Sony Bravia KD-65X85J No Sign Of life (No BL, Picture, Front LED,..)
  • EazyBone
    • Jun 2023
    • 1357
    • United states
    Good to hear 👍👍
    It's a corrupted chip. Emmcs have a lifespan apparently and that lifespan can be tested for with a programmer. I've pulled them off and tested them and they basically come back as corrupt. When you stick a new chip in, shows life used at 0 percent.
    Either way.. awesome to hear. Easy fix.
    • nomoresonys
      • 12306
      • U.S.
      I'll just post this bit of logic, you can research it if you like op. The eMMC typically lasts 4 or 5 years, replacing the mainboard with a used one will get the tv going if the eMMC has life left. THE question is how much is left. So without knowing, what you are left with is pretty much a ticking time-bomb. With most of these boards at more than 100 dollars used, it's not best practice. If someone didn't have the tools or didn't want to try or bother with repair. They could send it off to Nick or similar, they will install a NEW eMMC, get prolly a year warranty and you can rest easy that you have a new eMMC. And I'm pretty sure he can do it for less (than the uninformed, at least hopefully they are, people that are selling them on ebay are charging) So I would get that free quote from Nick...or tick...tick...tick. We seem to be striving for GREAT advice here lately, so there you go.
      • nomoresonys
        • 12306
        • U.S.
        There's Nick's doing one, anyone going this route needs to keep in mind what he says in the comments about netflix and some other apps: https://www.youtube.com/watch?v=mY9SDK6ihYc
        • EazyBone
          • Jun 2023
          • 1357
          • United states
          Yes but when you replace the EMMC on the Sony's you also lose access to Netflix prime and Hulu sometimes more than likely you do it just depends randomly.
          You can still access it through like a fire stick or some other media but no longer on the TV anyways
          • jason123
            • Oct 2015
            • 1110
            yeah, that's no good.. One last question, I can replace the eMMC with a brand new IC, but do I need to get some code into it? Is the actual executable code in the eMMC? Thanks
            • jason123
              • Oct 2015
              • 1110
              Thanks for sharing. It's interesting that the eMMC failure symptom on the TV in the Video is not preventing the startup process - it just halts. Mine is showing no life at all - wonder if the failure is other than eMMC
              • nomoresonys
                • 12306
                • U.S.
                #27
                Check post # 19, test those mlc caps.
                • nomoresonys
                  • 12306
                  • U.S.
                  #28
                  Yes, in Nicks video he says they program a new chip and install it.
                  • EazyBone
                    • Jun 2023
                    • 1357
                    • United states
                    #29
                    Yes you need to program it. Nick said he has to get the food software from a board that isn't bad, then he copies it and can use it afterwards. You can buy preprogrammed emmcs but the ones I saw were like 50-70$ each. Or buy a blank one for 2-4$ off Ali Express and put your own software. I have yet to be able to perform this yet on my own, and I don't have a proper reball machine or whatever you call it so I'm just using a hot air gun. I feel like there is something I'm missing but not sure what.
                    • Diah
                      • Feb 2013
                      • 6483
                      you do still have an open threat issue don't report back what i and lotas was involved with it.... are you such dummy ignore head... .. if you are hen we don't worth to apply for yours issue any more.
                      • nomoresonys
                        • 12306
                        • U.S.
                        #31
                        There's an echo in here, can you hear it??
                        • EazyBone
                          • Jun 2023
                          • 1357
                          • United states
                          #32
                          Yes, I thought I replied but it didn't post, it said restore. But you know I can't be always fixing a TV at all times . But I can be here because my phone is with me at all times... Don't see how this applies at all.
                          • jason123
                            • Oct 2015
                            • 1110
                            Thank you. I will exhaust the mlcc testing first then consider the emmc replacement.. happy tv is working though. Not sure what the comment from Diah means or refers to
                            • EazyBone
                              • Jun 2023
                              • 1357
                              • United states
                              #34
                              He's saying I am a hard head lol, he's not wrong. I post alot in here .. think I get on some people's nerves from time to time. I got good intentions tho.
                              • nomoresonys
                                • 12306
                                • U.S.
                                #35
                                Seems you do try to help, need to save the smart remarks for those who truly deserve them and not get involved in others disputes and send them in pm so as not to crap up the threads with controversy. Think before you lash out.
                                • jason123
                                  • Oct 2015
                                  • 1110
                                  Ok, finally got some time to investigate the issue on the main board. As it turns out, this had nothing to do with the eMMc. Several of the caps under the processor were shorted. I removed over 45 caps on the board that were shorted, with no luck. Finally, removing the processor cleared the shorts on the pads previously shorted. Internal short in the processor is the root cause. Hope this helps someone else.. at this point, it will take hours to put the caps back, then if the ARM had some pre-programming, that's yet another can of warms that I don't want to go after. I'll hang on to the board in case my existing eMMC dies years from now. Thank you all
                                  • EazyBone
                                    • Jun 2023
                                    • 1357
                                    • United states
                                    #37
                                    Nice! That's the less likely thing but the CPU dies as well. good find. Check the caps by cpu.
                                    Also if the CPU was the actual thing that was wrong the EMMC can be removed and the software can possibly be taken off the chip now. And then save the 8 gig file for future use lol
                                    • jason123
                                      • Oct 2015
                                      • 1110
                                      I may have to invest into a JTAG programmer.. good idea
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4507
                                        • Italy - Milan
                                        #39
                                        Jason you remembered me an Italian comedian that played the role of unlucky man in many films: "..after 45 condensers on the pile, one doubt came into his mind: could it be a bad chip???" ... apart jokes, this is not the way the good technician do, after the second cap you better had to take the bench psu and do the well known current injection..
                                        but remaining on the defect, you already did the reflow of chip, no? A ball could have made a short doing a bad reflow job, or the pop corn effect damaged the chip.. have you pre heated the bottom before blowing to top? Now neither the godfather saves this board..
                                        • lotas
                                          • Jan 2016
                                          • 4796
                                          • Russia
                                          #40
                                          And the short one on the CPU is how many Om? CPU core power is low.
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • JUCaESAl
                                            Sony bravia KD-65AF9
                                            by JUCaESAl
                                            Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                                            Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                                            10-20-2025, 04:03 AM
                                          • swrb898
                                            Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                                            by swrb898
                                            What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                                            Problem:
                                            Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                                            My troubleshooting got me this far:
                                            With the left-hand TCON to bottom-board ribbon cable...
                                            12-28-2021, 08:12 PM
                                          • iglitare
                                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                            by iglitare
                                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                            Backlight seems to work, Sound (Setup menu after reset) works.
                                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                            With my small knowledge i would think at least the cables are good.
                                            Can this happen because of a bad tcon board?
                                            Or is it always a bad/shorted...
                                            09-04-2025, 07:13 AM
                                          • PopsCaps
                                            Sony Bravia KDL-40V2500 that will not power on
                                            by PopsCaps
                                            I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                            I do not hear any sound and I cannot see any backlight.
                                            I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                            The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                            My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                            03-25-2025, 11:23 AM
