HP M32f FDH Monitor: 12v missing after connect the LVDS ribbon cable to the LCD circuit
  • alfredomfr1
    • Oct 2014
    • 318
    • usa
    12v pin is shorted to ground in the LCD board (1st picture) if the LVDS cable is disconnected, 12v are OK in the Main Board (2nd Picture)
  • lotas
    • Jan 2016
    • 4760
    • Russia
    So, how can I help? You have a problem in the T-CON (short circuit at the 12v input), it could be ceramic capacitors or the DC/DC converter, disconnect the lvds cable and supply power from a lab power supply 8-10v (observing the polarity) and increase the current, see what will heat up (get hot), that will be your problem...
    • alfredomfr1
      • Oct 2014
      • 318
      • usa
      Thanks for the help I will try and let you know.
      • alfredomfr1
        • Oct 2014
        • 318
        • usa
        The Capacitor on the top of the board was shorted. Thanks for your help Iotas
        • lotas
          • Jan 2016
          • 4760
          • Russia
          Ok! Congratulations on the successful renovation.
          • edugimeno
            Help me identify the missing component... Sound to light circuit
            by edugimeno
            hI there!
            Im trying to help a friend repairing a large, real-sized short-circuit robot.
            This is remotely controlled and has a 2 way voice send/receive. Also while the hidden operator is talking, the red bulb inside the "mouth" should flash according to the sound
            Some other technician used to service it and he was fired leaving all the repairs unfinished and no documentation at all.
            What I found is a sound receiver, a speaker, and a wire directly to the mought bulb (a normal motorbike 5W 12V bulb).
            So I bought a simple 2X30W amplifier to feed the loudspeaker...
            02-14-2024, 10:23 AM
          • NolesFan
            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
            by NolesFan
            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
            10-24-2024, 06:36 PM
          • Scincidae
            UN70NU6900FXZA Won't Boot Unless I Temporarily Disconnect Right LVDS Ribbon
            by Scincidae
            I recently was given a UN70NU6900FXZA that would only boot loop once plugged in (auto powers on when plugged in). I found that disconnecting the lower (right side) LVDS ribbon, then plugging the TV in, followed by reconnecting the lower LVDS ribbon will allow the TV to work 100% normal as far as I can tell (no lines, no discoloration, no dimming or anything like that).
            I tried the tape method on the lower LVDS ribbon and found that if I cover pins 10 and 11 (counting from the bottom up) allows the TV to boot normal but 25% screen all the way to the right side is discolored. While...
            04-24-2022, 06:00 PM
          • wattage
            by wattage
            Hello Badcaps Community,
            07-13-2025, 04:41 PM
          • ant3202
            HP 27es - LED monitor - Monitor Flashing On - Off
            by ant3202
            Hi Everyone
            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
            https://www.badcaps.net/forum/troubl...lashing-on-off
            The monitor is HP 27es LED Monitor
            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
            The monitor will randomly blackout and display no signal and will recover again.
            Sometimes need to power and off again to restore the display but...
            03-20-2025, 07:30 PM
