Sony Bravia KD-65X85J No Sign Of life (No BL, Picture, Front LED,..)
  • jason123
    • Oct 2015
    • 1110
    Originally posted by Davi.p
    Jason you remembered me an Italian comedian that played the role of unlucky man in many films: "..after 45 condensers on the pile, one doubt came into his mind: could it be a bad chip???" ... apart jokes, this is not the way the good technician do, after the second cap you better had to take the bench psu and do the well known current injection..
    but remaining on the defect, you already did the reflow of chip, no? A ball could have made a short doing a bad reflow job, or the pop corn effect damaged the chip.. have you pre heated the bottom before blowing to top? Now neither the godfather saves this board..
    Reflow is done on a professional BGA machine. Bottom heater, top heater, profile per ARM spec
    .. xrayed the chip before and after. Unlikely a ball short... though everything is possible! Sorry not up to date on the Italian comedy!
    • jason123
      • Oct 2015
      • 1110
      Originally posted by lotas
      And the short one on the CPU is how many Om? CPU core power is low.
      Core voltage was not coming on... there was no 0.8v on one of the rails with the proceesor on board. With cpu off the board, 0.82 came on.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4507
        • Italy - Milan
        #43
        wow, what an equipement... so i shut myself up, in this case.. this is prob. a dead by lightning so
        • nomoresonys
          • 12306
          • U.S.
          #44
          I don't think you missed much, the ratings must have been horrendous.
          • jason123
            • Oct 2015
            • 1110
            • yordsoto
              • Oct 2024
              • Chile
              #46
              https://youtu.be/-uAe-MQ1CYs?si=AKNUgelX6azbW9_R
              • Daren87
                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                by Daren87
                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                08-13-2023, 03:25 PM
              • JUCaESAl
                Sony bravia KD-65AF9
                by JUCaESAl
                Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                10-20-2025, 04:03 AM
              • swrb898
                Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                by swrb898
                What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                Problem:
                Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                My troubleshooting got me this far:
                With the left-hand TCON to bottom-board ribbon cable...
                12-28-2021, 08:12 PM
              • iglitare
                Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                by iglitare
                i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                Backlight seems to work, Sound (Setup menu after reset) works.
                If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                With my small knowledge i would think at least the cables are good.
                Can this happen because of a bad tcon board?
                Or is it always a bad/shorted...
                09-04-2025, 07:13 AM
              • PopsCaps
                Sony Bravia KDL-40V2500 that will not power on
                by PopsCaps
                I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                I do not hear any sound and I cannot see any backlight.
                I have tried disconnecting every cable on each board one at a time to see if anything changes.
                The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                03-25-2025, 11:23 AM
