Emerson CLC 401EM2F 40" LCD backlight turns off after 2 seconds.
  • paulstef
    • Dec 2013
    • 724
    Hi ,
    the TV turns on but after 2 seconds or so the backlight turns off.
    All voltages from the PS seem to be ok.
    The High voltages transformers on the inverter PCB are ok.
    My question is what exactly do I have to expect on the signal lines PWM SEL, BL ADJ and BL SW?
    BL SW is 2.95V when turning on the TV, and it stays there, BL ADJ goes to about 1.3V and then increases to 2.2V 2 seconds AFTER the backlight turns off.
    PWM SEL is at DC 1.56V while the backlight is on and then after the backlight is off has a 150Hz 3.3V signal on it.
    I assume BL SW would be "backlight switch", BL ADJ would be the intensity of the backlight . What is PWM SEL for?
    Re: Emerson CLC 401EM2F 40" LCD backlight turns off after 2 seconds.
    This is I assume: PWM_SEL is for, if used, PWM DIMMING CONTROL, the signal will be around 200Hz with variable pulse width from 10% (min brightness) to 90% for max brightness. BL_ADJ is an analog (variable DC) from <1V for MIN, >4V for max.
    If you can look up the LCD panel model number then you can get the spec which will tell you the electrical spec of the inverter board and the T-CON board.
    Sounds like the inverter is getting the correct signals but there is problem due to circuits or bad lamps, bad lamp wiring.
    • paulstef
      • Dec 2013
      • 724
      Ok, thanks. I will check the panel tomorrow.
      What voltages can I expect on the secondary of the inverter transformers? I could borrow a high voltage probe next week.
        1500~2000V!
        I use this to test each output to see if one of them is bad:
        https://www.badcaps.net/forum/showth...x+dx-40l261a12
        • paulstef
          • Dec 2013
          • 724
          Bdm , I think you brought me on the right track .
          Apart from lcdparts.net, is there any other reliable store to buy HV transformers? They don't seem to have it. Otherwise I would need a new inverter board...
          • zklgfs
            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
            by zklgfs
            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
            08-11-2025, 02:14 PM
          • alpersen
            Philips 40 PUK6809/12 Backlight turns off after 10-20 seconds
            by alpersen
            Hello
            Mother called and said TV turns off after switching on. So after turning on Philips logo shows and probably 10-20 seconds image disappears, sat receiver is connected and sound is heard from source. So I turned on my phones light and I can see the image it seems backlight was off after some time. I dis assembled the cover hoping to see a distinc cap blown or leakage. Here are photos I took (I was after 22:00 pm and maybe some of them are dark). Should I order and change caps on the power circuit or what would you recommend? Thanks...
            07-25-2024, 12:50 AM
          • www
            LG L192WS-BN backlight turns off after 1 second
            by www
            I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
            I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
            03-24-2024, 05:26 PM
          • twonk9098
            Lenovo Legion 5 high fan spin turns off after 34 seconds
            by twonk9098
            I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
            I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
            I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
            I have tried a few new bios but exactly...
            07-14-2024, 11:19 AM
          • frannyjunk
            Hisense 40H4F no backlight but turns off after splash screen
            by frannyjunk
            So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
            TIA.
            09-24-2025, 10:59 AM
