I have a vizio E470VL that a customer brought in that is dead. no response from the power button, only the vizio logo goes to orange when plugged in. 5v standby is only voltage on power supply connector. all fuses are good. The HDMI ic on the mainboard is blistering hot to touch. Question, would removing the HDMI ic allow the tv to turn on, and would an over-heated HDMI ic keep a tv from operating?
vizio E470VL unusual question
Re: vizio E470VL unusual question
The HDMI IC may be locking up the processor so it will not allow the processor to function, that is the only thing I can think of. You can try removing the IC, unless we understand exactly how HDMI IC communicate with the processor, we cannot tell if removing the IC will allow the board to work again or not.Last edited by budm; 07-18-2014, 02:01 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
this is from a post "Re: Vizio E470VL Orange Light/No Power"
I will say yes a burn HDMI chip can cause a TV not to power on.
I pick up two Vizio last week the seller claim that both TV's wouldn't power on after a bad power outage surge.
the first TV Vizio E370VL, got it home and remove the back of the case to find no burn chips or blown fuses. plug the power cord in and I got a orange light on the front "Vizio logo" press the power button and nothing. I was leaning toward the EPPROM being bad but I remember what the seller said. So I touch the main CPU chip and then the HDMI chip. the main cpu chip was cold but the HDMI chip was warm to the touch with no signal being inputted. I check the HDMI chip under magnification and saw a little black ball near the corner of the chip.
So I started to remove the HDMI chip with a hot air gun and that when I can smell that "burn out smell"
after the chip removal the TV power up fine now.Comment
I am going to remove the HDMI IC and see what happens. Like you, with no input the IC is too hot to touch. After removing if the TV works or the symptoms change at all I will order a replacement HDMI IC and install it. Mouser has them for $4.90 plus shipping of about $5Comment
His is a P13HDMI 301ZLE which is a square IC. Mine is a P13HDMI 245AZLE which is a rectangle IC. I've looked at the data sheet on these and it does appear to have base-tab, so I will be using a hot air gun to remove it.Comment
http://www.ernestos-electronics.com/...-azle-ic-chip/
you can buy the chip with in the US. if neededComment
no, the traces are damage and the thermal pad for the IC chip is destroy.This board can't be repaired using the HDMI portsComment
Assuming...7 Photos -
by Bugman1400EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
+5VSB= +5.09
12V= +12.18
PS_ON= +2.25
I_ON/OFF= +3.27
LAMP= +3.18
DIM= +2.97
Any more testing I can do on Main board or is it just a replacement?... -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by dholleyWould someone please help troubleshoot a Vizio 47" TV Switch Mode Power Supply with 5 volt output fluctuating voltage. The voltage fluctuates at 5 the volt output and at the Pulse Switch Modulating IC at VCC. I have the following notes:
1. The 3 main filter caps all have approximately 167 volts steady
2. I have replaced 4 mosfets next to what I think is called the inventor transformer (big black transformer) pictures attached
3. I have replaced Fuse F102 with an equivalent
4. I have check all diodes and caps and they seem to be ok
5. I replaced the 431... - Loading...
