philips 32 lcd keeps going on and off even when all caps have been changed
  • adamp91gvm
    • Jan 2014
    • 699
    As above gets worse as it gets warmer
  • adamp91gvm
    • Jan 2014
    • 699
    Re: philips 32 lcd keeps going on and off even when all caps have been changed
    Model 32pf9631d
      So... what have you tested so far? Should we just throw random guesses out? Maybe try checking PSU voltages. Any LED blinking? Check service menu (062596 then info+ or sometimes info+ 062596) for error codes.
      • adamp91gvm
        • Jan 2014
        • 699
        I had nothing on the tv could not find a book all voltages seem to be right no error leds at all
          What's the chassis code? If unsure, post a picture of the model # sticker. Voltages OK when it goes off? Does backlight go out? What about sound?
          • adamp91gvm
            • Jan 2014
            • 699
            Nothing stored in service menu
            • adamp91gvm
              • Jan 2014
              • 699
              Everything goes off on it then resets
                Chassis is FJ3.0ELA.
                Service manuals can be found on my site, as well as elektrotanya, servicemanuals.pro, and possibly many others.
                So when it goes off the power supply rails, do they drop out or not?
                Does it reboot immediately, or do you have to turn it back on?
                • adamp91gvm
                  • Jan 2014
                  • 699
                  Power drops slightly it seems to stay on when there is nothing plugged in but as soon as hdmi or scart goes in it starts going off it drops from 15.68v to 14.47v and it restarts it's self
                    WHAT drops from 15.6V to 14.4V? What is it labelled?
                    • adamp91gvm
                      • Jan 2014
                      • 699
                      View My Video
                      • adamp91gvm
                        • Jan 2014
                        • 699
                        its labelled 1306 on the power board and goes to the audio standby
                          I don't know every TV chassis off by heart so if you would be as kind to highlight this component on a photo I might be able to make a guess. What about the answers to my other questions?
                          • adamp91gvm
                            • Jan 2014
                            • 699
                            I'll get a pic in a mo for you I put a video up to show what it's doing it turns back on its self
                            • adamp91gvm
                              • Jan 2014
                              • 699
                              Just there to the audio board
                                No idea if that's OK, but if that part is only for audio I would exclude it for now. The way it turns off almost looks like panel 12V fails and it might be resetting because of this, try locating t-con board and check fuse voltages.
                                • adamp91gvm
                                  • Jan 2014
                                  • 699
                                  13 v going to the t con ?
                                    13V steady? Or not?
                                    • adamp91gvm
                                      • Jan 2014
                                      • 699
                                      12v now sorted voltage on t con but still goes off as soon as I plug and play my blue ray through hdmi
                                      • adamp91gvm
                                        • Jan 2014
                                        • 699
                                        Yer its steady till it goes off
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          Yesterday, 03:43 AM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • aidanmo
                                          Philips 43PUS7506/12 - Loud blown out sound
                                          by aidanmo
                                          I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                          I thought maybe the speakers got damaged, so I replaced them - no dice.
                                          • Using the internal speakers, it always happens.
                                          • Using the headphone jack, it never happens.
                                          • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                          02-28-2025, 03:13 PM
                                        • reach7458
                                          philips 37pf8404 solarized image (changed as15f already)
                                          by reach7458
                                          I got here an philips 37pf8404 with a solarized image. image one
                                          First guess its a bad as15f. so I replaced it with another. Same issues
                                          So I replaced it again with a rm5101. Same issues
                                          Problem is that is projecting a solarized image irregularly. When I pull the hdmi cable and put it back all is okay for a undetermined time. It also helps if I change the input from one hdmi port and back.
                                          One thing thats weird and I don't remember if it was the case with the previous tvs I repaired.
                                          When the image is solarized it doesn't affect...
                                          08-03-2020, 08:27 AM
                                        • Cornito
                                          Philips 50PUH6400 bad color and gosting / slow motion on one side
                                          by Cornito
                                          Hello Team,
                                          New issue on LCD panel where I need to find out the cause and the potential solution.
                                          This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                          I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                          When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                          I've checked voltages, no issue found comparing right and left side of the panel driver.
                                          VHG VGL CKV... are the sames on...
                                          03-08-2024, 06:41 AM
