Sharp T-Con LVDS Cable Connector - How to open
  • jstiene
    • Feb 2013
    • 148
    Hello.
    I have a Sharp LC-60LE640U and cannot seem to figure out the proper way to open and close the connector for this particular cable. Would someone know the proper way of installing this cable?
    Thanks for your help!
    Re: Sharp T-Con LVDS Cable Connector - How to open
    Please up load the pictures so we can see what we are dealing with.
    • jstiene
      • Feb 2013
      • 148
      Oh. I am sorry. Here is the picture I meant to upload.
      • jstiene
        • Feb 2013
        • 148
        Hi. Any suggestions on how to open and close this connector?
        • splitcrete
          • Dec 2012
          • 387
          • usa
          How about a picture of the other side of the board...
          • jstiene
            • Feb 2013
            • 148
            The cable is sitting disconnected it plus right into that connector. There is nothing on the underside of the board.
              Hmm, can I see the point of view of the slot for the cable to go in? It looks like the brown section needed to be push up (slide) on both ends by a very small amount.
              • bammbammfran
                • Apr 2014
                • 476
                If it has a slot like in the picture I attached, then the black part should slide out about 1/16 of an inch, then you slide in the flat cable and then slide the black clip back in.
                If your slot is on the bottom like my picture, the the pins on the ribbon will point down towards the board.
                If the slot is on the top side, then the pins would face up away from the board
                • anmol
                  • Mar 2012
                  • 73
                  • India
                  This may help you?
                  wbr
                  • jstiene
                    • Feb 2013
                    • 148
                    anmol,
                    Thanks for the help! That was the answer.
