Panasonic TX-P42S10B
Re: Panasonic TX-P42S10B
It helps to have a meter with continuity, beeping when you make connection, and one which is fast (my meter responds within 1ms for continuity testing.)
Place probe on the floating GND and run it along the panel ribbons. Any beeps are bad, shorted outputs.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I don't think his has that feature, might have to stick to diode and watch for the very low or zero reading.Comment
Set to 200 ohm IMHO, each buffer output has an antiparallel diode which you don't want to pick up. any reading different from "1" would indicate a potential short and should be investigated.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
on diode mode if i touch the pins i get a change to 000 its what iv always used to test for shorts
all boards using the above method show no shorts apart from the EMOS SD, its every single pin on that one showing a short
so if im using my DMM correctly then i should try using my buffers as we know for sure one SD is defiantly badComment
just checked the SC again while the buffers are out and thats blown now aswell
the bad lower buffer must have blown it when i connected them up
am i right in thinking it wasnt the panel as my lower buffer is ok ?Comment
If picking a new meter go for one with a fast and latched continuity range.
I use the BK 2709B you can see that you can run it right along a load of panel connectors and it will pick up a short really quickly.
https://www.youtube.com/watch?v=51SZ...Y&noredirect=1
Something like a good condition used Fluke, e.g. Fluke 87 or Fluke 27 is hard to go wrong with.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
How did the SC blow?
You get the parts and fit them getting SOS 7.
Then I get you to isolate the SD/SU and jumper SC50, SC passes and TV powers on, no blinks.
We then knew that SC was good, and suspected we had bad buffers (possibly panel)
We then start testing the buffers and conclude the supplied SD is suspect and you've since confirmed a shorted output on one connector.
At what point did the SC blow?Comment
I put his sc and buffers in and got 7 blink, I then isolated his sc and got it to power up, I've then double checked it was all built correctly tried again and still got blink 7. Then I've pulled the buffers and started checking them. After confirming his sd was bad and mine looks good I wanted to try mine. While buffers out checked sc again and 7 blinks.
This is why I wanted sc and buffers to avoid this.
Well lesson learnt I'm going to get a new dmm send these boards back for exchange hopefully then test new ones first.
Do you agree that my panel didn't cause this because my lower buffer would be the same if it had ?Comment
Yeah, trying again once the Sc passed was a risky move especially when i said the buffers were most likely bad. If you found something obvious like the earth screws left out maybe worth a retry but we all learn the hard way sometimes.I put his sc and buffers in and got 7 blink, I then isolated his sc and got it to power up, I've then double checked it was all built correctly tried again and still got blink 7. Then I've pulled the buffers and started checking them. After confirming his sd was bad and mine looks good I wanted to try mine. While buffers out checked sc again and 7 blinks.
You would assume that since your originals are not shorted then whatever happened to the SD was prior. Most likely a cracked screen whilst on blew the SD, SC survived the first time, not the second.
Exactly what happened to me except I only had myself to blame for not checking the buffers. 2 attempts SOS 7, blew it on the second and you could hear the quick pop.
general rule for me I always check any used sustain or buffres on arrival for shorts prior to installation now.
When I got my EMOS boards, they never left the box, tested short not only the Sc but the Buffers too.
It'll be interesting to see how you go now. Hope it works out. I guess you've done a quick check of the transistors to see what's shorted?Last edited by tw2005; 05-22-2014, 12:16 AM.Comment
Hi all
just to update
advised EMOS of the faulty parts and I want to return them
I never checked for shorts as I was fed up of seeing this set
took the boards in as they are not to far from my work
chap there went upstairs and "tested" the boards he agreed the bottom buffer had a short but the SC was fine !
he suggested replacing the bottom buffer would solve the issue
so with that information ( now doubting my diagnosis of faulty SC ) and new none shorted bottom buffer I went back home
fitted SC with no buffers did the jumper trick and still SOS 7
took all the parts back to EMOS again and the same guy checked the boards again he said they are all fine and "tested"
when I asked him how he tested he said he checked for shorts with DMM
I advised him they might not be any shorts where he is checking but the board is bad as I get 7 blink on its own
he told me I cant run it on its own and which point I gave up and told him I want a refund
so just had my refund from them but its shy of £11.75 iv asked why so waiting for a reply
I have a feeling it will be a re stocking fee or something as they have said the board is fine. I would have thought tho that the board would have been re sold and sent out by now so he should have another customer complaining but i doubt he would ever admit thatComment
by BigPeteI picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
Unfortunately the whole machine has to come apart to fix it.
I have... -
...1 Photo11-20-2024, 08:52 PM -
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
Channel: BIOS Requests ONLY!
by stecosHi everyone!
I happened several times, in the search for help from the web, to consult this very interesting forum.
So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
Having said that I come to the gist of my post on the forum as the title suggests.
For my passion for technology I'm now collecting several... -
by aa10aa10Good day,
I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....-
- Loading...
