Vizio E420VL problem
  • ecking767
    • Oct 2009
    • 492
    Re: Vizio E420VL problem
    DIM voltage looks ok.
    your main board seen to be working, its your inverter circuit that having the problem. you have to replace your power supply & inverter board.
    looking on the solder side of your power supply inverter board there is a blue LED that light up for about 2 to 3 second when you power up the TV, are you seeing the blue light?
    • CraigR
      • Dec 2013
      • 959
      Yes, it comes on.
      • CraigR
        • Dec 2013
        • 959
        So what can I check next?
        • ecking767
          • Oct 2009
          • 492
          Order an replacement power supply & inverter board.
            Are you getting about 370~400VDC on the two legs of that 450VDC Main filter cap when the TV is on? You can try fixing the board or buy a replacement as eckink suggested.
            • CraigR
              • Dec 2013
              • 959
              396V at the big cap. I would also like to fix this board so maybe I can learn something.
              • CraigR
                • Dec 2013
                • 959
                Well got another power supply and that didn't fix squat. (other than make my wallet $50 lighter)
                  Is this board from shopjimmy? The power supply /inverter board only requires small signals (BL_ON, DIM, PS_ON) from main board which according to the readings, you do have all the required signals for it to activate the backlights
                  • CraigR
                    • Dec 2013
                    • 959
                    No not this one. But still gives the exact same problem.
                    • CraigR
                      • Dec 2013
                      • 959
                      Ok, started over and found a fuse on mainboard out so got a kit from eBay that came with 2 fuses and 4 low voltage regulators and installed. Now I have orange logo then push power button and logo turns white and now the backlight flash on and off continuously. So I disconnected the main and shorted the power board and backlights stayed on like they are suppose to so I know it's in the main board however no one has one and if SJ did it's like $150 so any ideas on this main?
                      • CraigR
                        • Dec 2013
                        • 959
                        turned out to be a ribbon cable from the mainboard to the top shorting and blowing a fuse. Taped up place where it was shorted and works fine now.
                        • ecking767
                          • Oct 2009
                          • 492
                          which power supply did you used? the replacement?
                          • CraigR
                            • Dec 2013
                            • 959
                            Did not replace the power supply or change anything on it.
                            • ecking767
                              • Oct 2009
                              • 492
                              wow a bad cable, I wonder how that happen !
                              • CraigR
                                • Dec 2013
                                • 959
                                On top where it went over the fram it looked to have rubbed through.
                                • audiofreak19
                                  • Apr 2013
                                  • 556
                                  • usa
                                  #36
                                  Ewww. That sucks. Yea when I get a new tv and if there is any kind of a possibility that it might be a main board or power supply I always check any and all fuses I can find. Rule out the easiest stuff first. Then I try looking at voltage regulators. Just an idea for next time to try and avoid buying a board and have it not fix the problem even though in this case it did sound like it.
                                  • Super360
                                    Vizio E701i-A3 Vizio logo flashing then turns off
                                    by Super360
                                    Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                    07-25-2024, 07:06 PM
                                  • rajbot
                                    No Power problem with Vizio E60-E3
                                    by rajbot
                                    Hi all:
                                    I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
                                    I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
                                    On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
                                    03-22-2023, 08:09 AM
                                  • x_orange90_x
                                    Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                    by x_orange90_x
                                    I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                    12-28-2023, 06:26 AM
                                  • theone111
                                    by theone111
                                    3. Problem: TV shuts down
                                    07-22-2024, 10:36 AM
                                  • MICHAEL_2013
                                    Change Logo Aptio Setup Utility 2021 (ROM Layout mismatch detected) Problem
                                    by MICHAEL_2013
                                    Good afternoon, Lords of great wisdom. My problem is the following: I bought a Chinese laptop with GN117_MB_V31-T board. (Aptio Setup Utility 2021) (There is no info for that board). And I want to change the logo of the bios. I have used Aptio_V Afuwin to do the bios Backup, then I change the logo with AMI ChangeLogo Tool v5.0.0.2 and everything seems perfect. But when you restart the new logo appears ok. But it automatically enters the bios, appearing a new option RECOVERY, ROM LAYOUT MISMATCH DETECTED - PARTIAL UPDATE IS NOT ALLOWED. If I give ESC it enters windows without problem but always...
                                    06-28-2021, 03:12 PM
