TCL 43S431 Backlight issue or Power Supply
  • handsworth
    • Oct 2015
    • 175
    I was wondering if anyone else has come across this problem. What was the problem?, and was it solved. I recently picked up 2 of these tvs and both initially diagnosed as bad backlights. When turned on, the backlights flash the red logo screen. Sound and an image is clear using a flashlight. So I buy 2 sets of leds. When they arrive I take one tv apart and test the leds before removing them. OMG they all work. but I put the new ones in anyway. So I think its the power supply. I swap PS from one to the other and same results. Now here is the issue and really confused me. I reset the tv using the reset button on the main board. Tv went into recovery mode. Backlights are on and stay on while I go through all the steps. Tvs says updating and I think its done. Tv restarts, I get picture, sound and backlights like normal, then backlights shut down. I'm back to original issue. Need help or explanation of whats happening. TIA
  • vinceroger69
    • Mar 2012
    • 6714
    which mainboard is used in this set i wonder if its turning the backlight signal/voltage off
    • handsworth
      • Oct 2015
      • 175
      The PS is the same but the MB are different. As of now, both tvs are at initial setup like right out the box. No backlights but both tvs have sound and image.
      • tech9pc
        • Sep 2021
        • 50
        I have same problen with one like you ... don't think it is your power supply or your leds either. I picked up a free TCL 43S446 get standby light and works without backlights turning on ... but no power to leds. Ordered another power supply and was garbage didn't even get any standby light .. so put original back in. Than went and ordered a LED replacement strip .. same thing as original .. and still no backlight on power tv on. At this point It has be something like bad circuit on the panel. I have not went back to it yet. I think all these models are suffering from the same flaw.
        Power Supply: 08-L12CLJ1-PW200AA
        Know Models:
        43S434
        43S435
        43S433
        43S446
        43S431
        IPS Panel: T430QVN03.M
        Main Board: TCL 30800-000328 - 40-R51MTA-MAA2HG; 11602-500227
        No T-Con Board​
        • Diah
          • Feb 2013
          • 6580
          you can slide out the BL_ON wire from the power boards socket... and jumper the pins of it in the socket via 1KR to Power_on pins... when the BL come on keep this DIY. because yours MB didn't sent this signal anomaly
          • tech9pc
            • Sep 2021
            • 50
            Hi Diah thanks for all your input. Do you mean the Red wire is BL_ON? and jumper it to where? with a 1KR? is that a 1 K Ohm Resistor? .. sorry dumb here lol ... just an amateur. Appreciate your expertise.
            • EazyBone
              • Jun 2023
              • 1362
              • United states
              Also test these and see if there is continuity on any, and test resistance if there isn't. There shouldn't be.. but let's see. I fixed one recently with this issue. Not exactly the same so test this while doing diahs suggestions.
              • Diah
                • Feb 2013
                • 6580
                NO..
                the red socket which it go to Mainboards .. here are the BL_ON and power _ON... search on yours Power boards you will find Print Chart describe this socket wiring by Number and name , if the chart not on top look at the downside of the boards...
                you should 100% sure of the Pins location., other wise you could damage the PSU
                • tech9pc
                  • Sep 2021
                  • 50
                  OK I see what you mean now .. looked at the board pins like you said Diah. Thanks for the tips and suggestions all. I will try this when I get a chance. I will have to research it a bit before I attempt it .. skills are not very good lol.
                  • handsworth
                    • Oct 2015
                    • 175
                    So I tried to get the backlights to turn on by jumping the 2 pins with a 1kR. The P_ON and the Bl_ON pins are charted on the back of the Mb. When turned on, the logo screen appears for 15 seconds (I timed it) and then the backlights go out. No backlights but sound and image still present. I also think the problem is with the main board not sending the signal after initial startup. There are a few MB on Ebay for less than $25, so I'll try one.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      did you reemove the BL_ON wire from the power board socket before jumping the two pins together
                      • handsworth
                        • Oct 2015
                        • 175
                        yes I did
                        • Diah
                          • Feb 2013
                          • 6580
                          yes I did
                          some things wrong you did... maybe you jumber other one.. no reason to stay on 15 seconds unless the LED defect
                          show us the print chart of the socket on power boards
                          also with reference TV Chassis measure the red wire of LED+ at time you plug the tv in wall... mark the high and low V you will have
                          • handsworth
                            • Oct 2015
                            • 175
                            It was the power supply. I bought a repair kit from ShopJimmy ( $38) which included the main board, PSU and T con. 1st tv fired right up and stayed on. I put the original MB back in and tv turned on and everything is ok. I repeated this on the 2nd tv and the results were the same. Unfortunately, the second screen had a vertical line down the right side. So out of 2 free tvs, I got one to work for 38 bucks.
                            • tech9pc
                              • Sep 2021
                              • 50
                              So I finally got around to 3 of these TCL 43S446-CA tv's I had picked up for free over the past year. People were dumping them. Seems these models all have cheap power supply problems with diodes. After wasting 20 bucks on a Power Supply: 08-L12CLJ1-PW200AA that was sent to me and was garbage I saw a video on youtube that was similar ... showing the bad diodes beside the backlight plug that were likely the problem. Like handsworth said all it is is the power supplies. I bought 20 SB540 diodes for 4.00 and replaced 1 SB540 diode on all 3 power supplies and now all 3 tv's work lol
                              One of the tv screens has an issue though ... does not look like burnt pixels but more like bad integrated t-con on mainboard or maybe bad screen? Anyone have any thoughts before I tinker with it? You can see near top left a square black block, and near bottom right same thing a black block. The rest of the screen is ok. I've tried to add the best pics I could of the screen on. Any tips appreciated Thanks all
                              • tiki66
                                • Jul 2016
                                • 63
                                • Croatia
                                Looks to me like it's some garbage under screen
                                • EazyBone
                                  • Jun 2023
                                  • 1362
                                  • United states
                                  Agree, looks like a piece of paper or tape for in-between the screen and the light diffuser.
                                  • tech9pc
                                    • Sep 2021
                                    • 50
                                    Ya thanks tiki, eazy ..is weird why someone watched this tv with 2 black squares on the screen lol ... It seems there is some tape or something behind the screen .. even though I can tell the tv has never been taken apart. A lot of these 2020 to 2023 tv's are all COVID tv's so probly built as garbage and some sucker bought it from Costco, Best Scam Buy, WalFart, Amazon Prime Crap deal etc on sale. So guess my next step is to pop the screen off and see what is actually behind it. I will report back soon with the results.
                                    • tech9pc
                                      • Sep 2021
                                      • 50
                                      So 3 months later I finally got around to pulling the screen of the TCL 43 inch with the 2 black spots. Turns out was my fault lol. I have never touched these small cheap brittle plastic models before and when I had the bezel off and the screen lifted out to check the led strip ... two tiny plastic square clips from the bezel had fallen in behind the screen onto the diffuser. There was enough of a static charge in the plastic that they just hung on to the plastic diffuser sheeting. I took them out and now is perfect picture and thank god was not dead pixels in the panel. Gee my dumb arse is learning the hard way lol
                                      • handsworth
                                        • Oct 2015
                                        • 175
                                        I have fixed about 5 of these tvs by just replacing the PS. Yes, people just throw the tv out. I just found another one 43S431 and came back to read because now used PS are going for around $30-$40. Tech9pc hit it on the head. Here's a video that he referenced and saved some good $$. I ordered the diode from Amazon, got it next day, resoldered and tv fired right back up. I hope this helps.
                                        https://www.bing.com/videos/rivervie...86&FORM=VRDGAR
