s'il vous plaît vous m'aider philips 42PFP5532D /12
  • Mogador12
    • Jul 2014
    • 40
    • french
    #41
    Re: s'il vous plaît vous m'aider philips 42PFP5532D /12
    it's good I ordered up on the site mouser
    I thank you for your waiting rooms after I tell you if it fonctioone thank you for your help really nice
    • Mogador12
      • Jul 2014
      • 40
      • french
      #42
      https://www.badcaps.net/forum/attach...05942672:beer:
      • Mogador12
        • Jul 2014
        • 40
        • french
        #43
        Hello to you all
        I'm back, I change the S2186 and not going because he jumps acha that time and now I have the red led blinking one second and then remains fixed? that what this problem
        • Mogador12
          • Jul 2014
          • 40
          • french
          #44
          https://www.badcaps.net/forum/attach...1&d=1406570622
          • Mogador12
            • Jul 2014
            • 40
            • french
            #45
            hello
            what is the value of the zener diode that red and yellow and green
            https://www.badcaps.net/forum/attach...1&d=1406741020
            • selldoor
              Slow Learner
              • 7870
              #46
              Maybe
              • Mogador12
                • Jul 2014
                • 40
                • french
                #47
                thanks
                • Mogador12
                  • Jul 2014
                  • 40
                  • french
                  #48
                  Hello there
                  or I can find the zener diode because in french not possible
                  https://www.badcaps.net/forum/attach...1&d=1406821027
                    • 31043
                    green = 5
                    yellow = 4
                    red = 2
                    so either 542 (5v4?)
                    or maybe 245 which makes no sense!
                    • Mogador12
                      • Jul 2014
                      • 40
                      • french
                      #50
                      this is the exact value of the 542 diode (5V4?)
                      • Mogador12
                        • Jul 2014
                        • 40
                        • french
                        #51
                        http://f1mvp.perso.sfr.fr/hamradio/diode.htm
                        • selldoor
                          Slow Learner
                          • 7870
                          #52
                          Well I dont know using the datasheet
                          green yellow red is a RLZ18
                          RLZ 18B 16.82 17.70 10 23 10 150 0.5 0.2 13
                          So voltage is around 17v
                          • G33RT
                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                            by G33RT
                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                            It does power up when pressing the power button.
                            I already try the power button while plugin the plug with no result.
                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                            Could this be an PSU or eMMC issue ?
                            07-19-2025, 03:43 AM
                          • aidanmo
                            Philips 43PUS7506/12 - Loud blown out sound
                            by aidanmo
                            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                            I thought maybe the speakers got damaged, so I replaced them - no dice.
                            • Using the internal speakers, it always happens.
                            • Using the headphone jack, it never happens.
                            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                            02-28-2025, 03:13 PM
                          • Cornito
                            Philips 50PUH6400 bad color and gosting / slow motion on one side
                            by Cornito
                            Hello Team,
                            New issue on LCD panel where I need to find out the cause and the potential solution.
                            This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                            I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                            When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                            I've checked voltages, no issue found comparing right and left side of the panel driver.
                            VHG VGL CKV... are the sames on...
                            03-08-2024, 06:41 AM
                          • spantor
                            Activate power board Philips 40PFH40009/88 tv
                            by spantor
                            Hello partners.
                            Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                            The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                            02-11-2024, 05:07 PM
                          • alro7779
                            Philips 32PFL4901/F8 BA5DFGG0201 1 Backlight is present but no image
                            by alro7779
                            Hello there!
                            Have this Philips with no image at all. When I plug it to the outlet, it turns on without pressing the power button, and after a moment, it turns off, then starts again. I checked the 12v and 3.3v voltages on the main board connector that goes to the T-con, but it only has the former (12v). Any clues, guys?...
                            08-07-2025, 11:53 AM
