Vizio E422VA not turning on
  • tibimakai
    • Jan 2012
    • 3680
    The previous owner said that they had a storm and right after the storm the TV would not turn on anymore. Most likely a surge.
    I have manged to force the PS on and it's all good there, backlight turns on, all the voltages are there.
    If I lug in the mainboard connector, the standby voltage is pulled down to 2.59V.
    Can I find the problem component on the mainboard, or I should just get a another one?
    A thermal fuse how should show on the meter, mine shows 0.5 ohm.
    Any ideas would be appreciated.
    This would be the mainboard(picture from shopjimmy):
    http://www.shopjimmy.com/media/catal...acb5k00503.jpg
    • 30978
    Re: Vizio E422VA not turning on
    fix it.
    trace the standby voltage and see what it connects to.
    it's probably not much.
    • tibimakai
      • Jan 2012
      • 3680
      I have found a voltage regulator type of component(three pins on one side and two on the other) and the markings are EKAON.
      I can't find anything about it, on the net.
      Pin #3 and #4 have short, I don't know if it's OK or not though.
        • 30978
        foto?
        • tibimakai
          • Jan 2012
          • 3680
          The two pins marked with small orange arrows show 2.59V(short with Ohm meter). They also seem like, input and output pins to me.
          I have replaced a couple days ago a very similar component on a Sony TV which it was a voltage regulator that had a control ON/OFF function as well. It was regulating 5v to 3.3V. Maybe it's the same part?
          Here it is:
            • 30978
            could be a regulator.
            can you remove it cleanly?
            • tibimakai
              • Jan 2012
              • 3680
              Yes, I can. What should I do after that?
                • 30978
                see if the short is on the part, or the pcb.
                • tibimakai
                  • Jan 2012
                  • 3680
                  I have removed it and the voltages did not change, so there is something else then, but there are not to many components around there to go bad.
                  The main processor is warming up also. What if it's damaged already?
                    • 30978
                    you didnt anser the question.
                    was the part you removed shorted, or was the short still on the board?
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I haven't measured the part, but after removing the part, there it was still 2.6V at both pads.
                      Most likely something else is pulling down the voltage.
                      Could be one of the capacitors?
                        • 30978
                        could be anything,
                        but you still need to check the part & pads on the board.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Finally I have found a mainboard for $109.
                          I have installed it expecting the TV to turn on and be OK.
                          To my surprise, nothing happened.
                          I'm measuring the standby 5V and it drops with this board to as soon as I connecting it.
                          If I unplug it, it shows 5.1V.
                          If I force the PS to turn on, it turns on and backlight stays on as it should.
                          I really need some help here.
                          Not sure, what to make of this one.
                          The second mainboard, to have the same issue, it's almost impossible.
                          TV went bad, after a storm.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            Nobody has any ideas?
                            • audiofreak19
                              • Apr 2013
                              • 556
                              • usa
                              Well either the main board you got is bad or it's not in the main board. If your standby voltage isn't up to spec then I would bet its one of the voltage regulators in the main board.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I have purchased it from tvpartsguy and they guaranty that the board is good, but I will contact them about this, though.
                                What is weird, that how come both boards show the same exact symptom?
                                • audiofreak19
                                  • Apr 2013
                                  • 556
                                  • usa
                                  There is a short or bad regulator I think in both of them. If it drops when plugged in. Then there is a bad regulator most likely
                                  • Ltank
                                    • Jun 2013
                                    • 776
                                    Let see if i got this right. The PS 5stby is 5 or 5.1 vdc with no main board connected.
                                    You replaced the main board and it, too loads down the 5vdc stby. What was the resistance on the main board pin in reference to chasis ground? It should be at least several hundred ohms as not load down the PS. If the PS is loaded down easily then the regulator on the PS 5vdc circuitry is the problem. Th check what resistance is bad take these steps. measure the main board reisistance on that pin referenced to chasis gnd.
                                    That would be the low end of your test. Get a vaiable resistor (POT) at least double that resistance and load the PS while measuring the voltage. When that voltage drops, remove power and check the resistace on the pot. It will give you and idea when it starts breaking down and confirm the problem is in the PS
                                      Try using 5 Ohms 10W as the load to simlulate 1A of current draw on the 5V line to see if it can handle 1A load, I do not know the spec of the 5VSTBY, but it should be able to provide 1A @5VDC at least.
                                      • hienton2
                                        • Sep 2009
                                        • 183
                                        Have an good external 5v. connect to 5v in of main board .see it load down the 5v?. then use p.on of mainboard to turn on the power supply . I hope it works.
                                        Must have good ground connection. external and tv
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • pedromvu
                                          Vizio M65-E0 not turning on
                                          by pedromvu
                                          Hi, I know these TVs are common to have problems like this, but unfortunately I was not able to find repair guide for this specific model or for something with this kind of power board.
                                          The thing is this doesn't have the 5vsb pin which is used to determine from which board the issue comes.
                                          Everything in power and main board was inspected without any apparent problems, but haven't measured everything.
                                          The voltages from Power to Main board are as follows:
                                          NC = 0
                                          A = 0
                                          BL_on/off = (Some millivolts, probably considered 0)...
                                          11-18-2022, 12:28 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • howardc64
                                          Vizio SmartCast TV software bug that looks like hardware
                                          by howardc64
                                          Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                          It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                          11-16-2024, 05:17 PM
