vizio E470VL unusual question
  • jgrice53
    • Dec 2012
    • 63
    • usa
    I have a vizio E470VL that a customer brought in that is dead. no response from the power button, only the vizio logo goes to orange when plugged in. 5v standby is only voltage on power supply connector. all fuses are good. The HDMI ic on the mainboard is blistering hot to touch. Question, would removing the HDMI ic allow the tv to turn on, and would an over-heated HDMI ic keep a tv from operating?
    Re: vizio E470VL unusual question
    The HDMI IC may be locking up the processor so it will not allow the processor to function, that is the only thing I can think of. You can try removing the IC, unless we understand exactly how HDMI IC communicate with the processor, we cannot tell if removing the IC will allow the board to work again or not.
    • jgrice53
      • Dec 2012
      • 63
      • usa
      there is another post about this model with the same problem and someone suggested that the hdmi is not plug and play and if treated as plug and play could cause this condition.
      • jgrice53
        • Dec 2012
        • 63
        • usa
        i am having trouble locating another main board so I was wondering if i just remove the ic and see if the tv would work
        • jgrice53
          • Dec 2012
          • 63
          • usa
          this is from a post "Re: Vizio E470VL Orange Light/No Power"
          Originally posted by selldoor
          It wont be of help to you but did you treat the hdmi sockets as plug and play
          and plugged in the roku when either was stitched on?
          I have been warning people that hdmi is not plug and play due to the number of cases on here where it stuffs the main/logic board.
          • ecking767
            • Oct 2009
            • 492
            I will say yes a burn HDMI chip can cause a TV not to power on.
            I pick up two Vizio last week the seller claim that both TV's wouldn't power on after a bad power outage surge.
            the first TV Vizio E370VL, got it home and remove the back of the case to find no burn chips or blown fuses. plug the power cord in and I got a orange light on the front "Vizio logo" press the power button and nothing. I was leaning toward the EPPROM being bad but I remember what the seller said. So I touch the main CPU chip and then the HDMI chip. the main cpu chip was cold but the HDMI chip was warm to the touch with no signal being inputted. I check the HDMI chip under magnification and saw a little black ball near the corner of the chip.
            So I started to remove the HDMI chip with a hot air gun and that when I can smell that "burn out smell"
            after the chip removal the TV power up fine now.
            • jgrice53
              • Dec 2012
              • 63
              • usa
              I am going to remove the HDMI IC and see what happens. Like you, with no input the IC is too hot to touch. After removing if the TV works or the symptoms change at all I will order a replacement HDMI IC and install it. Mouser has them for $4.90 plus shipping of about $5
                • 30983
                just make sure you remove it cleanly,
                ecking767 damaged the pcb and ripped a load of tracks up!
                • jgrice53
                  • Dec 2012
                  • 63
                  • usa
                  yeah it will be a bit of a challenge because it is such a small IC. I use CHIPQUIK so hopefully I can get it off without any problems.
                    • 30983
                    i dont think you can do it.
                    looking at that fucked-up mess, i think the chip has a base-tab soldered to the board in the center.
                    i think it needs a hot-air unit.
                      • 30983
                      actually, i'm 100% sure it does on second look
                      • jgrice53
                        • Dec 2012
                        • 63
                        • usa
                        His is a P13HDMI 301ZLE which is a square IC. Mine is a P13HDMI 245AZLE which is a rectangle IC. I've looked at the data sheet on these and it does appear to have base-tab, so I will be using a hot air gun to remove it.
                        • jgrice53
                          • Dec 2012
                          • 63
                          • usa
                          I will take before and after pcs and post them
                          • ecking767
                            • Oct 2009
                            • 492
                            I didn't ripped up the traces intentional, the thermal pad on the IC chip was fused to the board caused by the power surge, I have CHIPQUIK,and it wasn't any help in this case.I had my hot air gun temp up high, is wasn't having any affect on the chip being remove with ease.
                            http://www.ernestos-electronics.com/...-azle-ic-chip/
                            you can buy the chip with in the US. if needed
                            • jgrice53
                              • Dec 2012
                              • 63
                              • usa
                              So the TV is working without installing a new IC? guess the traces were not damaged too badly. What input can you use on the TV now without the HDMI IC on the board?
                              • ecking767
                                • Oct 2009
                                • 492
                                yes the TV works on all other inputs: TV, AV,and COMPONENT 1 & 2
                                no, the traces are damage and the thermal pad for the IC chip is destroy.This board can't be repaired using the HDMI ports
                                • jgrice53
                                  • Dec 2012
                                  • 63
                                  • usa
                                  That's good to hear. I will remove it tomorrow and post my results.
                                  • jgrice53
                                    • Dec 2012
                                    • 63
                                    • usa
                                    Well, I got the HDMI IC removed but the TV is still dead.
                                      • 30983
                                      one pad is loose and looks like it's touching another in the 4th foto.
                                      and in the 5th foto it looks like the other chip ower-left has bridged pins - may just be the foto but check.
                                      • DLinkOZ
                                        • May 2013
                                        • 238
                                        Also looks like at least one resistor went on walkabout (R727).
                                        • Bugman1400
                                          Vizio E470VL got +5VSB, but no 12V
                                          by Bugman1400
                                          EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
                                          +5VSB= +5.09
                                          12V= +12.18
                                          PS_ON= +2.25
                                          I_ON/OFF= +3.27
                                          LAMP= +3.18
                                          DIM= +2.97
                                          Any more testing I can do on Main board or is it just a replacement?...
                                          09-04-2022, 09:19 AM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • dholley
                                          Vizio TV E470VL SMPS Flucuation Output Voltage
                                          by dholley
                                          Would someone please help troubleshoot a Vizio 47" TV Switch Mode Power Supply with 5 volt output fluctuating voltage. The voltage fluctuates at 5 the volt output and at the Pulse Switch Modulating IC at VCC. I have the following notes:
                                          1. The 3 main filter caps all have approximately 167 volts steady
                                          2. I have replaced 4 mosfets next to what I think is called the inventor transformer (big black transformer) pictures attached
                                          3. I have replaced Fuse F102 with an equivalent
                                          4. I have check all diodes and caps and they seem to be ok
                                          5. I replaced the 431...
                                          01-20-2022, 03:12 PM
