TCL 50S535 bad tcon or panel issue?
  • x_orange90_x
    • May 2015
    • 727
    Originally posted by Diah
    BUl**SHIT what over written to stop and no HOPE.. did yours ass was part from Panel or TV production?
    OP. TCON just timing , Panel are slave to T-CON., data when it come correct from MB then T-CON timing them to its slave. as soon Panel display correct image no way its fault. MB always the keys of Data.
    BGA connection issue?
    • Diah
      • Feb 2013
      • 6440
      could be.. but at this issue need to monitor Signal within Oscilloscope. this will bring us direct to fault.
      • x_orange90_x
        • May 2015
        • 727
        Hmm. I don't own one of those unfortunately. Any other way to narrow it down?
        • Diah
          • Feb 2013
          • 6440
          investment by MB with refund
          • x_orange90_x
            • May 2015
            • 727
            I found a board in my collection from a 4 series, 421 I believe, that has all of the same connectors except for the power button. If it hooks up right, is there a way to turn it on without the button? Is it safe to even try this board? I'll post pictures of it later.
            • EazyBone
              • Jun 2023
              • 1353
              • United states
              #46
              Before you try a new main board with different set go into the service menu on the original TV check what the panel code is because you would likely have to change the panel code or else you're going to get a jumbled screen. Google how to go to the service menu and then find where it shows the panel code should be a number between 0 and 100 roughly so if you do try a different board that fits you will probably have to change the panel code
              • x_orange90_x
                • May 2015
                • 727
                It's just a loose board in my drawer. No idea what TV I pulled it from as it's long gone. I simply want to see if the band appears. If the screen is jumbled I guess that wouldn't really help me would it ๐Ÿค” nonetheless I'll post pictures of it shortly when I get home
                • EazyBone
                  • Jun 2023
                  • 1353
                  • United states
                  #48
                  He likes to push your buttons because you react. And when he gets his buttons pushed he cries too. Pretty sure just best to ignore.
                  You can easily look up a boards model number plug it into shopjimmy or eBay and it'll tell you.
                  And if it's for TCL and screen is jumbled ... After you set to correct panel it goes normal so I don't know what you mean by that. I'm not even saying this is going to do anything.
                  • lotas
                    • Jan 2016
                    • 4754
                    • Russia
                    #49
                    So what's your diagonal? The thread says it's a TCL 50S535, but the motherboard tag says 55S535.
                    • x_orange90_x
                      • May 2015
                      • 727
                      ๐Ÿ˜† I just realized a couple nights ago when I was standing it up that it was 55", and then the Roku app said 55 and I'm like oh ya lol. Props to you for catching that
                      • x_orange90_x
                        • May 2015
                        • 727
                        Attached are the two boards, the original and the one I mentioned. It looks like it has all the same connectors except for the power button. It's from a 50S421.
                        I just want to see if the vertical band appears, but if the screen won't display right because of the size difference, I probably won't notice, right?
                        Edit: nevermind that, I see it's missing another connector for the LED inverter.
                        • EazyBone
                          • Jun 2023
                          • 1353
                          • United states
                          #52
                          No those won't work, they generally look identical. You have the newer model. Oh well
                          • Diah
                            • Feb 2013
                            • 6440
                            you can try disconnect the LVDS from MB side. and feed the T-CON 12V an point VCC after F201. see if the T-CON will start at test mode... as it had TEST points label printed on it
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4467
                              • Italy - Milan
                              #54
                              For what importance it has now i remember years ago i bought a big tv from LG, the defect was the same and it was installed right under an air conditioner, that the owner said it dripped sone condenser water on the tv, after many tests on the panel boards, i found the target, wiith a magnifier lens i found a single burnt trace on a cof tab, the one with the correspondence to the issue on all its working area.. and that's it..
                              • x_orange90_x
                                • May 2015
                                • 727
                                You sir led me to double check the area closely.. And I found the issue! Question is, can I replace then? Does the value matter significantly, or can I replace them with ones of similar physical size?
                                Edit: so I tried cleaning them with alcohol and they all cleaned up nicely. No physical damage that can be seen. I even checked for ground shorts on them and they all tested good. However, I still have the band ๐Ÿ˜” what's really strange though is that if you look at the attached pictures, you cannot see it at all except for on the lightest shades of color. Like literally, it does not appear on any of the darker areas. But if the whole screen is white or another really light color you'll see it from top to bottom. If one of these caps were bad, wouldn't it be permanently visable on ALL colors?
                                  • 12276
                                  • U.S.
                                  #56
                                  Yep, pop some same sized ones in there.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4467
                                    • Italy - Milan
                                    #57
                                    Please, if you use a smart phone to make photos, i suggest you to install a separate app to make trimmed photos for email / web exchange with a maximum of around 2k x 2k px, like i suggest in my sticky post, in Android i.use "Camera flash" from expertisenetcoms that has also a particular "light booster" (more bright on low light), good for boards, besides this i need a larger area pictured of the board so i can understand the purpose of those caps, i suggest you to replace them all the oxydated ones, generally you get them on spare cracked lcd boards (i store a lot of them) the same size /.same color hue ones, color has relevance for capacity, the darker the more capable, the newer the more cap/size ratio..
                                    PS: check them for capacity in circuit, compare between them, they must match each other, the cof tab must be checked on the green side, by flipping the board..
                                    • lotas
                                      • Jan 2016
                                      • 4754
                                      • Russia
                                      #58
                                      Take a toothbrush, wet it with isopropyl alcohol and clean these capacitors from oxide, dry and check whether the strip has disappeared or not.
                                      • x_orange90_x
                                        • May 2015
                                        • 727
                                        I tried. They cleaned up nicely too.. Didn't look blown, burnt, or anything like that. The band was still present tho. I checked them for ground shorts and they all tested good.
                                          • 12276
                                          • U.S.
                                          #60
                                          I see, it sounded like you meant they tested bad.
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed๐Ÿ™
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • alltvrepairs
                                            Lg TCon test pins for screen test
                                            by alltvrepairs
                                            i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                            Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                            Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                            Appreciate your help....
                                            06-13-2025, 06:33 AM
                                          • speedtime07
                                            i life zed air cx5 no image on screen
                                            by speedtime07
                                            hi everyone ,
                                            There is an image on the external computer screen ,
                                            flexi cable test ok - screen test ok -
                                            What alternative should I look for?
                                            thank you for your supportโ€‹
                                            04-10-2025, 06:24 AM
