Vizio E420VL problem
    Re: Vizio E420VL problem
    DIM voltage looks ok.
    your main board seen to be working, its your inverter circuit that having the problem. you have to replace your power supply & inverter board.
    looking on the solder side of your power supply inverter board there is a blue LED that light up for about 2 to 3 second when you power up the TV, are you seeing the blue light?
      Yes, it comes on.
        So what can I check next?
          Order an replacement power supply & inverter board.
            Are you getting about 370~400VDC on the two legs of that 450VDC Main filter cap when the TV is on? You can try fixing the board or buy a replacement as eckink suggested.
              396V at the big cap. I would also like to fix this board so maybe I can learn something.
                Well got another power supply and that didn't fix squat. (other than make my wallet $50 lighter)
                  Is this board from shopjimmy? The power supply /inverter board only requires small signals (BL_ON, DIM, PS_ON) from main board which according to the readings, you do have all the required signals for it to activate the backlights
                    No not this one. But still gives the exact same problem.
                      Ok, started over and found a fuse on mainboard out so got a kit from eBay that came with 2 fuses and 4 low voltage regulators and installed. Now I have orange logo then push power button and logo turns white and now the backlight flash on and off continuously. So I disconnected the main and shorted the power board and backlights stayed on like they are suppose to so I know it's in the main board however no one has one and if SJ did it's like $150 so any ideas on this main?
                        turned out to be a ribbon cable from the mainboard to the top shorting and blowing a fuse. Taped up place where it was shorted and works fine now.
                          which power supply did you used? the replacement?
                            Did not replace the power supply or change anything on it.
                              wow a bad cable, I wonder how that happen !
                                On top where it went over the fram it looked to have rubbed through.
                                  Ewww. That sucks. Yea when I get a new tv and if there is any kind of a possibility that it might be a main board or power supply I always check any and all fuses I can find. Rule out the easiest stuff first. Then I try looking at voltage regulators. Just an idea for next time to try and avoid buying a board and have it not fix the problem even though in this case it did sound like it.
