Vizio V0420E
  • ned1
    • Feb 2014
    • 139
    • usa
    Vizio V0420E
    Picked up 42 inch Vizio LCD from friend. At first when plugged in to power it will show orange vizio logo then when power on button pushed it change to white but black screen. Ordered power inverter combo board from Shop Jimmy. Got it pretty quick and this time the screen comes on, I have welcome Vizio logo on the screen then brightens will dim and it will go black again. It does it every time tv is turned on. I read on this website that bad bulb will cause it, strip it down all the way to backlight, 18 bulbs. Powered on all bulbs come on and appears 3 bulbs will stay brighter others will dim and again all die. Should I consider those bright bulb are problem or there is other test I can perform.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Vizio V0420E
    I am guessing here but I think the dim bulbs are the faulty ones so I'll wait to see what the real experts may say.
    • ned1
      • Feb 2014
      • 139
      • usa
      Re: Vizio V0420E
      Thanks for reply. When I powered it on first time it stayed on longer then I tried to change input channel, (no remote) and I increased backlight level almost to 99 by pressing buttons on the side of tv.Maybe it has to do something with this, because after that it will shut off after 5 seconds when power on now.
      • ned1
        • Feb 2014
        • 139
        • usa
        Re: Vizio V0420E
        Is there a way to check bulbs individual, bypass it with resistor on any other way. They are all short together on each side and resistance reading is 56.8 ohms from any left side end of bulb to any right side end of bulb.
          Re: Vizio V0420E
          Can we see good clear pictures of the board and the lamp assembly, also the LCD panel model number so we can look up the spec to see how all the lamps are connected and what type of lamps they are?
          • ned1
            • Feb 2014
            • 139
            • usa
            Re: Vizio V0420E
            I am having problems with pictures, maybe website problem. I will try again later. The board is combo power and inverter, bulbs are 3mm X 950mm. The panel is LC420WUG. I am powering backlight only with LCD panel removed, so maybe it should shut off after few seconds since T-con is not present. But all bulbs comes on.
            • ned1
              • Feb 2014
              • 139
              • usa
              Re: Vizio V0420E
              Pictures are attached
                Re: Vizio V0420E
                It should stay on without T-con board. So all the lamps light up evenly before shutting down since you indicate that 3 are lit up brightly? These lamps looks to be EEFL type and they are connected in parallel without having ballast caps per lamp like CCLF type.
                http://www.beyondinfinite.com/lg-philips/lc420wug-sca1/
                Those lamps are socketed, did you carefully try to reseat them?
                • ned1
                  • Feb 2014
                  • 139
                  • usa
                  Re: Vizio V0420E
                  I reseated all of them. After reseating it appears that all bright up evenly and shot down faster.
                  • ned1
                    • Feb 2014
                    • 139
                    • usa
                    Re: Vizio V0420E
                    Can I bypass lamp to figure which one is problem.
                    • ned1
                      • Feb 2014
                      • 139
                      • usa
                      Re: Vizio V0420E
                      If they are in parallel connection why would 1 lamp shut off entire backlight assembly. Can I insert one by one lamp to see when it starts to shut down?
                      • ned1
                        • Feb 2014
                        • 139
                        • usa
                        Re: Vizio V0420E
                        Got it somehow to stay longer and took a picture. It appears that bulb #6 from the top is dim.
                          • 31014
                          Re: Vizio V0420E
                          interesting,
                          they are different colours.
                          i realise this is probably down to the camera sensor being more sensitive than the eye, but it shows they are either unevenly made, or pretty worn!
                          • ned1
                            • Feb 2014
                            • 139
                            • usa
                            Re: Vizio V0420E
                            Where can I buy those bulbs?
                            • ned1
                              • Feb 2014
                              • 139
                              • usa
                              Re: Vizio V0420E
                              STJ it was just camera, second picture may be better.
                              • ned1
                                • Feb 2014
                                • 139
                                • usa
                                Re: Vizio V0420E
                                Maybe this picture is better
                                • ned1
                                  • Feb 2014
                                  • 139
                                  • usa
                                  Re: Vizio V0420E
                                  Can I replace eefl lamp with ccfl lamp?
                                    Re: Vizio V0420E
                                    No.
                                    Can you swap the #6 lamp with other lamp to see if the problem follows?
                                    • ned1
                                      • Feb 2014
                                      • 139
                                      • usa
                                      Re: Vizio V0420E
                                      I swapped the bulb 6 and 1 and it was shutting down very fast. Then I completely removed bad bulb and the backlight stayed on, never shut off. So I definitely know which bulb is bad, now the question is where can I buy it in USA.
                                        Re: Vizio V0420E
                                        A lot of people here use CCFL WAREHOUSE.
                                        http://www.ccflwarehouse.com/?gclid=...FQaCMgod4msARg
                                        • Bob1394
                                          Vizio M65-C1 | Logo appears for 10 seconds then off
                                          by Bob1394
                                          I have used the search, and am stumped.
                                          My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
                                          I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
                                          https://www.badcaps.net/forum/showthread.php?t=81088
                                          https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
                                          Observations
                                          1) [Interaction] Power turned on via TV button (or remote)...
                                          02-08-2023, 01:03 PM
                                        • Super360
                                          Vizio E701i-A3 Vizio logo flashing then turns off
                                          by Super360
                                          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                          07-25-2024, 07:06 PM
                                        • x_orange90_x
                                          Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                          by x_orange90_x
                                          I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                          12-28-2023, 06:26 AM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
