then remove the SoC from circuit, will be first step to know where was the short.
SONY KDL-46R473A ALMOST DEAD NO STB
Oh shit my bad, I didn't look close at the chip, it's not bga so no reflow like Diah said. If the caps near a chip read short on the board but ok off the board then a lot of times it's that chip that's bad.Comment
[QUOTE=nomoresonys;n3625460]Oh shit my bad, I didn't look close at the chip, it's not bga so no reflow like Diah said. If the caps near a chip read short on the board but ok off the board then a lot of times it's that chip that's bad.[/
well I'll do as Diah has suggested but I have to buy a replacement Chip it's not worth fixing this Tv want to try something and learnComment
I hear you, probably not worth investing much in. I wonder if one of those cheap universal mainboards would work for this tv.Comment
maybe i have no idea never com over such board .but i will just go on maybe i find that short just for learning even take away that chip as training . or maybe if Nick see this and give some advises would be funComment
Doesn’t mean anything with these Mediatek IC’s. If you search older threads here, you find tons of mainboards with this Mediatek IC that failed just like that.Comment
You have my vote CapLeaker, I would like to see that chip switched out. If you try it Bohaboha, maybe practice on some scrap boards and check some youtube videos for technique.Comment
i have read so many thread here but none have this model kdl-46R473A and even in Niks video i did not find my model but of course the basic is the same. i found some caps shorted on the boards down side .but just now i have to finish that samsung 70""an other thread here" then i ll take this one
​Comment
it is not Shure that Mediatek IC is the fault because i found some shorted caps on the other side of the board so it is not clear yetComment
here some they are 1each side of that big chip and under it 4 big ones and 2 otr 3 small ones all are shortAttached Filesif you find these attachements useful please consider making a small donation to the site
by thstuffA) TV initially dead
B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
C) Was able to perform a Reset from Settings menu and completed out of box configuration.
D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical... -
by jamespHello, can someone please help me. i have a dead laptop mainboard, aspire a315-55 with board model DA0ZAWMB8G0 rev. G
upon checking of voltages at s5, 19v is present Vin, 5v and 3v is present at PL6001 and PL6000 respectively, but no signal from MAINON And s5_ON to be able to produce +3v_s5 to give power to vcc of BIOS CHIP U2. MAINON and S5_ON is coming from ec chip U37 it8987e/cx.
do i need to reflash the EC? any advice? thanks...09-30-2024, 08:24 AM -
by 3mz3tNM-C931 mainboard, does not start, no light, no nothing. Draws 20.56 V / 0.14 A from a wall charger.
Under thermal camera, the only thing that show is the ThinkEngine chip (BD4179MWV / UTE1B) heating up (also quite hot to the touch), there's 19.75 V on the VREGIN20 (pin 45).
Is the BD4179 dead? WDYT?
Thank you.... -
by TalynHi,
My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
Any advice? Thanks! -
by mmartellThis sat around for quite some time after the backlights died with the six blink error code. I bought replacement strips and eventually swapped them in.
Backlights appear to be working fine now. However the tv only powers on with the "Sony" logo for about two seconds after which it goes away and the panel with backlights stay powered for about twenty more seconds then it shuts off. Tv can only be powered again after power cycling at the outlet.
It will not program via usb, the stick flashes but there is never any indication that it has entered programming... - Loading...
