s'il vous plaît vous m'aider philips 42PFP5532D /12
  • Mogador12
    • Jul 2014
    • 40
    • french
    Re: philips 42PFP5532D /12
    one to help me
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Re: s'il vous plaît vous m'aider philips 42PFP5532D /12
      Tension at fuse?
      No find schematic
      • Mogador12
        • Jul 2014
        • 40
        • french
        sorry
        weird sound good but there is no fuse on the power supply board and both left and right bottomhttps://www.badcaps.net/forum/attachment.php?attachmentid=90061&stc=1&d=1405258529
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Wrong Fuse - This one
          • Mogador12
            • Jul 2014
            • 40
            • french
            hello
            non fuse sounds so good is that
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #26
              Tension on fuse? chaque cote
              • Mogador12
                • Jul 2014
                • 40
                • french
                #27
                zero voltage on each side
                • Mogador12
                  • Jul 2014
                  • 40
                  • french
                  #28
                  https://www.badcaps.net/forum/attach...1&d=1405457179
                  I can not find the diagram of the power supply board
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #29
                    Looks like main board or tcon problem or broken panel
                    • Mogador12
                      • Jul 2014
                      • 40
                      • french
                      #30
                      https://www.badcaps.net/forum/attach...1&d=1405459467
                      the cable coming from the supply board
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        #31
                        Any tension on that end (white line)
                        • Mogador12
                          • Jul 2014
                          • 40
                          • french
                          #32
                          yes the power board
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            #33
                            Voltages on the cable at the power board end?
                            • Mogador12
                              • Jul 2014
                              • 40
                              • french
                              #34
                              I go to bed and tomorrow I change all the capacitor thank you for your patient to help others Bravo
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                #35
                                May not be a cap problem but you do need to trace why there is no voltage to
                                tcon
                                Really need Tom66 to look at the picture on screen to see if he thinks it is a panel fault
                                https://www.badcaps.net/forum/attach...5&d=1405020869
                                  Hmm, hard to tell, not seen one like that before! Doesn't look like a panel fault. Given no image I would suggest a possible X-main or combination of X-main and Y-main bad...
                                  Could also be control board. I kind of doubt it though.
                                  Really hard to be sure.
                                  Try checking Ve voltage on X-main
                                  Try checking Vsc and Vsch and Vset (if present) on Y-main
                                  • Mogador12
                                    • Jul 2014
                                    • 40
                                    • french
                                    #37
                                    https://www.badcaps.net/forum/attach...1&d=1405937010
                                    Hello to you all
                                    Here I found the problem on platinum is cmos S2186 806P IR CX6R7 where I can find this circuit
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #38
                                      peut-être
                                      http://ca.mouser.com/Search/Refine.aspx?Keyword=s2186
                                      • Mogador12
                                        • Jul 2014
                                        • 40
                                        • french
                                        #39
                                        this is not the same reference (S2186 806P IR CX6R7)
                                        (942-IRS21867STRPBF)
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          I was thinking IRS2186SPbF, International Rectifier, Gate Drivers 3-Phase Bridge DRVR 600V 10V to 20V
                                          https://cdn.badcaps-static.com/pdfs/...75b95f7c6b.pdf
                                          • alro7779
                                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                            by alro7779
                                            Hello, guys!
                                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                            09-14-2025, 12:25 AM
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • double_DD
                                            Philips curling iron - is this a common AC cable?
                                            by double_DD
                                            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                            08-18-2025, 10:04 AM
                                          • janos6662000
                                            Philips 47PFS7509/12 LCD TV problem
                                            by janos6662000
                                            Hi
                                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                            I downloaded original firmware and applied the update, but the problem remained.
                                            From a colleague i received a "factory package software" which is a lot bigger.
                                            I made another firmware update, but still did not solve the problem.
                                            Somewhere on the way the error got worse, because at the moment the...
                                            08-12-2025, 12:54 PM
                                          • aidanmo
                                            Philips 43PUS7506/12 - Loud blown out sound
                                            by aidanmo
                                            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                            I thought maybe the speakers got damaged, so I replaced them - no dice.
                                            • Using the internal speakers, it always happens.
                                            • Using the headphone jack, it never happens.
                                            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                            02-28-2025, 03:13 PM
