Transformer substitution - Sanyo DP42849-01
  • lookimback
    • Aug 2013
    • 1489
    Over the past couple of months I've encountered 5 of these inverter boards (P/Ns 1AV4U20C41500 and 1AV4U20C41501) which had failed. Of those 5, 2 were PWM failures and 3 were inverter transformer failures. I have failed 3 separate times at disassembling the transformers for rebuild. My most recent failure involved soaking the transformer in MEK overnight to dissolve the varnish which holds the ferrites in. The varnish dissolved (including on the primary windings which weren't bad) but the ferrites still cracked. Even when I have managed to get the ferrites out in one piece, the bobbin that the secondary is wound on usually breaks because it is fused to the primary bobbin.
    So, I've essentially abandoned the idea of rebuilding them. Now my idea is to locate a suitable SMD substitute and and make an adapter board. The adapter board would have the pin configuration of the original transformer and go in it's place. Then a SMD transformer would mount on that board and have tracings go to the correct pin locations. I at least think this could be done.
    My question though, is what I need to take into consideration when looking for a suitable transformer?
    ------------signature starts here------------
  • lookimback
    • Aug 2013
    • 1489
    Re: Transformer substitution - Sanyo DP42849-01
    Here's what I know about the transformer.
    Primary Winding 115 turns
    Secondary Winding 550 turns
    Primary Resistance 0.7-0.8 ohms
    Secondary Resistance 26-27 ohms
    How can I figure out the frequency?
    And the type?
      • 31015
      the datasheet for the driver chip will give you the frequency and sometimes an aplication circuit with transformer details.
      • lookimback
        • Aug 2013
        • 1489
        Data sheet for the PWM just says 30khz to 500 kHz.
        The PWM is a switch mode power supply controller so I guess that means I need an smps transformer?
          • 31015
          are you sure that drives the lamps?
          that board looks like a combined psu and invertor.
          • lookimback
            • Aug 2013
            • 1489
            It is a combined PSU and inverter. I'll look at the data sheets from the other ICs and see if any might be the lamp driver.
            • lookimback
              • Aug 2013
              • 1489
              Maybe it's this one?
                • 31015
                no, that's the pfc circuit.
                trace the transformers back to the fets that switch them.
                then trace the gate pin from those fets to find the drive chip.
                does it have parts on the other side of the board?
                • lookimback
                  • Aug 2013
                  • 1489
                  Here's a pic of the bottom and a link to one of my older threads which has some good closeups of the bottom.
                  https://www.badcaps.net/forum/showthread.php?t=33261
                  • lookimback
                    • Aug 2013
                    • 1489
                    Are these the FETs?
                    Edit: Only other ICs on the board are op-amps and standby controller.
                      • 31015
                      controller
                      • lookimback
                        • Aug 2013
                        • 1489
                        OK, that was the one I originally thought. The data sheet is in post #4. But it only says 30khz to 500khz. So I guess I'll need someone with an oscilloscope right?
                          • 31015
                          frequency counter i think you mean.
                          • lookimback
                            • Aug 2013
                            • 1489
                            So one of these would work then?
                            http://www.ebay.com/itm/OSCILLOSCOPE...item19eae5e6d7
                            http://www.ebay.com/itm/Frequency-Co...item1e8cf01fd0
                              • 31015
                              before you spend much money,
                              there are nice projects.
                              make one.
                              https://duckduckgo.com/?q=atmel+70mh...-wt&kp=-1&kv=1
                              another option, the datasheet implies that the frequency is directly related to the voltage on one of the pins.
                              so maybe meter the voltage to calculate the frequency.
                              finally - check for cheap clone transformers.
                              like here - this seller has a bunch.
                              http://stores.ebay.com/lcd-led-parts
                                • 31015
                                http://danyk.cz/avr_fmetr_en.html
                                • lookimback
                                  • Aug 2013
                                  • 1489
                                  Sweet! So we have the circuits resonant frequency. Or, will have once I build the counter. Now I guess all that's left to determine is the transformer's input voltage and current. I get nothing with my volt meter because the frequency is too high.
                                    I wouldn't stick that frequency meter within 2 foot of any high voltage or mains potentials.
                                      You will need to know the inductance, the DCR of Primary and Secondary, the turn ratio, the power requirement, etc.
                                      http://www.coilcraft.com/ccfl.cfm
                                      • lookimback
                                        • Aug 2013
                                        • 1489
                                        So that counter would probably fry?
                                        Post #2 has turns of primary and secondary. Turn ratio would be 1:4.78
                                        DCR? If that's resistance, it's also in post #2.
                                        How do I determine inductance?
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
                                        • dennis_elx33
                                          3PHASE STEP-DOWN Transformer in Check
                                          by dennis_elx33
                                          Hello All,
                                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                          Problem statement: Power tripped Off
                                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                          Action Done:
                                          1) Replaced the faulty parts with good spare.
                                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                          12-02-2024, 06:52 AM
                                          ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 04:40 PM
                                          ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 12:00 PM
