)
                                  STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                                  06-28-2023, 02:43 AM
                                • MrCreosote
                                  Lightning Strike: 55" TV dead: is display panel OK?
                                  by MrCreosote
                                  THE LIGHTNING:
                                  This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
                                  Very close and probably a very strong EMP.
                                  THE TV:
                                  No standby LED. Some voltage from PSB (not totally dead).
                                  But found a kit of ALL 4 circuit boards for $55.
                                  At first thought, this will fix my TV.
                                  But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
                                  08-16-2021, 10:27 PM
