Looking for some help please. Samsung UN75RU800DFXZA rebooting, no picture, clicks
  • joel warren
    • Jan 2025
    • 32
    TV was working fine and then just shutdown one day. It will not turn back on. I get a backlight for a little while, then it just clicks and won't fully boot.
    I took off the back panel and did the basic troubleshooting and it seems like it's a panel issue.
    The backlight will stay on if I disconnect either of the ribbon cables going to the panel. I've watched this video (https://www.youtube.com/watch?v=77tymvTJDxo) and am wondering if this could be the issue, just a bad cap on the panel.
    Any assistance is appreciated.
  • thetonywarren
    • Feb 2013
    • 149
    We could try to test caps on the panel, but Im not sure how we can determine what their values should be. Im guessing we would need a different type of meter or tool to test those very small SMD caps.
    • EazyBone
      • Jun 2023
      • 1340
      • United states
      Solder the 2 pts in the picture and then remove the speakers and metal guards protecting the buffer boards on the bottom of the TV. There will be a yellowish U ribbon on the left and right side. Unplug one at a time (don't short it so disc it from the closest to the middle). And plug in the tv. If you get 3/4 a pic you know that buffer boards is where it's disconnected is where the short is. If not, reconnect the cable and do it to opposite side and see if 3/4 picture. This will isolate the short on the screen. But
      In the end your screen
      • joel warren
        • Jan 2025
        • 32
        I will try this soon and report back. Thx
        • EazyBone
          • Jun 2023
          • 1340
          • United states
          Also make sure to unplug in-between switches
          • thetonywarren
            • Feb 2013
            • 149
            What were you going to say after "in the end your screen"?
            • joel warren
              • Jan 2025
              • 32
              I think he meant , in the end the issue is my screen…. Going to do the suggested testing tomorrow.
              • joel warren
                • Jan 2025
                • 32
                I unplugged the U shaped gold cable on the far left when looking at the back of the tv and got 3/4 of a picture.. so it’s the left buffer board that has the short..
                any advice on how I can locate the component with the short??
                • EazyBone
                  • Jun 2023
                  • 1340
                  • United states
                  Make sure you test right side also (just to make sure I'm sure you did)
                  Basically you can compare caps from each side of buffer boards, check them using beep beep mode and maybe you will get lucky. If you can't find a short.. well probably internal issue.
                  Don't forget to unsolder that bridge you made.
                  And yes in the end, your screen is dead correct.. small chance something else tho! I've never been lucky on it.
                  • joel warren
                    • Jan 2025
                    • 32
                    Yes, when I reconnected the left side and unplugged the right side, I didn't get a picture and had the same clicking/rebooting issue. I will test the caps next.
                    • joel warren
                      • Jan 2025
                      • 32
                      I'm guessing that it might be the cap at location c211. I used 1 probe on my multimeter on the left side of a cap and get continuity if I touch the left side of any other cap besides c211
                        • 12206
                        • U.S.
                        The question is do you have continuity to ground on one side of the cap, the other side should not.
                        • joel warren
                          • Jan 2025
                          • 32
                          yes I do, I just thought it was odd that I got continuity on the opposite side of c211 from the rest of the caps.
                          I did not find any shorted caps.
                          Is there anything else that I can check?
                          • Diah
                            • Feb 2013
                            • 6376
                            i remember RU series Panel they have at the far end of the panel buffer boards 3 ESD diode... show us .. if there are ESD then one shorted
                            • EazyBone
                              • Jun 2023
                              • 1340
                              • United states
                              I knew I recalled something like that, I was unsure to say something. Pics of buffer boards!
                              • joel warren
                                • Jan 2025
                                • 32
                                • Storyteller12
                                  • Jun 2020
                                  • 624
                                  Don’t see any on that side. Need close up pics of the other side of buffer board.
                                  • joel warren
                                    • Jan 2025
                                    • 32
                                    • Diah
                                      • Feb 2013
                                      • 6376
                                      is this site when you disconnect the U ribbon you got 3/4 screen ? if yes close up clear photo on these 3 sets
                                      • joel warren
                                        • Jan 2025
                                        • 32
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                          09-07-2024, 05:50 AM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • rui4892
                                          Samsung UE55NU8005T , rebooting , no picture , no backlight
                                          by rui4892
                                          Good morning.
                                          the original board of this equipment is in reboots without giving an image or turning on the backlight, the board code is BN94-12926P (BN41-02636), I made a copy of the flash ic1603 and ic1604, dumps attached. I tried to put other dumps (from other popis models I didn't find this board) but without success. That said, I bought a board on ebay BN94-12926A, which in principle should at least give image, even if with defects, this board turns on and responds to the command but does not give any indication of image despite the availability of VHG and VGL voltages as well...
                                          01-18-2025, 03:15 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
