philips 32 lcd keeps going on and off even when all caps have been changed
    Re: philips 32 lcd keeps going on and off even when all caps have been changed
    So, at the moment the screen fades does it drop out, or is it only gone once it's dark?
    • adamp91gvm
      • Jan 2014
      • 706
      • uk
      It's like I turn the plug off at the wall all colours are there untill it goes off and the power drops completely off then goes back up after it comes back on
        OK. Perhaps at this point it's a good idea to try to get the TV to run cool (perhaps put it in an outside shed for an hour?) then heat up parts with a hairdryer or hot air gun. See if you can make it malfunction. It's going to be tricky to track down exactly what part, but you might be able to get it down to a board-level replacement.
        • Sharpa
          Repair attempt Philips 55OLED804/12
          by Sharpa
          I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
          The symptoms when bought: Philips logo appears then tv turns off
          Things tried so far:
          1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
          2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
          11-22-2025, 08:30 AM
        • alro7779
          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
          by alro7779
          Hello, guys!
          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
          09-14-2025, 12:25 AM
        • G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
          by G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
          It does power up when pressing the power button.
          I already try the power button while plugin the plug with no result.
          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
          Could this be an PSU or eMMC issue ?
          07-19-2025, 03:43 AM
        • double_DD
          Philips curling iron - is this a common AC cable?
          by double_DD
          Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
          As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
          Not sure if this is something Philips proprietary, or a standard, but the cable plug...
          08-18-2025, 10:04 AM
        • janos6662000
          Philips 47PFS7509/12 LCD TV problem
          by janos6662000
          Hi
          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
          When i applied cable signal to check image, i had normal picture, but TV was restarting.
          I downloaded original firmware and applied the update, but the problem remained.
          From a colleague i received a "factory package software" which is a lot bigger.
          I made another firmware update, but still did not solve the problem.
          Somewhere on the way the error got worse, because at the moment the...
          08-12-2025, 12:54 PM
