Vizio E470VL backlight circuit sensitivity
    Re: Vizio E470VL backlight circuit sensitivity
    Do the lamp ends have metal cap on it? If I remember correctly, it is not CCFL, I just do not remember the name of it right now, it is another type fluorescent that uses different electrode ends, they can be connected in parallel with out having ballast cap per lamp.
    OK, I found some info, they may be EEFL (used in LC470 series panel).
      Info about CCFL, EEFL.
      • ecking767
        • Oct 2009
        • 492
        Originally posted by Taterbug
        I took off the LCD screen and the White plastic cover where I could observe all of the lamps real close. I found the problem one of the lamps was starting to flicker just slightly and could only be noticed with the white plastic screen removed. I removed the lamp and that solved the problem of the backlight shutting down. Now to find a replacement lamp. Does anyone know a source where I can buy a single lamp? I would replace all of them but have already spent a ton on this set. I am planning on just replacing the single lamp for now and keep the TV and watch it a while to make sure everything is ok.
        http://www.ernestos-electronics.com/...-4mm-x-1074mm/
        these are from a Vizio 47" TV
          I am not so sure about buying used lamps unless you have no choice.
          • ecking767
            • Oct 2009
            • 492
            at $5.75 a lamp isn't bad and he will have back up lamps just in case another fails.
            • tibimakai
              • Jan 2012
              • 3680
              http://www.ccflwarehouse.com/ccfllamps.html
              • Taterbug
                • Dec 2013
                • 114
                Finally got the backlight working by replacing one of the bad backlight lamps. Now it does not shut down but I have a new problem. In the attached photo you will see all these lines in the screen that was not their before.. Any ideas what would cause this???
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5037
                  • New Zealand
                  #28
                  Check the signal cables to the panel are connected properly.
                  It's also possible you damaged the panel or drivers when replacing the backlights. Unfortunately if this has happened it is not fixable.
                  -David VanHorn
                  • Taterbug
                    • Dec 2013
                    • 114
                    Unfortunately when I was moving the LCD Panel as I was setting it down I chipped a very small nick in the corner . Will have to put this one aside until I can find a new panel.
                    • Anthony M
                      • Apr 2017
                      • 14
                      • Usa
                      #30
                      Can someone tell me the size of the bulbs.
                      • Bugman1400
                        Vizio E470VL got +5VSB, but no 12V
                        by Bugman1400
                        EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
                        +5VSB= +5.09
                        12V= +12.18
                        PS_ON= +2.25
                        I_ON/OFF= +3.27
                        LAMP= +3.18
                        DIM= +2.97
                        Any more testing I can do on Main board or is it just a replacement?...
                        09-04-2022, 09:19 AM
                      • Astonished
                        Fixing the Charge Circuit of the Batteries of the DC Motor
                        by Astonished
                        Hi friends of electronics
                        What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                        The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                        Please help me fix this circuit.
                        (the datasheet of the IC: https://pdf.datasheet.live/28...
                        01-28-2025, 06:24 AM
                      • SS454
                        vizio e650i-a2 backlight flashes then turns off
                        by SS454
                        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                        panel: au optronics T650HVN05.4
                        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                        https://www.shopjimmy.com/vizio-56-0...-power-supply/
                        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                        08-20-2020, 03:57 PM
                      • mrtek
                        Vizio M65-C1
                        by mrtek
                        Hi.
                        picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                        When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                        This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                        07-14-2025, 07:28 PM
