Panasonic TX-P42S10B
  • noledud
    • Dec 2013
    • 413
    • united kingdom
    Hi All been away a while waiting for parts and getting side tracked, found this Panasonic nearby and never having one for repair wanted to give it a go
    7 Blinks wont power on
    The seller was using daily until sometimes is was hard to turn on sometimes
    he told me this went on for a while all he did was unplug it then try again
    until recently it wont come on at all
    so i checked it and looked untouched and clean and screen good. He had bought a new one and just wanted rid
    I paid more than i would have liked then took it home
    the pics say it all for my first panasonic -- WTF
  • Agent24
    I see dead caps
    • Oct 2007
    • 5094
    • New Zealand
    Re: Panasonic TX-P42S10B
    Often a power-on problem that gets slowly worse is bad capacitors.
    But what interests me are the burn marks on the heatsink!
    -David VanHorn
    • noledud
      • Dec 2013
      • 413
      • united kingdom
      im more worried about the missings FETs missing from the y-main lol
      • noledud
        • Dec 2013
        • 413
        • united kingdom
        i think the person i bought it off forgot to say "hes tried repairing it but couldn't so then sold it"
        • Agent24
          I see dead caps
          • Oct 2007
          • 5094
          • New Zealand
          Only looked at thumbnails, didn't notice those missing FETs! Hopefully those were the bad ones (That he probably blew out from whatever mistake caused the heatsink to get burnt)
          -David VanHorn
          • tw2005
            • Oct 2011
            • 6458
            I think SC failure is fairly common in these. there are a couple of Ebay repairers of the board and some here have done that since these are pretty much impossible to find.
            not sure how you'll go now with the SC messed with as most repairers will not attempt a repair. i'd try and find out what exactly the previous person had done.
            It may just be that the shorted IGBts have been removed but if they've tried replacing them and powered it up, other damage may have occurred.
            they probably bailed out on cost. I think fro memory a Sc repair is about $130 plus you should resistance check the SD/SU as well just in case.
            • noledud
              • Dec 2013
              • 413
              • united kingdom
              exactly what i thought this is a can of worms
              • tw2005
                • Oct 2011
                • 6458
                So you need TNPA4829AD or TXNSC1EKUU.
                Inside the rear cover are there corresponding burn marks for what we see on the PSU?
                You may want to check fuses and FETs on that PSU and see if he's blown it.
                It may be possible to power this set up to confirm PSU and A board but will require isolating all the other boards.
                • tw2005
                  • Oct 2011
                  • 6458
                  Is 43quid a lot of money in your speak?
                  • noledud
                    • Dec 2013
                    • 413
                    • united kingdom
                    It is a TNPA4829AD
                    there are no marks on the rear cover at all
                    its not alot no, so can i narrow it down you think ?
                    • tw2005
                      • Oct 2011
                      • 6458
                      Originally posted by noledud
                      It is a TNPA4829AD
                      should I'm just trying to upload manuals now.
                      have you tried turning this on yet as is not that I want you too?
                      • noledud
                        • Dec 2013
                        • 413
                        • united kingdom
                        the seller powered it on for me lol
                        • tw2005
                          • Oct 2011
                          • 6458
                          might be quicker if you go to TOM's links in the reference library. Nothing but trouble last 2 days with uploads.
                          looking for 2009_PDP_Troubleshooting_Handbook_TTG090507CP-REV091117
                          not sure if he renames them.
                          If you think the PSU is ok, disconnect 3 white ribbons at the A board , P35, SC2, SS11 and power up and confirm if it starts ok and stays on. This will confirm PSu and A.
                          then I'd resistance check the SD/SU boards.
                          • tw2005
                            • Oct 2011
                            • 6458
                            That was nice of him, clearly he knew what he was doing(not)
                            Well, I guess that confirms there's hope.
                            If you disconnect all of what I posted hopefully it will just turn on.
                            I'd expect SOS7 with a Sc in that condition.
                            • tw2005
                              • Oct 2011
                              • 6458
                              Finally,
                              Slide 25 on, resistance check SD/SU,
                              Slide 27, boards disconnected from the SC, all the instructions are there.
                              note: Unplug connector SU41 and SU11(interconnecting ribbon SU/SD. Remove the 2 floating ground screws from the SU board
                              If they come up good you might get out of it for 43quid.
                              • tw2005
                                • Oct 2011
                                • 6458
                                This post may be of interest. MSAUDIO replaced just the blown IGBTs and a diode (Q402, Q421, Q422, Q661 & D865 ) and got one going which is pretty lucky and cool.
                                https://www.badcaps.net/forum/showth...ght=TX-P42S10B
                                Are these all that are missing? D622,Q401,Q402,Q421,Q422,Q661. Be interesting to check D865 next to Q622 and see if short cct.
