VIZIO (V555-H1) Television with odd cascading display fault
This topic has been answered.
+ More Options
Posts
  • Garret Matt.
    • Apr 2025
    • 22
    I'm working on a Vizio Model V555-H1 that displays a cascading series of horizontal lines when first powering on. These lines appear to be in the shape of the Vizio Logo and descend until reaching the logo before resetting to the top and continuing their descent. I have reseated my TCON board and dusted connections but still have this fault displaying. I'm familiar with vertical lines but this one is a new one for me. My research into this problem hasn't yielded results as keyword searches point back to vertical line problems.
    Anyone have any recommendations? I stand ready to remove diodes on the buffer board.
    Once the display reaches the home/landing page it switches to this:
  • Answer selected by Garret Matt. at 04-05-2025, 02:25 PM.
    lotas
    • Jan 2016
    • 4694
    • Russia
    They are in this area, pick up block these pins from the sore side, for the best effect...
    • Garret Matt.
      • Apr 2025
      • 22
      Here is a view of each side of the buffer board at the bottom of the display.
      Left:
      Right:
      • lotas
        • Jan 2016
        • 4694
        • Russia
        Disconnect the strips from the T-con and check the resistance of each diode assembly relative to ground (each diode assembly has 4 pins, the middle 3 pin is GND)
        • Garret Matt.
          • Apr 2025
          • 22
          After disconnecting the strips from the T-Con and checking the resistance in diode mode on each spot you marked I am seeing .0L on my multimeter. In resistance mode I got OL in both directions as well.
          • lotas
            • Jan 2016
            • 4694
            • Russia
            It is better to measure resistance on large limits (200kOhm, 2MOm). Disconnect the left bar from T-CON and turn on the TV, see how the image will be on one half, then do the same with the right side...
            • Garret Matt.
              • Apr 2025
              • 22
              Disconnecting the left bar from the T-CON allowed the opposite side of the screen to display correctly.
              Disconnecting the right bar from the T-CON resulted in the same cascading screen image.
              • Garret Matt.
                • Apr 2025
                • 22
                I double checked pin connectors and ribbon cables and everything is intact.
                • lotas
                  • Jan 2016
                  • 4694
                  • Russia
                  So there is a problem on the left side, try to mask it on the CKV line...
                  • Garret Matt.
                    • Apr 2025
                    • 22
                    Having trouble identifying the CKV Line without a data sheet for the IC. My search yielded no results. Is the CKY marked differently on this T-CON Board?
                    • lotas
                      • Jan 2016
                      • 4694
                      • Russia
                      • Garret Matt.
                        • Apr 2025
                        • 22
                        Thanks! I’ll give this a try tomorrow.
                        • Diah
                          • Feb 2013
                          • 6404
                          we do have here dual Channel Timing T-CON., one channel defect, could be Quartz or PMC, or also MB Data issue ... best way disconnect the LVDS, if yours BL remain On. fed the TCON F101 with 12V VCC and let it start RGB Test.for period of time., this will reset the T-CON SPI / gamma/ PMC
                          • Garret Matt.
                            • Apr 2025
                            • 22
                            Do you suppose replacing the TCON F101 would provide the same results? I do have a donor board and i'm much more confident swapping ICs than injecting voltage.
                            Here are my results after trying 'Iotas' suggested fix. It was in fact a signal timing issue. Effectively this Television has been saved from E-waste so I'm satisfied with this conclusion. There are vague lines when the device first powers on but it's hardly noticeable with a full picture at a comfortable viewing distance.
                            • lotas
                              • Jan 2016
                              • 4694
                              • Russia
                              Well, that's great, as I said, the problem is on the left side in the panel itself and here it is not a two-channel T-CON clock signal, but a regular one and is divided into each half of the panel.
                              • Diah
                                • Feb 2013
                                • 6404
                                when you disconnect one ribbon cable to Panel you will have picture on left or right ... its dual channel t-con... but when you have only one picture on one side only this signal channel. ... so correct your info.
                                masking CKV docent meant found fault... you are just remove the load from one channel of T-CON...
                                tell me what are defect on panel of double and distributed image, but when u mask one 1 or 2 ckv the panel display correct full image ?
                                • lotas
                                  • Jan 2016
                                  • 4694
                                  • Russia
                                  The same signals (CKV....) are supplied to both the left and right sides. If you don’t believe me, you can use a multimeter to ring these signals CKV1, CKV2,.... The same line will be on both the left and right sides.
                                  • brad2157
                                    Vizio E70-E3 Two white vertical lines
                                    by brad2157
                                    I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                                    Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                                    Replacement main board - Boots up fine, but starting...
                                    12-13-2021, 05:11 PM
                                  • x_orange90_x
                                    Vizio V585-J01 dancing lines and image doubling
                                    by x_orange90_x
                                    I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
                                    Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
                                    Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
                                    I swapped...
                                    06-12-2024, 07:57 AM
                                  • viking509
                                    vizio e65 e3 LED tv color vertical lines center tv only
                                    by viking509
                                    I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                                    03-21-2023, 12:48 AM
                                  • rapid911
                                    Vizio M58Q7 colored horizontal lines
                                    by rapid911
                                    Hi guys, I have a Vizio M58Q7-J01 and now there are some colored horizontal lines on the screen. Could someone tell me if it's probably a panel issue or something related to other parts and can be fixed? Thank you in advance....
                                    05-28-2023, 04:17 PM
                                  • JRyan
                                    Vizio 39" horizontal lines
                                    by JRyan
                                    Found yet another TV by the road that has lines across the whole screen. What is causing this?
                                    12-22-2023, 10:02 PM
