s'il vous plaît vous m'aider philips 42PFP5532D /12
  • Mogador12
    • Jul 2014
    • 40
    • french
    #41
    Re: s'il vous plaît vous m'aider philips 42PFP5532D /12
    it's good I ordered up on the site mouser
    I thank you for your waiting rooms after I tell you if it fonctioone thank you for your help really nice
    • Mogador12
      • Jul 2014
      • 40
      • french
      #42
      https://www.badcaps.net/forum/attach...05942672:beer:
      • Mogador12
        • Jul 2014
        • 40
        • french
        #43
        Hello to you all
        I'm back, I change the S2186 and not going because he jumps acha that time and now I have the red led blinking one second and then remains fixed? that what this problem
        • Mogador12
          • Jul 2014
          • 40
          • french
          #44
          https://www.badcaps.net/forum/attach...1&d=1406570622
          • Mogador12
            • Jul 2014
            • 40
            • french
            #45
            hello
            what is the value of the zener diode that red and yellow and green
            https://www.badcaps.net/forum/attach...1&d=1406741020
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #46
              Maybe
              • Mogador12
                • Jul 2014
                • 40
                • french
                #47
                thanks
                • Mogador12
                  • Jul 2014
                  • 40
                  • french
                  #48
                  Hello there
                  or I can find the zener diode because in french not possible
                  https://www.badcaps.net/forum/attach...1&d=1406821027
                    • 31185
                    green = 5
                    yellow = 4
                    red = 2
                    so either 542 (5v4?)
                    or maybe 245 which makes no sense!
                    • Mogador12
                      • Jul 2014
                      • 40
                      • french
                      #50
                      this is the exact value of the 542 diode (5V4?)
                      • Mogador12
                        • Jul 2014
                        • 40
                        • french
                        #51
                        http://f1mvp.perso.sfr.fr/hamradio/diode.htm
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          #52
                          Well I dont know using the datasheet
                          green yellow red is a RLZ18
                          RLZ 18B 16.82 17.70 10 23 10 150 0.5 0.2 13
                          So voltage is around 17v
                          • alro7779
                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                            by alro7779
                            Hello, guys!
                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                            09-14-2025, 12:25 AM
                          • G33RT
                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                            by G33RT
                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                            It does power up when pressing the power button.
                            I already try the power button while plugin the plug with no result.
                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                            Could this be an PSU or eMMC issue ?
                            07-19-2025, 03:43 AM
                          • double_DD
                            Philips curling iron - is this a common AC cable?
                            by double_DD
                            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                            08-18-2025, 10:04 AM
                          • janos6662000
                            Philips 47PFS7509/12 LCD TV problem
                            by janos6662000
                            Hi
                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                            I downloaded original firmware and applied the update, but the problem remained.
                            From a colleague i received a "factory package software" which is a lot bigger.
                            I made another firmware update, but still did not solve the problem.
                            Somewhere on the way the error got worse, because at the moment the...
                            08-12-2025, 12:54 PM
                          • aidanmo
                            Philips 43PUS7506/12 - Loud blown out sound
                            by aidanmo
                            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                            I thought maybe the speakers got damaged, so I replaced them - no dice.
                            • Using the internal speakers, it always happens.
                            • Using the headphone jack, it never happens.
                            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                            02-28-2025, 03:13 PM
