    • Nov 2024
    • 54
    I got the TV taken apart again. The plugins that were attached to the new LED strips got ripped off because of the tight wires.
    I'm going to order some new ones and when I install those, I'm going to remove the tape from the LED strip wires throughout the chassis until I can get slack on the wires and tape them down again.
      • Nov 2024
      • 54
        • Nov 2024
        • 54
        Both sides were pulled out.
        • x_orange90_x
          • May 2015
          • 727
          Those are the plugs on the new LED strips?? If so you don't ORDER new ones, you tell the seller to give you refund or replacement! That should not happen unless the solders are very poor quality, which I've read does happen.
            • Nov 2024
            • 54
            Yes these are from the new ones. I think the solders were very poor quality.
            You think I can get them to get me a replacement ?? That would be great so I don't have to spend money on another set.
            • x_orange90_x
              • May 2015
              • 727
              Absolutely! Send them that picture and tell them the connectors pulled off the strips. These are so cheap to manufacture that they more than likely will just send you a refund or replacement without even asking for you to skip them back. It costs more to ship then back than they are worth.
              Do you think they were poorly soldered from the get go, or do you think maybe you put too much tension on them? I would expect the strips to flex before the solders would break. If you feel they were too cheaply soldered, and you obviously are going to need replacements anyway, maybe consider asking for a refund and purchasing from a different seller. It's still possible that you'd end up getting the same ones even from a different seller because these Chinese sellers have multiple eBay stores under different names and compete with their own listings over mere pennies. It may be worth a shot in order to possibly get better quality.. But then again, if you just get offered replacements and give the slack needed on the wires you'd probably be fine anyway.
                • Nov 2024
                • 54
                I think both, I think the tension was too much for the weak solder. That wiring was pretty tight.
                Yeah I'm just going to get replacements and get some slack on the wiring.
                  • Nov 2024
                  • 54
                  Seller wants me to pay him $10 to ship me replacements.
                  • x_orange90_x
                    • May 2015
                    • 727
                    Get a refund and order from someone else. That's what I'd do. Make sure when you leave this seller feedback that you say you needed replacements and they wanted to charge you for it.
                    Edit:
                    I don't know which strips are in your TV as I see a few different part numbers available. But check these out and if they're correct I'd suggest ordering from this seller. If they're not right see if you can find the right ones sold by them. They've been great about refunds and shipping me replacements for free when I've ordered the wrong ones. I've probably ordered from them a half dozen times or so for various different tv models.
                    The store name is "Besttoolshop"
                    https://www.ebay.com/itm/27619790001...mis&media=COPY
                      • Nov 2024
                      • 54
                      Okay guys sorry for the wait...
                      The seller I bought the first set of strips from tried to send me replacements but they got lost during shipping.
                      I got a refund and bought another pair, but one of the plugins came disconnected from the LED strip during packaging I assume. Click image for larger version
                      I really don't want to go through another waiting period of sending these back and getting new ones replaced and I don't want to spend money on anymore.
                      Couldn't I just solder it back on ? If so, what kind of soldering gun kit could I buy from Amazon to do it with ?
                        • Nov 2024
                        • 54
                        Ok, I have a solder gun but I need solder wire. Click image for larger version
                        Is there a specific size of wire I need ?
                        Will I need flux ?
                        • EazyBone
                          • Jun 2023
                          • 1351
                          • United states
                          #72
                          Yes of course flux. And small electronic solder wire. Small size as it's a tiny pad. This doesn't look like it's going to be easy.. since there is 5 pads and honestly I would of sent them back. If your are new to solder the chances of this pulling through is going to be very small.
                          • lotas
                            • Jan 2016
                            • 4672
                            • Russia
                            #73
                            This connector still needs to be soldered correctly; if it is turned 180* degrees, the backlight will not work.
                            • x_orange90_x
                              • May 2015
                              • 727
                              I got a refund and bought another pair, but one of the plugins came disconnected from the LED strip during packaging I assume. Click image for larger version  Name:	IMG_20241231_101738482.jpg Views:	19 Size:	2.63 MB ID:	3538720
                              Orientation shouldn't be a problem if you compare it to the original strip you took out. As for soldering it back on it looks entirely plastic so I don't think it CAN be. What is more likely is that it is glued on. I would plug the wire into the connector like it's supposed to be and then try to carefully push the connector onto the pins of the strip if you can line them up properly. If it slips back on flush, leave it in place and connect the probes of your LED tester to the WIRES coming out of the back of the plug. If it lights up the strip then you'll know it's on correctly and makes good contact. At that point you can super glue/hot glue the connector in place.
                              Edit: your picture doesn't really represent the situation clearly, so perhaps I'm not seeing it correctly. If those are in fact solder pads then soldering it would be quite tricky. Perhaps gluing it in place will make enough contact. You really should take this up with the seller tho. I've bought two different sets of edge lighting with these style connectors and neither one came damaged or pulled off. I'll bet it was the same seller under a different name. The Chinese sellers are good for that.
                                by sam_sam_sam
                                After all of...
                                07-13-2024, 08:14 PM
                              • Soulzink
                                Samsug washing machine. Power supply DC41-00189a board issue
                                by Soulzink
                                I am trying to fix a samsung washinmachine power supply main board.
                                I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                The power supply board reference is the following: DC41-00189a
                                I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                04-19-2025, 06:26 AM
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • Nicktronic
                                Samsung Power Supply Board BN44-00874F
                                by Nicktronic
                                Hey everyone,
                                This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                Anybody...
                                03-17-2025, 06:20 AM
                              • penangit
                                Hp v193 monitor power supply board
                                by penangit
                                Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                                I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                                I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                                Steps taken so far:
                                Checked all...
                                02-21-2023, 04:00 AM
