Panasonic TX-P42S10B
  • noledud
    • Dec 2013
    • 413
    • united kingdom
    Re: Panasonic TX-P42S10B
    using slides 27 and 28
    DMM = ohms 20M
    SU41 pin 2 to ground = 1.4 ohms
    SD42 pin 9 to ground = 0.2 ohms
    • tw2005
      • Oct 2011
      • 6458
      Oh, yeah definitely short cct but for a sanity check set meter to diode or continuity and confirm continuous beep indicating short cct
      • noledud
        • Dec 2013
        • 413
        • united kingdom
        yeah SU has continuity but the SD dont, thinking this is going to me uneconomical to repair
        • DoubleDratt88
          • Aug 2013
          • 51
          DMM = ohms 20M
          If those readings are in meg-ohms then it could be ok?
          Im going through a similar process on another model(s10a) with same 42 panel as this so alot will be similar.
          My pins varied from printed guides for other models so check your manuals for your models pins to be sure VSCN-F etc are on the pins they should be.
          Long story short, at SU41:
          VSCN-F 220k ohms is near enough to normal according to the manuals I have - IF that was the 0.2 in meg ohms you read at SU41? and vfo was 1.5m?
          Expected approx readings(from 2010_FHD_Plasma_TV_G25_Series_Troubleshooting_Handbook.pdf):
          VFO 2.2m
          VSCN-F 221k
          5V_F 5.7m
          and from another guide:
          VFO 1.9m
          VSCN-F 220k
          5V_F 6.3m
          Vfo was more interesting.
          With Black to VF_GND and Red to VSCN-F measuring point i get 6.2-7.5mohm on 20m resistance scale and no contunuity on diode check or continuity beep settings.
          With Red to VF_GND and black to test point i get no reading on any resistance scale(not oL, just open). However with meter set to diode test i do get a reading of 1.0x - on continuity beep setting i get nothing.
          The schematics i have for my s10a chassis are missing the SC/SU boards so have to assume with the leads switched the path taken by the supplied current from the dmm is passing through a diode or transistor etc or both, and the positive diode reading is possibly a good sign. As i mentioned on continuity beep setting- i get nothing.
          Some patience was needed on measuring the m-ohm readings as they took a while to get a stable number too.
          All taken with SC board removed and SU SD ribbon disconnected etc.
          I'm not 100% sure what all this means yet but I was fairly confident before reading this that my su/sd boards are ok after checking the various isolation procedures, despite some of the numbers being a bit off the guide they are stil in the mohm range and far from dead shorted.
          Also i'm still testing for certainty and wouldn't say i was 100% sure of anything at this stage. If i had my tv working after all this i might be more certain but it will be a couple of weeks before i finish diddling with the sc board and replacement parts etc and find out. fwiw i have not posted yet about my issues but plan to start a thread sometime with my notes on journeys with similar problems but they are looking to be the same as folks in this thread:
          https://www.badcaps.net/forum/showth...t=27921&page=1
          Your situation may be different but these panels do seem to be tossing out similar SC issues on various models from the searching ive done lately and i noticed your numbers look suspiciously close to the expected values from the pana guide if they were taken on 20m range. *or in tw2005's post # 58 in this thread: https://www.badcaps.net/forum/showth...t=26322&page=3
          Goodluck, hope this helps and sorry if it wasted your time :-)
          • noledud
            • Dec 2013
            • 413
            • united kingdom
            hi sorry for the long delay after discovering i might have a bad buffer as well i put this on the back burner hoping i could get a donor still not found one so going to have a bash if you all agree this possibly could be repaid in the light of what DoubleDratt88 said about the buffer possibly being ok
            • tw2005
              • Oct 2011
              • 6458
              what do you mean repaid?
              • noledud
                • Dec 2013
                • 413
                • united kingdom
                #27
                lol repaird
                • noledud
                  • Dec 2013
                  • 413
                  • united kingdom
                  #28
                  hi all found a poss tv with bad panel - does anyone happen to know which compatible models should use the same boards ?
