Looking for some help please. Samsung UN75RU800DFXZA rebooting, no picture, clicks
  • joel warren
    • Jan 2025
    • 32
    TVs diodes…
      • 12330
      • U.S.
      #42
      No, have none, if you think one of them is the problem you can remove one at a time and check it, the tv will likely work without it. Maybe remove one try it, no difference, put it back on and remove the other etc.
      • joel warren
        • Jan 2025
        • 32
        which one is the resistor that I should be checking?
        • joel warren
          • Jan 2025
          • 32
          Originally posted by Diah
          then block CKV line on the U ribbon side which it was on yours hand... you have the pins NO of CKV printed on the boards... give try
          I blocked all 8 CKV lines on the U ribbon cable and the tv no longer clicks, the backlight stays on, but there is no picture.
          • Diah
            • Feb 2013
            • 6573
            if you blocked all 8 CKV rails.... and no reboot... how about if you disconnect this U ribbon complete !! will you have same result ?
            • joel warren
              • Jan 2025
              • 32
              yes. if I disconnect the left side of the U ribbon I get the same result
              • Diah
                • Feb 2013
                • 6573
                so its... blocking all ckv are same to disconnect... this why need reduce yours masking. however i have doubt ... but you can try all 8 CKV messure them against TV chassis ... U ribbon should be disconnected.. check if you find one or 2 low Resistances
                • joel warren
                  • Jan 2025
                  • 32
                  I'm not sure I understand. would like me to measure between the chassis and the ckv? If so, can you please point out in one of my pictures where the CKV lines are on the board?
                  • Diah
                    • Feb 2013
                    • 6573
                    this what you wrote... the U ribbon when you disconnected... the pins you masked before at the socket pins measure them in Ohm against GND
                    • joel warren
                      • Jan 2025
                      • 32
                      what ohm setting should my meter be on to test the pins? I have 2000k, 200k, 20k, 2000, 20
                      • Diah
                        • Feb 2013
                        • 6573
                        all ab to you.... its is adjustable value. that you can choice to make you able to find differences reading between all the 8 lines
                        • joel warren
                          • Jan 2025
                          • 32
                          while on 2000k ohm setting. here are my readings.
                          • Diah
                            • Feb 2013
                            • 6573
                            it sound to me you have issue in glass panel gate transistor .. install the jumpers of Feed back which easybone advised at post #3 and disconnect the U ribbon we are talking on... if no picture displaying... then MB need to replace... but keep in mind the damage at gate transistor which make damage at T-CON circuit at original MB could happen too after short time at the same test advised here.
                            • joel warren
                              • Jan 2025
                              • 32
                              I installed the jumper again, removed the left side of the U ribbon cable and I do get a picture on 3/4 of the screen
                              • Diah
                                • Feb 2013
                                • 6573
                                set yous tv viewing to setting 3/4 at setting instate of wide screen or 16/9 and enjoy it ..
                                • joel warren
                                  • Jan 2025
                                  • 32
                                  thx. guess i'll be throwing it in the garbage.
                                    • 12330
                                    • U.S.
                                    #57
                                    +1000
                                    • bohaboha
                                      • Nov 2012
                                      • 1025
                                      • sweden
                                      #58
                                      +1000
                                      is that means the screen is defect?
                                      • joel warren
                                        • Jan 2025
                                        • 32
                                        Yes. Screen buffer board issue
                                        • bohaboha
                                          • Nov 2012
                                          • 1025
                                          • sweden
                                          #60
                                          screen buffer board many video they fix it some of them just take away some caps thats it not even replace them search you l se before you throw it .Don't give up, you've been helped by wonderful people here, be sure and keep going, they will absolutely help you if you do what they ask you to do
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                            09-07-2024, 05:50 AM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • rui4892
                                            Samsung UE55NU8005T , rebooting , no picture , no backlight
                                            by rui4892
                                            Good morning.
                                            the original board of this equipment is in reboots without giving an image or turning on the backlight, the board code is BN94-12926P (BN41-02636), I made a copy of the flash ic1603 and ic1604, dumps attached. I tried to put other dumps (from other popis models I didn't find this board) but without success. That said, I bought a board on ebay BN94-12926A, which in principle should at least give image, even if with defects, this board turns on and responds to the command but does not give any indication of image despite the availability of VHG and VGL voltages as well...
                                            01-18-2025, 03:15 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
