samsung ua55es6800 - no image
  • shlomim412
    • May 2018
    • 45
    • israel
    hi
    having problem with samsung ua55es6800
    tv had backlight on, sound working - responds to the remote control but no image.
    check tcon board - had 12v in but no other voltages present.
    when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
    when leaving only left side connected - again no voltages and no image.
    put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
    kept trying to block less pins on the left ribbon cable to try and get a good image
    now, suprisingly - getting complete rainbow vertical lines! also with no pins blocked on left ribbon
    both ribbons connected i get voltages but all the time random rainbow vertical lines (also when each half panel is connected, same for both left and right side)
    bad tcon? or did i bypassed the protection causing it fry due to a bad panel?
    how can i verify that the panel is toast if that is really the case?
    thanks in advance!
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4835
    • Italy - Milan
    Hi, the panel has got vertical side cof, if i recall, it is highly recommended that you set apart the screen bezels and inspect with magnifier each side cof, especially back green side, check if there is a gap between the enameled green area and the screen joint.. further details in private.. wait patiently, you can also try to apply hot air to those cof and watch if it improves, only for testing purpose, not a fix.. bye
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Boardview and Schematic Bot
      09-07-2024, 05:50 AM
    • Bloopeta
      Samsung UE55JU6800K No Picture
      by Bloopeta
      Samsung UE55JU6800K with no image on screen.
      I have had this TV many years without fault, however aprox 6 months ago I fitted a new set of backlights as some of the lens caps had fallen off.
      Was working fine, until 3 days ago, when watching TV the screen just went blank (still illuminated)
      I turned the TV off and left it around 12 hours, and when turned it on again it seemed to work perfectly again. After around 45 mins the screen went blank again.
      Left it off overnight and turned it on, and the Smart TV logo came on as normal, then screen went blank.
      05-03-2024, 10:42 AM
    • snirsnir
      Samsung QE65Q67AAUXXH (65" QLED) - Bootloop, no logo, no hot components found
      by snirsnir
      I have a Samsung QE65Q67AAUXXH (2021 QLED, 65").
      Panel: CY-QA065HGSV1H
      Main board: BN41-02844A (BN94-16448X) - T-CON integrated, no separate T-CON board.
      SYMPTOMS:
      - Immediate bootloop on power-on - backlight flashes on for ~1 second then shuts off, repeats endlessly.
      - No Samsung logo, no picture at any point.
      - Sound never plays.
      WHAT I'VE DONE SO FAR:
      1. Disconnected both 90-pin ribbon cables from mainboard → TV powers on, backlight stays on steady. No bootloop. Confirmed mainboard and PSU...
      04-23-2026, 06:10 AM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
