Vizio E470VL backlight circuit sensitivity
  • Taterbug
    • Dec 2013
    • 114
    I have been working on an Vizio E470VL for months and it is driving me crazy that I can't fix it. I plays for just a few minutes (5 at the most) then the back light shuts down. Every time I loose the lamp voltage going to the PS board. I have replace the power supply board and also have replaced the main board THREE times and still having the same problem. Last night I went as far as to tear the whole thing down and remove the LCD screen and examined the Backlight lamps and associated wiring looking for arc spots. I did find one small spot next to the connector on the circuit board that holds the lamps. I cleaned that spot and insulated it thinking it would cure the problem. The spot was very very small about the size of a pin head. I reassembled everything and still have the problem. I found a new set of cables on e-bay that I ordered. This is about the only thing left that has not been replaced. I ohmed out the lamps to gound using a VOM on megohm range and could find no shorts to ground. Is their anyway to make the Lamp feedback circuit less sensitive? Or do you think it could possible be a bad cable? I should get the cables in a couple of days and that will eliminate that problem. I have also just installed a new eprom on the new main board I received just to double eliminate that problem. Anyone else had this problem???
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: Vizio E470VL backlight circuit sensitivity
    Is the inverter on the power supply? Can we see some pictures? It sounds like you may have one or more cfls that are taking more amperage than the inverter likes then it shuts them off. Shopjimmy shows about 4 different power boards used in this model. Which does your tv have? If it will turn on with the screen removed you can check for dim bulbs, or ones with black stripes around the end.
    Sometimes it is just better to move on for a bit and come back to it later. Ive got a Samsung that wont keep the backlights on for more than a few seconds, waiting for another cracked screen to come in with compatible bulbs as I cant get enough matching tubes to make the balancer happy.
    Liberating magic smoke one part at a time
      • 31198
      what do the tubes look like?
      if they are ice-white with silver ends they are new,
      if they are white with darkened ends they are old,
      if they look a bit yellow and the coating looks powdery instead of smooth they are done.
        "I ohmed out the lamps to gound using a VOM on megohm range and could find no shorts to ground" The meter cannot put out 2000V to simulate the high voltage than can cause high voltage break down.
        I agree that you may have bad lamps, or still arcing some where.
        • Taterbug
          • Dec 2013
          • 114
          The bulbs look white and it has a beautiful picture when I can get it to play. I tore it back down and double checked for more arc spots and did not see any. If the cables that I've got coming don't fix it then I will just hold on too it until I can find one with a cracked screen. Thanks.
            • 31198
            how many tubes does it use?
            is it edge-lit or back-lit?
            • Taterbug
              • Dec 2013
              • 114
              Here is a photo of the backlights...
                So when you turn it on right now, you do see ALL the lamps light up, right?
                BTW, which version of this model do you have? The one with power supply-inverter combo board? Or the one with separate power supply, inverter board.
                LCD panel model number?
                  • 31198
                  10 tubes - damn that's gotta generate some heat!
                  • pongagt
                    • Apr 2014
                    There are 20 tubes and my VO420E has 18 tubes.
                    • Taterbug
                      • Dec 2013
                      • 114
                      All the lamps DO light up. I have the model that has the PS and inverter board combined. I have replaced this board as well as the main board ( twice ). I did find some arc spots underneath the boards that the lamps are connected too. I cleaned these areas and reinsulated with electrical tape. Still same problem!! Waiting on cables to arrive but this really has me stumped. Plays at most two or three minutes before I loose lamp signal shutting down back lights. ?????
                      • audiofreak19
                        • Apr 2013
                        • 556
                        • usa
                        Do all of the ccfl bulbs light up to the same brightness. If one is duller then the others it means its on the way out. That could be the only thing I would think since you have replaced the main and power board multiple times. Does your model have the t con built into the screen or is it a separate board? If it's separate or I guess even fixed if for some reason there is a fault in the t con and it shuts down and looses the video signal it will shut the backlights off.
                        • audiofreak19
                          • Apr 2013
                          • 556
                          • usa
                          When the tv backlight turns off can you still shine a light behind it and still see a picture. That would eliminate the t con and panel.
                            • 31198
                            i know it looks like 20,
                            i assumed it was using "U" shaped tubes or it would need twice as many invertor outputs.
                              Are there any small blue caps on the board where the lamps are connected to?
                                OH, and the LCD panel model number?
                                • Taterbug
                                  • Dec 2013
                                  • 114
                                  All the lamps light equal. Tcon combined with main and no caps on boards. Should have new cables by Tuesday. If that don't fix it then I will set it aside until I find one with a broken screen and use for parts.
                                  • Taterbug
                                    • Dec 2013
                                    • 114
                                    I took off the LCD screen and the White plastic cover where I could observe all of the lamps real close. I found the problem one of the lamps was starting to flicker just slightly and could only be noticed with the white plastic screen removed. I removed the lamp and that solved the problem of the backlight shutting down. Now to find a replacement lamp. Does anyone know a source where I can buy a single lamp? I would replace all of them but have already spent a ton on this set. I am planning on just replacing the single lamp for now and keep the TV and watch it a while to make sure everything is ok.
                                    • audiofreak19
                                      • Apr 2013
                                      • 556
                                      • usa
                                      Ccflwarehouse.com
                                      • Taterbug
                                        • Dec 2013
                                        • 114
                                        • Bugman1400
                                          Vizio E470VL got +5VSB, but no 12V
                                          by Bugman1400
                                          EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
                                          +5VSB= +5.09
                                          12V= +12.18
                                          PS_ON= +2.25
                                          I_ON/OFF= +3.27
                                          LAMP= +3.18
                                          DIM= +2.97
                                          Any more testing I can do on Main board or is it just a replacement?...
                                          09-04-2022, 09:19 AM
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
