SONY KDL-46R473A ALMOST DEAD NO STB
  • bohaboha
    • Nov 2012
    • 1045
    • sweden
    Originally posted by lotas
    You don't know what a choke is? It says "2R2" (a coil wound on a ferrite core)!
    thank you it is a matter of languages English is not my native , anyhow what do you think about what those shorts and voltages
    • bohaboha
      • Nov 2012
      • 1045
      • sweden
      look at this
      • bohaboha
        • Nov 2012
        • 1045
        • sweden
        Hi again i took away one of those 3 capacitor but the short still there. even the one near SoC and nothing happened i will go on and take away the choke and se what it gives but it is possible as Diah said the culprit is the SoC MT5367
        • CapLeaker
          Leaking Member
          • 8352
          The problem IS the Mediatek IC. Kinda surprised it held up that long. They were a lot of problems with these Mediatek IC’s back then.
          • bohaboha
            • Nov 2012
            • 1045
            • sweden
            ok but this one seems to work he is getting a normal temp but of course that old must get tired .but maybe a reflow will take him back to live
            • Diah
              • Feb 2013
              • 6614
              you said you don't have 12V on Panel fuse... so check this area where you could find this 12V
              • bohaboha
                • Nov 2012
                • 1045
                • sweden
                #27
                thank you Diah please look at post 22
                • Diah
                  • Feb 2013
                  • 6614
                  then why you wrote no 12v on panel t-con fuse? at time u have it on lvds socket !
                    • 12331
                    • U.S.
                    #29
                    Just carefully reflow the mediatek, won't hurt it as long as you don't overdo the heat but too little heat will have no effect. Then try it, might get lucky. Check youtube, plenty of good diy reflow tips there, remember that not all of the youtubers do it right so probably have to wade thru some.
                    • bohaboha
                      • Nov 2012
                      • 1045
                      • sweden
                      #30
                      because there is no voltage at the fuse and at all the panel Bond both parts i do not find any voltage att all and i do not find any voltage at that socket on your picture just on the capacitor under it there is 12.25V
                      • bohaboha
                        • Nov 2012
                        • 1045
                        • sweden
                        #31
                        i have this IRDA SMD And BGA Rework Station T-862++ i am thinking to use to just reflow the chip maybe 220 degres C max use on this one is 350" C i think
                        • lotas
                          • Jan 2016
                          • 4899
                          • Russia
                          #32
                          From heating mediatek, you will not have a short circuit on the motherboard.
                          • bohaboha
                            • Nov 2012
                            • 1045
                            • sweden
                            #33
                            Then you think it is worth a tray with my tool ? or better to use hot Gun and a good preheating 220" to 230" C
                            • lotas
                              • Jan 2016
                              • 4899
                              • Russia
                              #34
                              What do you want to do with the Mediatek chip, replace it with a new one, are you sure that it is short-circuiting or do you just want to warm it up and think that the short circuit will disappear.
                              • Diah
                                • Feb 2013
                                • 6614
                                this MT SoC cant be refllow or heated ,
                                main function pin out of it
                                • Pin 1 (VDD): Power Supply Voltage Pin.
                                • Pin 2 (VSS): Ground Pin.
                                • Pin 3 (V0): LCD Contrast Voltage Pin.
                                • Pin 4 (RS): Register Select Pin for Command/Data.
                                • Pin 5 (R/W): Read/Write Pin for Data Read/Write Control.
                                • Pin 6 (E): Enable Pin for LCD Controller.
                                • Pin 7 (D0-D7): Data Pins for 8-bit Data Bus.
                                • Pin 8 (BLA): Backlight Anode Pin.
                                • Pin 9 (BLK): Backlight Cathode Pin.
