Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
TCL 50S535 bad tcon or panel issue?
  • x_orange90_x
    • May 2015
    • 798
    I see, it sounded like you meant they tested bad.
    Even though I don't understand how the main board could cause this type of display issue, I'm going to try disconnecting it and getting a test pattern on the tcon. Depending on the shades of colors in that pattern I may not see the band anyway 😒
    It just doesn't make sense that it appears in some shades but not others, particularly in light but not in dark.
    • Daren87
      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
      by Daren87
      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
      08-13-2023, 03:25 PM
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • alltvrepairs
      Lg TCon test pins for screen test
      by alltvrepairs
      i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
      Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
      Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
      Appreciate your help....
      06-13-2025, 06:33 AM
    • speedtime07
      i life zed air cx5 no image on screen
      by speedtime07
      hi everyone ,
      There is an image on the external computer screen ,
      flexi cable test ok - screen test ok -
      What alternative should I look for?
      thank you for your support​
      04-10-2025, 06:24 AM