                                Any chance you can check to see if the guy has the pulled parts, some may not have been bad, like D622 or Q401 /402. Could be handy in case D622 is hard to find and you want to have a gamble fixing this.
                                Actually TN245 got his going, reported replacing same and fixed his too.
                                Originally posted by masaudio
                                I have one of these boards in, and your parts list is a great help as we can order direct from Panasonic, glad someone out there can get onto the manuals..
                                We have the board with Q402, Q421, Q422, Q661 & D865 all shorted, disconnecting them has removed all shorts from the board, so hopefully replacing them will cure the problem.
                                (I think the parts list precedes the parts with 16, eg Q16402... ?)
                                The SC board from Panasonic is £197.28 trade price
                                Yes I did replace those blown components, and that was all it was, It cured the fault and got all the components direct from Panasonic, they did not cost very much at all.
                                Originally posted by tn245
                                I just got around to finishing this repair and testing and I'm happy to report it works. On my board it was Q401, Q421, Q422, Q661 & D865 that were shorted. Q402 was actually ok although I replaced it anyway as I removed it before Q401.
                                IGBTs were from utsource.net, total cost $12 (USD) + $4 shipping. Took a couple of weeks to arrive. The diode was that BOURNS, CD214A-F1400 from ebay which was £1.37.
                                The 30G123s and the RJP6065 looked brand new as far as I could tell. Now that you mention it I was a little surprised that the 2PG011s both had legs already bent into position and cut the correct length. You think they're selling pulled parts as new?
                                I was pretty pleased when I heard the sustain boards buzzing instead of parts exploding yes.
                                Some parts info should you need.
                                Originally posted by tw2005
                                snipped................Q16402, 2PG0090000R (2PG009) Panasonic IGBT; VCES (V): 510; Ic (A): 40; tf (µs) typ: 0.19; Vce typ: 1.95; Package: TO-220FN
                                Q16421, Q16422, = GT30G123 (30G123) Toshiba IGBT; VCES (V): 430; Ic (A): 30;(200A Peak pulse); Vce typ: 2.2; Package: TO-220FN
                                Q16661 = RJP6065DPP-90-T2 RENESAS IGBT; VCES (V): 630; Ic (A): 40; tf (µs) typ: 0.45; Vce typ: 1.8; Package: TO-220FN
                                RJP63F3A would work. RENESAS
                                D16865 = RF101L4S TE25, ROHM 400V 1A
                                Q16701, = MMBTA92 NXP , PNP high-voltage transistor 300V 0.1A
                                Q16702 = 2SD0601A0L,,2PD601ART, NXP , 50 V, 100 mA NPN general-purpose transistor
                                Q16501,521,531,551,762, = SANYO, PNP / NPN Silicon Transistor, CPH5524-TL-E
                                Q16647,607,608,817,818,874 = ROHM , Small switching N-channel MOSFET (30V, 0.1A) 2SK3018T106 (2N7002 will work, watch the package sizes)
                                IC16771,= TOSHIBA TA78L05F(TE12L,F) , 78L05
                                IC16464, IC16465 , IC16773 C0JBAB000715 = TOSHIBA TC7SH14F (TE85L), (Texas Instruments SN74AHC1G14DBVR)
                                • noledud
                                  • Dec 2013
                                  • 413
                                  • united kingdom
                                  Yes all the missing ones are D622,Q401,Q402,Q421,Q422,Q661.
                                  Just as you suggested, im about to test the ps and i will check for that short aswell
                                  Cheers
                                  • dcapper
                                    • Dec 2013
                                    • 496
                                    What's with the Panasonic project parts tv? I had the exact same problem with a X2. Missing chips on boards. I replaced the A board. The P board was already replaced. Ordered an SN and SC boards. Nothing left but the buffers.
                                    Has shopjimmy or paylesscomponents got any replacement boards?
                                    I tried to repair what I had too and I gave up and found boards. But haven't received them to try them. TW has been more than helpful with my trouble too. Check out my thread. It has great info too.
                                    https://www.badcaps.net/forum/showthread.php?t=35362
                                    • noledud
                                      • Dec 2013
                                      • 413
                                      • united kingdom
                                      Hi all sorry for the delay in getting back on this one
                                      the power board is ok
                                      the SU has a resistance of 1.4 and the SD has 0.4 so long as im measuring right
                                      so i take it that means im going to need SU SD and SC
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        More info, units of measurement e.g. ohms, and the test points.
                                        • BigPete
                                          Panasonic Heatpump Dryer Repair
                                          by BigPete
                                          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                          Unfortunately the whole machine has to come apart to fix it.
                                          I have...
                                          11-01-2025, 06:40 PM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • aa10aa10
                                          Panasonic Toughbook CF-33 mk1 BIOS repair
                                          by aa10aa10
                                          Good day,
                                          I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                          I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                          01-21-2025, 06:13 AM
