Getting white streaks and lines - sound and channels work fine with remote, but no picture. Most probable thing the T-con?
Vizio SV370XVT - white screen with streaks
Tags: None
Re: Vizio SV370XVT - white screen with streaks
yes- check the fuse on the tcon then when connected voltage with respect to ground. Also if you havent already clean the flat cables and reseat.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740 -
I'm going to put a bet on this being a bad panel. Non repairable unfortunately.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Try having one ribbon cables between the LCD panel and the T-CON board connected one at a time to see what you get.Never stop learning
First photo is with right ribbon connector removed (looking at back panel).
Second photo is with entire T-con board removed - I noted the formation on the right side that looked like spilled liquid - would this indicate a bad display or would new boards correct?Attached Filesif you find these attachements useful please consider making a small donation to the site
by harpTo ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment... -
by spice_discI'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...1 Photo -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by EazyBoneAnother TV topic!!
I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?... -
by hcinneHello,
I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the... - Loading...
