DYNEX DX55L-150A11 Randomly turns off
  • dskall
    • Oct 2016
    • 2905
    • usa
    #101
    Re: DYNEX DX55L-150A11 Randomly turns off
    I would recheck all solder joints for 5v
    • Shane711
      • 493
      All the solder joints are good. The IC A6059H (N901) exploded and took out R905. I have replaced those but my 5V standby is erratic. I checked the near by capacitors and they test good.
      • dskall
        • Oct 2016
        • 2905
        • usa
        #103
        Is that with main board disconnected? Checked transformer connections? Connections at connector plug?
        • Shane711
          • 493
          Yes, just the power board. It is removed from the TV. There is a component causing the problem. I asked what component should I suspect? All my connections are good. Budm probably knows this like the back of his hand, he dreams about it.
          • freakaftr8
            • Oct 2012
            • 3743
            I suspect could be an opto, checked all diodes around primary bridge rectifier?
            • Shane711
              • 493
              Yes, checked all the diodes. So you think the opto can fluctuate? I will have to check those tomorrow then and see what I find.
              • Shane711
                • 493
                Well I got another board that had NO 5V(0V), the first board had fluctuating voltage. I removed the optos(Optocouplers) from the second board to the first and SUCCESS, the board now works. So you were right freak, it was the opto. Now I just got to get my crappy meter to work right so I can change out those resistors. The resistors on the second board seem perfect. Bought the second board as "For Parts" on eBay, I think it has some bad caps that are not popped.
                • Shane711
                  • 493
                  I got the resistors on the board. I used regular 1/2 watt resistors. I don't know if it is normal but I noticed the length of my leads changes the resistance so I played around with it until I got 1.95 M OHM.
                  • Shane711
                    • 493
                    OK, so the board is not working all the time, It appears the Optocoupler that turns the board on is working sometimes but only sometimes. Can I replace the 817B Optocoupler with a 817C or a NEC 2561 ?
                    • Jason20
                      • Apr 2014
                      • 3
                      • united states
                      #110
                      I know this is a old thread but I was having issues with my dx-55l150a11 tv shutting off/not turning on when power was applied.. also would just shut off whenever it wanted ... I ended up replacing power supply because when it comes to any component more then capacitors/fuse being bad I'm a nuub... it's been a couple weeks and hasn't acted up since... thanks guys for the help/suggestions on how to repair my tv..
                      • bluenote
                        • Apr 2020
                        • 3
                        • no thanks
                        #111
                        Ok I'm pretty noobish and I guess I'll be replacing those resistors. Is anybody following this still that can help out with my stupid questions?
                          • 12332
                          • U.S.
                          #112
                          Shoot.
                          • bluenote
                            • Apr 2020
                            • 3
                            • no thanks
                            #113
                            Shoot.
                            Thanks for speaking up! I'm going to source these resistors and I'll be back! For now, my only dumb question is, am I going to have to drain the capacitor(s) to work on this thing, or is leaving it unplugged for some days enough? And if so, can I just take some insulated wire and touch a leg of the caps to wall socket ground?
                              • 12332
                              • U.S.
                              #114
                              Use a resistor, touch both legs of the cap with each end of resistor, like you would with a wire.
                                • 12332
                                • U.S.
                                #115
                                Be careful with those big capacitor they can KILL, never touch the ends with your fingers, just assume they have a charge, make sure you are insulated from them when discharging, some use a resistor held with insulated needle nose pliers not bare metal pliers, here he built a simple discharge tool: https://www.youtube.com/watch?v=QNiBqF3Plw0
                                  • 12332
                                  • U.S.
                                  #116
                                  DON'T use a wire, NEVER use a bare metal wire, touching that with your fingers can KILL.
                                  • bluenote
                                    • Apr 2020
                                    • 3
                                    • no thanks
                                    #117
                                    Ok, I finally sourced the resistors! I have never opened a lcd before. It looks like there is 6 big bolts around the stand that need to come out to get the back off, but I was hoping not to have to put this thing on it's face to work on it. Anybody recall whether those are necessary AND if they compromise the stand? From outside it looks like they do. In that case I would I think have to lay it on it's face and work over it.
                                    thx
                                    (thanks for the info about the caps nomoresonys)
                                      • 12332
                                      • U.S.
                                      #118
                                      Sure lay it face down on a nice flat surface, I usually use a quilt or blanket under it to try to keep from scratching the screen.
                                      • cajoeg
                                        Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                        by cajoeg
                                        Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                        The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                        02-10-2025, 04:01 PM
                                      • nieljosiah
                                        HP Notebook - 15-ba017ax (LA-D711P Motherboard) turns off randomly after some time
                                        by nieljosiah
                                        I've had this laptop for 8-9 years, and about a week back, it started malfunctioning. When I press the power button, the power LED comes on for about 5secs and turns off. The fan also doesn't spin at all during this time. But, if I press the power button, and then manually spin the fan, the laptop boots up and the fan starts spinning on its own. Even if I do this, and the laptop boots up, it turns off (hard shutdown) after some time between 10secs and 1hour randomly. I've tried checking the fan voltage and it's at zero volts when I press the power button without spinning it, but when I spin the...
                                        08-17-2024, 02:19 AM
                                      • thedigi321
                                        I have an LG 50PN4500-UA turns off and on randomly with 2 flashes before turning on
                                        by thedigi321
                                        showing power does nothing randomly turns on with 2 flashes: https://youtu.be/ZHME8GthErc
                                        Hello all I have an issue with my tv. I have had it for about 5-6 months because when I moved apartments the previous owner left the tv. and I got it for free it is a plasma tv and looks nice enough. an issue that started to happen was that it would kick off randomly but I could still turn it on well about a month or so I assumed the power button went out so I got a universal remote and programmed all lg codes and nothing just the solid red standby light so fast forward to a week ago...
                                        12-18-2019, 10:00 PM
                                      • Stephen
                                        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                        by Stephen
                                        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                        03-15-2024, 09:37 AM
                                      • www
                                        LG L192WS-BN backlight turns off after 1 second
                                        by www
                                        I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                        I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                        03-24-2024, 05:26 PM
