I was wondering if anyone else has come across this problem. What was the problem?, and was it solved. I recently picked up 2 of these tvs and both initially diagnosed as bad backlights. When turned on, the backlights flash the red logo screen. Sound and an image is clear using a flashlight. So I buy 2 sets of leds. When they arrive I take one tv apart and test the leds before removing them. OMG they all work. but I put the new ones in anyway. So I think its the power supply. I swap PS from one to the other and same results. Now here is the issue and really confused me. I reset the tv using the reset button on the main board. Tv went into recovery mode. Backlights are on and stay on while I go through all the steps. Tvs says updating and I think its done. Tv restarts, I get picture, sound and backlights like normal, then backlights shut down. I'm back to original issue. Need help or explanation of whats happening. TIA
TCL 43S431 Backlight issue or Power Supply
Tags: None
I have same problen with one like you ... don't think it is your power supply or your leds either. I picked up a free TCL 43S446 get standby light and works without backlights turning on ... but no power to leds. Ordered another power supply and was garbage didn't even get any standby light .. so put original back in. Than went and ordered a LED replacement strip .. same thing as original .. and still no backlight on power tv on. At this point It has be something like bad circuit on the panel. I have not went back to it yet. I think all these models are suffering from the same flaw.
Power Supply: 08-L12CLJ1-PW200AA
Know Models:
43S434
43S435
43S433
43S446
43S431
IPS Panel: T430QVN03.M
Main Board: TCL 30800-000328 - 40-R51MTA-MAA2HG; 11602-500227
No T-Con Board​Comment
NO..
the red socket which it go to Mainboards .. here are the BL_ON and power _ON... search on yours Power boards you will find Print Chart describe this socket wiring by Number and name , if the chart not on top look at the downside of the boards...
you should 100% sure of the Pins location., other wise you could damage the PSUComment
So I tried to get the backlights to turn on by jumping the 2 pins with a 1kR. The P_ON and the Bl_ON pins are charted on the back of the Mb. When turned on, the logo screen appears for 15 seconds (I timed it) and then the backlights go out. No backlights but sound and image still present. I also think the problem is with the main board not sending the signal after initial startup. There are a few MB on Ebay for less than $25, so I'll try one.Comment
did you reemove the BL_ON wire from the power board socket before jumping the two pins togetherSo I tried to get the backlights to turn on by jumping the 2 pins with a 1kR. The P_ON and the Bl_ON pins are charted on the back of the Mb. When turned on, the logo screen appears for 15 seconds (I timed it) and then the backlights go out. No backlights but sound and image still present. I also think the problem is with the main board not sending the signal after initial startup. There are a few MB on Ebay for less than $25, so I'll try one.Comment
some things wrong you did... maybe you jumber other one.. no reason to stay on 15 seconds unless the LED defect
show us the print chart of the socket on power boards
also with reference TV Chassis measure the red wire of LED+ at time you plug the tv in wall... mark the high and low V you will haveComment
It was the power supply. I bought a repair kit from ShopJimmy ( $38) which included the main board, PSU and T con. 1st tv fired right up and stayed on. I put the original MB back in and tv turned on and everything is ok. I repeated this on the 2nd tv and the results were the same. Unfortunately, the second screen had a vertical line down the right side. So out of 2 free tvs, I got one to work for 38 bucks.Comment
So I finally got around to 3 of these TCL 43S446-CA tv's I had picked up for free over the past year. People were dumping them. Seems these models all have cheap power supply problems with diodes. After wasting 20 bucks on a Power Supply: 08-L12CLJ1-PW200AA that was sent to me and was garbage I saw a video on youtube that was similar ... showing the bad diodes beside the backlight plug that were likely the problem. Like handsworth said all it is is the power supplies. I bought 20 SB540 diodes for 4.00 and replaced 1 SB540 diode on all 3 power supplies and now all 3 tv's work lol
One of the tv screens has an issue though ... does not look like burnt pixels but more like bad integrated t-con on mainboard or maybe bad screen? Anyone have any thoughts before I tinker with it? You can see near top left a square black block, and near bottom right same thing a black block. The rest of the screen is ok. I've tried to add the best pics I could of the screen on. Any tips appreciated Thanks allAttached Filesif you find these attachements useful please consider making a small donation to the site
Ya thanks tiki, eazy ..is weird why someone watched this tv with 2 black squares on the screen lol ... It seems there is some tape or something behind the screen .. even though I can tell the tv has never been taken apart. A lot of these 2020 to 2023 tv's are all COVID tv's so probly built as garbage and some sucker bought it from Costco, Best Scam Buy, WalFart, Amazon Prime Crap deal etc on sale. So guess my next step is to pop the screen off and see what is actually behind it. I will report back soon with the results.Comment
So 3 months later I finally got around to pulling the screen of the TCL 43 inch with the 2 black spots. Turns out was my fault lol. I have never touched these small cheap brittle plastic models before and when I had the bezel off and the screen lifted out to check the led strip ... two tiny plastic square clips from the bezel had fallen in behind the screen onto the diffuser. There was enough of a static charge in the plastic that they just hung on to the plastic diffuser sheeting. I took them out and now is perfect picture and thank god was not dead pixels in the panel. Gee my dumb arse is learning the hard way lolComment
I have fixed about 5 of these tvs by just replacing the PS. Yes, people just throw the tv out. I just found another one 43S431 and came back to read because now used PS are going for around $30-$40. Tech9pc hit it on the head. Here's a video that he referenced and saved some good $$. I ordered the diode from Amazon, got it next day, resoldered and tv fired right back up. I hope this helps.So I finally got around to 3 of these TCL 43S446-CA tv's I had picked up for free over the past year. People were dumping them. Seems these models all have cheap power supply problems with diodes. After wasting 20 bucks on a Power Supply: 08-L12CLJ1-PW200AA that was sent to me and was garbage I saw a video on youtube that was similar ... showing the bad diodes beside the backlight plug that were likely the problem. Like handsworth said all it is is the power supplies. I bought 20 SB540 diodes for 4.00 and replaced 1 SB540 diode on all 3 power supplies and now all 3 tv's work lol
https://www.bing.com/videos/rivervie...86&FORM=VRDGARLast edited by handsworth; Today, 04:48 PM.Comment
Assuming...7 Photos -
by cheebsterHello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
Anyone... -
by AcnologiaHello to all members of badcaps.
Another brainstorming that i have been messing with for months as a side project.
Bought a T540p , from eBay as 'doesn't display' ,so i thought it was either backlight fuse, or screen issue etc.
I got it in my hands, first thing, the machine works fine boots to windows , in external screen all diagnostic are good.
Step 1.
Change screen (FAT - LED ) 1366x768 to 2nd one, that i know 1000% that is working ,as it has been tested.
Machine > Doesn't give display it's really dim.
Step 2.
Use the same... -
by phuzzydayThis was my initial thread.. https://www.badcaps.net/forum/troubl...-m-at-wits-end
(All the Electrolytics are brand new.)
I started a new one, hope that's ok, because my question is different now! (Strangely enough, after I walked away for a few weeks, it stopped lighting up at all!!)
I am determined to fix this power supply because I have the skills to replace bad components, I just need to find out... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
