Sony Bravia KDL-46EX640 no power
  • bullwinkle
    • May 2009
    • 107
    Re: Sony Bravia KDL-46EX640 no power
    @ budm: yes its a match. will firmware flashing recommended?
    • bullwinkle
      • May 2009
      • 107
      @ tom66: will check now the LVDS cable.
      • bullwinkle
        • May 2009
        • 107
        when you power up the unit, the display is very OK. But after 5 or 7 seconds later, picture is greenish
        • bullwinkle
          • May 2009
          • 107
          @ tom66: reset the LVDS cable. no joy. will check again
          • ecking767
            • Oct 2009
            • 492
            http://esupport.sony.com/US/p/model-...3#/downloadTab
            yes firmware update is needed
            • bullwinkle
              • May 2009
              • 107
              update:
              Cannot update firmware since the present firmware is already V1.245. Any other suggestions?
              • bullwinkle
                • May 2009
                • 107
                here is another pic of the board going to the panel
                • chrismurphy
                  • May 2014
                  • 251
                  • australia
                  #48
                  perform a firmware update that should fix it
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Maybe, you have to change something, in the service menu.
                    • bullwinkle
                      • May 2009
                      • 107
                      Cant reflash/update firmware. It says current firmware is latest.
                      • bullwinkle
                        • May 2009
                        • 107
                        Done playing with the service menu. Still no joy
                        • bullwinkle
                          • May 2009
                          • 107
                          Is it OK that the mainboard I purchased is from KDL-55EX640 instead of KDL-46EX640? Based on visual observation, both mainboards are a matach. Even the prints are all same.Any inputs?
                          • bullwinkle
                            • May 2009
                            • 107
                            any suggestions?
                              That can cause problems, Sony TVs are notoriously picky about the panel size requirement. You need to use 46" board.
                              • bullwinkle
                                • May 2009
                                • 107
                                Oh my , ok thanks for the info tom66.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I'm the other way around, I have a 46" board and 55" TV. Shopjimmy states, that it should be compatible.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    • bullwinkle
                                      • May 2009
                                      • 107
                                      Thank you very much for the info. Will update soon.
                                      • bullwinkle
                                        • May 2009
                                        • 107
                                        Update:
                                        Got the T-Con board. Same thing. No progress.
                                        Time to take a closer look at the original mainboard. Any suggestions/help is appreciated.
                                        • bullwinkle
                                          • May 2009
                                          • 107
                                          Well, I again visually checked the original mainboard and the one that I bought (it displays 55" not 46" in its current firmware version). Comparing the two visually I could say it is all same ie components, etc.
                                          My plan is since the mainboard I bought gave life to the TV except it is showing greenish display and I also bought a T-Con board and result is still the same. So, this mainboard I bought displays 55" instead of 46" in its firmware, is it OK if I flash it with a lower 46" firmware and then flash it with the latest 46" firmware?
                                          The firmware version of the mainboard that I bought is current but I cant reflash it again since it will display the version is current and no option to reflash except cancel option.
                                          Any suggestions? Please?
                                          • PopsCaps
                                            Sony Bravia KDL-40V2500 that will not power on
                                            by PopsCaps
                                            I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                            I do not hear any sound and I cannot see any backlight.
                                            I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                            The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                            My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                            03-25-2025, 11:23 AM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • repair-it
                                            SONY Bravia OLED XR-77A80J will not power on
                                            by repair-it
                                            SONY XR-77A80J shuts off as soon as it is powered on. It goes into standby ok when plugged in but when power button is pressed, relay clicks and tv powers off. Power supply board makes a sound that sounds like momentary coil whine when it clicks off. The main board appears to turn on and has working optical.
                                            I pulled the power supply board for visual inspection & there wasn't anything obvious. I am not sure how to go about testing this OLED as it is a bit different than the last one (LG) I tried to repair. The only voltage listed on the PSU is 12v for T-CON. The 12v is not present...
                                            01-24-2024, 10:15 PM