                                • bohaboha
                                  • Nov 2012
                                  • 1045
                                  • sweden
                                  #36
                                  What to do then ? just change it or new board or maybe find the short
                                  • Diah
                                    • Feb 2013
                                    • 6614
                                    test above listed SoC pins agains GND or pin 2 VSS
                                    • bohaboha
                                      • Nov 2012
                                      • 1045
                                      • sweden
                                      #38
                                      • Here is the result
                                      • Pin 1 (VDD): Power Supply Voltage Pin = 2.65V and loop from to 2.704 V
                                      • Pin 3 (V0): LCD Contrast Voltage Pin.0.039V
                                      • Pin 4 (RS): Register Select Pin for Command/Data.0.35o loop to 2.1 V
                                      • Pin 5 (R/W): Read/Write Pin for Data Read/Write Control. 0.3
                                      • Pin 6 (E): Enable Pin for LCD Controller.3.270V
                                      • Pin 7 (D0-D7): Data Pins for 8-bit Data Bus.3.270V
                                      • Pin 8 (BLA): Backlight Anode Pin.3.28V
                                      • Pin 9 (BLK): Backlight Cathode Pin. 2.211V​
                                      • Diah
                                        • Feb 2013
                                        • 6614
                                        at time VDD 2.65V and at D0 D7 3.270 & E the same.. it tell yours MB complete shorted, in this case replacement MB the easy way to avoid headache.
                                        • bohaboha
                                          • Nov 2012
                                          • 1045
                                          • sweden
                                          #40
                                          [QUOTE=Diah;n3624269]at time VDD 2.65V and at D0 D7 3.270 & E the same.. it tell yours MB complete shorted, in this case replacement MB the easy way to avoid headache.[
                                          Thank you Diah this TV is not worth spending money on it, while waiting for my Mainbord for Samsung UE70TU6905 by the way a 58 inches the coming one (on other thread) I will continue to find if possible the short maybe I will learn something thanks again
                                          • thstuff
                                            Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                            by thstuff
                                            A) TV initially dead
                                            B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                            C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                            D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                            E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                            12-26-2024, 09:10 PM
                                          • jamesp
                                            Acer Aspire A315-55 Dead mainboard
                                            by jamesp
                                            Hello, can someone please help me. i have a dead laptop mainboard, aspire a315-55 with board model DA0ZAWMB8G0 rev. G
                                            upon checking of voltages at s5, 19v is present Vin, 5v and 3v is present at PL6001 and PL6000 respectively, but no signal from MAINON And s5_ON to be able to produce +3v_s5 to give power to vcc of BIOS CHIP U2. MAINON and S5_ON is coming from ec chip U37 it8987e/cx.
                                            do i need to reflash the EC? any advice? thanks...
                                            09-30-2024, 08:24 AM
                                          • 3mz3t
                                            ThinkPad T14 Gen1 Intel, dead mainboard
                                            by 3mz3t
                                            NM-C931 mainboard, does not start, no light, no nothing. Draws 20.56 V / 0.14 A from a wall charger.
                                            Under thermal camera, the only thing that show is the ThinkEngine chip (BD4179MWV / UTE1B) heating up (also quite hot to the touch), there's 19.75 V on the VREGIN20 (pin 45).
                                            Is the BD4179 dead? WDYT?
                                            Thank you....
                                            08-05-2024, 04:59 AM
                                          • Talyn
                                            Sony 55W905 dead
                                            by Talyn
                                            My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
                                            I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
                                            Any advice? Thanks!
                                            04-15-2024, 08:14 AM
                                          • mmartell
                                            Sony KDL-65W850C is this a Mainboard issue ??
                                            by mmartell
                                            This sat around for quite some time after the backlights died with the six blink error code. I bought replacement strips and eventually swapped them in.
                                            Backlights appear to be working fine now. However the tv only powers on with the "Sony" logo for about two seconds after which it goes away and the panel with backlights stay powered for about twenty more seconds then it shuts off. Tv can only be powered again after power cycling at the outlet.
                                            It will not program via usb, the stick flashes but there is never any indication that it has entered programming...
                                            11-19-2023, 10:27 AM
