s'il vous plaît vous m'aider philips 42PFP5532D /12
  • Mogador12
    • Jul 2014
    • 40
    • french
    Re: philips 42PFP5532D /12
    one to help me
    • selldoor
      Slow Learner
      • 7870
      Re: s'il vous plaît vous m'aider philips 42PFP5532D /12
      Tension at fuse?
      No find schematic
      • Mogador12
        • Jul 2014
        • 40
        • french
        sorry
        weird sound good but there is no fuse on the power supply board and both left and right bottomhttps://www.badcaps.net/forum/attachment.php?attachmentid=90061&stc=1&d=1405258529
        • selldoor
          Slow Learner
          • 7870
          Wrong Fuse - This one
          • Mogador12
            • Jul 2014
            • 40
            • french
            hello
            non fuse sounds so good is that
            • selldoor
              Slow Learner
              • 7870
              #26
              Tension on fuse? chaque cote
              • Mogador12
                • Jul 2014
                • 40
                • french
                #27
                zero voltage on each side
                • Mogador12
                  • Jul 2014
                  • 40
                  • french
                  #28
                  https://www.badcaps.net/forum/attach...1&d=1405457179
                  I can not find the diagram of the power supply board
                  • selldoor
                    Slow Learner
                    • 7870
                    #29
                    Looks like main board or tcon problem or broken panel
                    • Mogador12
                      • Jul 2014
                      • 40
                      • french
                      #30
                      https://www.badcaps.net/forum/attach...1&d=1405459467
                      the cable coming from the supply board
                      • selldoor
                        Slow Learner
                        • 7870
                        #31
                        Any tension on that end (white line)
                        • Mogador12
                          • Jul 2014
                          • 40
                          • french
                          #32
                          yes the power board
                          • selldoor
                            Slow Learner
                            • 7870
                            #33
                            Voltages on the cable at the power board end?
                            • Mogador12
                              • Jul 2014
                              • 40
                              • french
                              #34
                              I go to bed and tomorrow I change all the capacitor thank you for your patient to help others Bravo
                              • selldoor
                                Slow Learner
                                • 7870
                                #35
                                May not be a cap problem but you do need to trace why there is no voltage to
                                tcon
                                Really need Tom66 to look at the picture on screen to see if he thinks it is a panel fault
                                https://www.badcaps.net/forum/attach...5&d=1405020869
                                  Hmm, hard to tell, not seen one like that before! Doesn't look like a panel fault. Given no image I would suggest a possible X-main or combination of X-main and Y-main bad...
                                  Could also be control board. I kind of doubt it though.
                                  Really hard to be sure.
                                  Try checking Ve voltage on X-main
                                  Try checking Vsc and Vsch and Vset (if present) on Y-main
                                  • Mogador12
                                    • Jul 2014
                                    • 40
                                    • french
                                    #37
                                    https://www.badcaps.net/forum/attach...1&d=1405937010
                                    Hello to you all
                                    Here I found the problem on platinum is cmos S2186 806P IR CX6R7 where I can find this circuit
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #38
                                      peut-être
                                      http://ca.mouser.com/Search/Refine.aspx?Keyword=s2186
                                      • Mogador12
                                        • Jul 2014
                                        • 40
                                        • french
                                        #39
                                        this is not the same reference (S2186 806P IR CX6R7)
                                        (942-IRS21867STRPBF)
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          I was thinking IRS2186SPbF, International Rectifier, Gate Drivers 3-Phase Bridge DRVR 600V 10V to 20V
                                          https://cdn.badcaps-static.com/pdfs/...75b95f7c6b.pdf
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • janos6662000
                                            Philips 47PFS7509/12 LCD TV problem
                                            by janos6662000
                                            Hi
                                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                            I downloaded original firmware and applied the update, but the problem remained.
                                            From a colleague i received a "factory package software" which is a lot bigger.
                                            I made another firmware update, but still did not solve the problem.
                                            Somewhere on the way the error got worse, because at the moment the...
                                            08-12-2025, 12:54 PM
                                          • aidanmo
                                            Philips 43PUS7506/12 - Loud blown out sound
                                            by aidanmo
                                            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                            I thought maybe the speakers got damaged, so I replaced them - no dice.
                                            • Using the internal speakers, it always happens.
                                            • Using the headphone jack, it never happens.
                                            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                            02-28-2025, 03:13 PM
                                          • Cornito
                                            Philips 50PUH6400 bad color and gosting / slow motion on one side
                                            by Cornito
                                            Hello Team,
                                            New issue on LCD panel where I need to find out the cause and the potential solution.
                                            This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                            I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                            When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                            I've checked voltages, no issue found comparing right and left side of the panel driver.
                                            VHG VGL CKV... are the sames on...
                                            03-08-2024, 06:41 AM
                                          • spantor
                                            Activate power board Philips 40PFH40009/88 tv
                                            by spantor
                                            Hello partners.
                                            Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                                            The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                                            02-11-2024, 05:07 PM