                  • noledud
                    • Dec 2013
                    • 413
                    • united kingdom
                    #29
                    any one know ?
                    • tw2005
                      • Oct 2011
                      • 6458
                      I was thinking U10B & S11B but you'd have to check if these were UK market. Would not it be just as easy if you just looked up the model in question and track down the manual to find the SC part number to work it out or search the model in FlatTV parts and see what boards come up?
                      • noledud
                        • Dec 2013
                        • 413
                        • united kingdom
                        #31
                        yeah your right me being thick cheers tw2005 iv sorted it now
                        • noledud
                          • Dec 2013
                          • 413
                          • united kingdom
                          #32
                          ok cant find a board so going to try the repair on this one
                          it TNPA4829 AD TXNSC11XBH42
                          is there a kit i can buy with everything or has anyone got a list of parts and where i can get them in the uk ?
                          • tw2005
                            • Oct 2011
                            • 6458
                            Post 16 has some part numbers. what can't you work out?
                            There's a couple of guys who had some success, including one repair shop in that post. Maybe send them a PM and they may have some tips especially the repair guy as he may be able to assist with the parts .
                            • noledud
                              • Dec 2013
                              • 413
                              • united kingdom
                              #34
                              what are mine of D622,Q401 i cant see them in the list ?
                              the tv was missing them when i got it so i have no idea
                              • tw2005
                                • Oct 2011
                                • 6458
                                You have the service manual for the parts list?
                                D16622 B0FBCN000006 = RF2001TM3SW, by ROHM. Same as D621, check that marking.
                                Q16401 2PG0110000RP = 2PG011, by Panasonic, Same as Q402 if you have that one still fitted.
                                • noledud
                                  • Dec 2013
                                  • 413
                                  • united kingdom
                                  #36
                                  just found all the boards for £63 to my door, the parts just for SC were 25 +
                                  so when everything arrives i can compare buffers to confirm if mine are bad and send back what i dont need
                                  • noledud
                                    • Dec 2013
                                    • 413
                                    • united kingdom
                                    #37
                                    received parts fitted and now it does nothing
                                    if i disconnect the 3 ribbions on the main the set powers up with all LEDs on SC etc lit and standby green just no pic
                                    its as soon as i connect the main board ribbons nothing happens when powered not even a red flashing standby
                                    any suggestions while i check for voltages
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      you got me on this one. You had 7 blinks, starts ok with A and PSU alone, now nothing with it all hooked up. Take a stab and hook everything except SC20 ribbon. Can you post a good picture of everything in one shot from the back for a look.
                                      This TV is jinxed it seems.
                                      • noledud
                                        • Dec 2013
                                        • 413
                                        • united kingdom
                                        #39
                                        ok will post pic in a min phone is charging
                                        have i tested the a and ps alone dont think i have, how do i best check the A ?
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          maybe not. I made suggestion in post 13, you came back and confirmed PSU was ok.
                                          I guess I took that as you had also tried the PSU/A board only.
                                          Other reason suggesting this was to be sure nothing else was going to bite you on the bum.
                                          • BigPete
                                            Panasonic Heatpump Dryer Repair
                                            by BigPete
                                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                            Unfortunately the whole machine has to come apart to fix it.
                                            I have...
                                            11-01-2025, 06:40 PM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            11-20-2024, 08:52 PM
                                          • AquaMan Ua
                                            Problem with PANASONIC CF53 laptop after changing BIOS settings
                                            by AquaMan Ua
                                            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                            05-17-2025, 09:40 AM
                                          • stecos
                                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                            by stecos
                                            Hi everyone!
                                            I happened several times, in the search for help from the web, to consult this very interesting forum.
                                            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                            Having said that I come to the gist of my post on the forum as the title suggests.
                                            For my passion for technology I'm now collecting several...
                                            11-28-2022, 11:39 AM
                                          • aa10aa10
                                            Panasonic Toughbook CF-33 mk1 BIOS repair
                                            by aa10aa10
                                            Good day,
                                            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                            01-21-2025, 06:13 AM
