Sony Bravia KDL-46EX640 no power
  • bullwinkle
    • May 2009
    • 107
    My 2 year old Sony Bravia KDL-46EX640 LED TV does not have any power at all. No RED LED standby indicator in the front panel can be seen. In short, deadset.
    My first step is to check the AC power cord and it turns out OK. Now I check fuses at the power supply board. All are OK. What's next?
    Any help would be much appreciated. Please help.
    Re: Sony Bravia KDL-46EX640 no power
    Post good clear pictures of the back side so we can see how the boards are connected together will be a good start.
    • bullwinkle
      • May 2009
      • 107
      Here are some pics as requested.
      • tibimakai
        • Jan 2012
        • 3680
        I'm in the same situation with a 55EX720. I don't even have standby.
        At the moment I'm waiting for a voltage regulator to arrive. On mine(yours may be different) I have 6 pin voltage regulator at the output of the standby transformer, which shows 4.27V input and output, which is not good, because the output should be 3.3V.
        I'm hoping, that it didn't mess up the mainboard.
          OK, measure the DC voltage right at the two legs of the main filter cap (big black cap laying on its side) C6530. You are working on the HOT side of the circuit so do not touch anything with your hands or body, plug the TV into GFI outlet will be a good idea.
          http://www.shopjimmy.com/media/catal...4-11-top_1.jpg
          • bullwinkle
            • May 2009
            • 107
            @ budm:
            Its 393.4 Volts DC.
              If that is the case, then the main board is sending out the PS_ON to turn on the PFC voltage booster. Turn the TV power switch to off, then the voltage on the cap should drop down to around 160~170VDC. Your meter is good, right?
              • bullwinkle
                • May 2009
                • 107
                Its a Fluke 79III True RMS Multimeter. But when I take the DC voltage, I simply plugged in to AC outlet and measure it across the big capacitor which is 393.4Vdc. I did not use any power switch since I can't see any RED LED standby indicator on the front panel.
                • sugar_ray
                  • Dec 2012
                  • 121
                  98% of the zero power issues I have encountered always seem to lead to a bad power supply board. Even after testing components that seemed ok. Just had a toshiba this weekend with the same issue your having. No standby, no front light, wouldn't respond to remote or side buttons. Just dead!! With meter I could tell the ps board was getting power but that's as far as it was going. No output. Ceramic fuse was fine as well. In most cases this will be a bad ps board. You'll just have to decide if you want to hunt down components or just replace the supply board itself. Rare occasions it can be the main board, but from experience, a bad main will still allow a standby light.
                  Here was the toshiba I was referring to. Replaced ps, and it lives!! Best of luck
                  https://www.youtube.com/watch?v=Bk9a...ature=youtu.be
                  • cliff_hootarski
                    • Jul 2006
                    • 411
                    In your second picture, do you see any burn marks on the mainboard near the connectors
                    at the top right of the board? Hard to tell in your pictures.
                    • bullwinkle
                      • May 2009
                      • 107
                      Please update us soon.
                      • bullwinkle
                        • May 2009
                        • 107
                        Checked both the power supply board and the mainboard using magnifying lens. All clean. No burnt marks or components.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          What do you get at D6201? That should be the diode after the standby transformer. Use the TV for ground when measuring.
                          Monday I should get the part.
                          • bullwinkle
                            • May 2009
                            • 107
                            Turned the switch to OFF but still the voltage present across the big filter capacitor is 393.4Vdc.
                            • bullwinkle
                              • May 2009
                              • 107
                              D6201 voltage is 3.327Vdc.
                              • bullwinkle
                                • May 2009
                                • 107
                                Other voltage infos:
                                D6303: Anode side: 374.4 Vdc and Cathode side: 420 Vdc
                                D6308: 14.41 Vdc
                                D6307: 13.98 Vdc
                                IC6301 (MIP2H2):
                                Pin 1: 5.74 Vdc
                                Pin 2: 1.632 Vdc
                                Pin 3: 0V
                                Pin 4: 14.41 Vdc
                                Pin 5: 374.5 Vdc
                                Pin 6: - - -
                                Pin 7: 0V
                                Pin 8: 0V
                                Any ideas?
                                • bullwinkle
                                  • May 2009
                                  • 107
                                  These components are also taken out and measured:
                                  C6308: 4.7uF/50V (measured = 4.8uF / ESR = 3.3 ohms)
                                  R6301: 10 Ohms (measured: 10.3 Ohms)
                                  R6302: 100KOhms (measured: 99.1 KOhms)
                                  C6311: 2.2uF / 50V (measured: 2.38uF / ESR = 5.8 Ohms)
                                  C6310: 100 uF/50V (measured: 110.9 uF / ESR = 0.65 Ohm)
                                  C6524: 10uF/50V (measured: 10.5uF / ESR: 2.3 Ohms)
                                  • bullwinkle
                                    • May 2009
                                    • 107
                                    D6303: Anode = 374.4 Vdc / Cathode = 420Vdc
                                    D6308 = 14.41 Vdc
                                    D6307 = 13.98 Vdc
                                    Im wondering if the ESR values stated are beyond their normal values. Do I have to replace those caps? Any inputs?
                                    • Ltank
                                      • Jun 2013
                                      • 776
                                      The Tv PS turns on as soon as the set is plugged in and the PS turns on? Can it still be turned off and back on? The MB gives the PS_On all the time? Normally if there is no standby voltage the set will not turn on at all. Strange
                                      • bullwinkle
                                        • May 2009
                                        • 107
                                        When I plug the unit to the wall outlet, i didnt see any RED LED Standby Indicator at the front panel. But when I trace the voltage starting the AC side, voltage is present, DC across the big filter capacitor is also present and in normal value.
                                        BUT, even if I press the POWER SWITCH located at the side of the unit, the DC voltage across the big filter capacitor remains the same. No changes at all. Does this mean a bad power switch?
                                        • PopsCaps
                                          Sony Bravia KDL-40V2500 that will not power on
                                          by PopsCaps
                                          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                          I do not hear any sound and I cannot see any backlight.
                                          I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                          03-25-2025, 11:23 AM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • repair-it
                                          SONY Bravia OLED XR-77A80J will not power on
                                          by repair-it
                                          SONY XR-77A80J shuts off as soon as it is powered on. It goes into standby ok when plugged in but when power button is pressed, relay clicks and tv powers off. Power supply board makes a sound that sounds like momentary coil whine when it clicks off. The main board appears to turn on and has working optical.
                                          I pulled the power supply board for visual inspection & there wasn't anything obvious. I am not sure how to go about testing this OLED as it is a bit different than the last one (LG) I tried to repair. The only voltage listed on the PSU is 12v for T-CON. The 12v is not present...
                                          01-24-2024, 10:15 PM
