LG 55LS4500 - T-Con or Panel?
    I have an LG 55LS4500 which I picked up for cheap because all it displayed was a black screen. The sound worked when hooked up to a source. In the lower left corner, there is a lighter patch which can be seen here:
    I pulled it all apart and managed to get some images to display by reseating the ribbon cables onto the T-Con board. When both the left and right ribbon cables are hooked up, I generally get a mess of lines which is shown here though sometimes I get the source image, albeit in negative colors.
    When I disconnect the left ribbon cable, leaving the right connected, the right side of the screen shows the source in negative with no lines (the left side is black).
    When the left ribbon cable is the only one attached, you get a similar display as when both are ribbon cables are connected (the right side is black). There are narrow lines that didn't turn up well in the picture.
    I know there a good chance the panel is at the fault. The only reason I haven't pulled it apart and parted it out is because of the weirdness of the T-con. If when only the right ribbon cable is connected, shouldn't you get half the screen perfectly instead of the inverted colors I get? Additionally, the T-con board get VERY hot when the unit is running for a just a few minutes; hot enough that it can definitely burn you if you touch it for more than a split second. There is no visible damage to the board though.
    In regards to the light patch on the bottom left side, the panel itself does not appear to be damaged, lines and pixels running through it fine, it just looks to be lighter for some reason. The lines change when the unit is left on but I think it is because of the T-con getting hotter; pressing on the side for of LCD panels does nothing, nor does slight twisting, moving the T-con board or attached cables, or anything else. The longer the TV is on, the worse it gets.
    Is it possible the panel is not the culprit and the T-con is in fact the problem Thanks for your help!
    -Alex
    Re: LG 55LS4500 - T-Con or Panel?
    99% panel.
    That splotch you will probably find is water damage. The tabs are on the bottom on modern panels, making them extremely vulnerable to water damage. Even just cleaning the screen without getting 100% of the water off the panel lip can damage a modern LED TV.
    Removing the ribbons pretty much confirms it. T-con drives both halves with same signal, so it cannot be at fault. The VCOM signal, however, is often generated on one panel side or another from an adjustment potentiometer or a pre-placed resistor network. If that's missing (on the missing side) you can get odd picture artefacts.
      Darn. Can't say I'm surprised though I was hoping I could something with this. Looks like I'll just salvage what I can. Thanks for your help!
        hello, for some reason i cant start a new thread, but i have lg 55ls4500 that has a picture, but sometimes with various colors flaring out from edges. i can adjust the flares out using advanced settings, but when you select a preset adjustment such as 'movie' , the flare outs come back. tried all inputs and doesnt seem to matter. when i first got the set you could see an image in background from a different input(ex hdmi input is faded in background when switching to av input).
        thinking it had to be the main board i replaced it, which seemed to improve the image retention( but can still see for a short time although much dimmer than before)
        i began looking a little harder at the power suppl board, and looks like all named voltages are ok, but i am not sure what voltage should be supplying the led panels at the top of the power supply board, right now its around 61V, which does seem a little low to me but just asking if anyone has seen similar problem? or what should those voltages be, is there a chart of typical voltages i can obtain?
          Screen shot of what you are seeing will help. You should be able to post your thread now, I believe.
