Vizio M65-E0 not turning on
  • pedromvu
    • Nov 2022
    • Mexico
    Hi, I know these TVs are common to have problems like this, but unfortunately I was not able to find repair guide for this specific model or for something with this kind of power board.
    The thing is this doesn't have the 5vsb pin which is used to determine from which board the issue comes.
    Everything in power and main board was inspected without any apparent problems, but haven't measured everything.
    The voltages from Power to Main board are as follows:
    NC = 0
    A = 0
    BL_on/off = (Some millivolts, probably considered 0)
    PS_on/off = 2.9
    Gnd = 0
    Gnd = 0
    Gnd = 0
    Gnd = 0
    18vsb1 = 18.7
    18vsb1 = 18.7
    18vsb2 = 18.7
    18vsb2 = 18.7
    The only difference when Power board is not connected to Main board is that PS_on/off = 0 and BL_on/off = 0
    The TV does make a click when connecting the power, but there is nothing, no led nor click when tapping the power switch
    Since I couldn't find anything bad I was just trying to figure if I would need to replace the Main board vs the Power board
  • pedromvu
    • Nov 2022
    • Mexico
    Re: Vizio M65-E0 not turning on
    Just wanted to report in the end I bought a replacement Main board since it was the more suspicious one based on the voltage tests.
    Replaced the part, forgot to recheck the voltages though since first we checked if it turned on and it did.
    So TV is working as normal now, just lost all the configurations, so need to recalibrate image, etc.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • mrtek
      Vizio M65-C1
      by mrtek
      Hi.
      picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
      When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
      This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
      07-14-2025, 07:28 PM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
