DYNEX DX55L-150A11 Randomly turns off
  • freakaftr8
    • Oct 2012
    • 3743
    Re: DYNEX DX55L-150A11 Randomly turns off
    Had any luck with n802? Got the same problem here. N802 shuts down tv with heat. But only if.
    its been on a while. Wierd..n802 is a pwm controller
    • dskall
      • Oct 2016
      • 2905
      • usa
      I replaced N802. I haven't fully tested it yet but I think it fixed the problem
      • freakaftr8
        • Oct 2012
        • 3743
        Where did you get the IC? Shopjimmy has it but don't want the whole kit. Don't want to spend the 24 bucks.
        • dskall
          • Oct 2016
          • 2905
          • usa
          I got mine here: http://www.ebay.com/itm/252299704471...%3AMEBIDX%3AIT
          I also replaced some feedback resistors as voltage on main cap was 357v. Now 391v so don't know if that factors in
          • freakaftr8
            • Oct 2012
            • 3743
            If you purchasd 5 of em would you mind sending me one? I'll pay whatever plus shipping. I'm up near Sacramento.
            • dskall
              • Oct 2016
              • 2905
              • usa
              #26
              OK I listed on ebay. Easiest for me to do. May not list immediately.
              • freakaftr8
                • Oct 2012
                • 3743
                Thanks bud
                • Burningstariv
                  • Mar 2017
                  • 7
                  Wow, I was having similar problems and found this fresh thread and I had to make a post.
                  So I have the Dynex DX55L-150A11 and it also shuts off until I unplug the power. It doesn't do it randomly. When my TV shuts off its usually from when the screen is displaying very bright White Light. So lets say I'm watching a show that has flashes in action scene, it will shut off. Sometimes I use my screen to stream Netflix from the PC through HDMI and If I open a full screen tab and its all white it will shut off. I suspect it must be related to the backlight inverter but I haven't taken it apart yet.
                  Any suggestions of troubleshooting before I do attempt to take it apart.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #29
                    Turn down your backlights and see if it continues to shutdown.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      Replace n802 on power supply. It's gone bad.
                      • Burningstariv
                        • Mar 2017
                        • 7
                        I turned down the brightness, it has mostly prevented the shut offs, but now I can barely watch it lol. I guess I'll be waiting for that chip from China?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #32
                          I think freakaftr8 has nailed the problem.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            EBay item no. 322465138482
                            Dskall has 3 left I believe. Coming out of .CA so shipping wont take too long
                            Replace this guy and you're good to go
                            • Burningstariv
                              • Mar 2017
                              • 7
                              I gotta say thank you guys for all the help man you are all awesome! I'll update after I purchase and install it.
                              • Burningstariv
                                • Mar 2017
                                • 7
                                Seems he took down his listing. No Results for the item number.
                                Dskall if you wanna sell me an extra I would greatly appreciate Ill cover the shipping and extra for your time.
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  #36
                                  Ok relisted one more. May not list right away.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    So the customer stated that it worked great all night long and then he turned it on this morning with the same symptom. I'm not really worried sure where to go from here besides replacing the power supply
                                    • dskall
                                      • Oct 2016
                                      • 2905
                                      • usa
                                      #38
                                      Well original op said replacing power supply fixed problem. I still have tv so will run it more to see if it turns off. Not going to replace power supply, if it still fails until I fix problem.
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        You said you replaced some feedback resistors. Which ones did you replace?
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #40
                                          I really hate faults like this and it looses customer confidence in us too but faults like this are really hard to fault find plus how long should we be soak testing/powering on and off a set etc as most customers want a quick fix.
                                          • cajoeg
                                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                            by cajoeg
                                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                            02-10-2025, 04:01 PM
                                          • nieljosiah
                                            HP Notebook - 15-ba017ax (LA-D711P Motherboard) turns off randomly after some time
                                            by nieljosiah
                                            I've had this laptop for 8-9 years, and about a week back, it started malfunctioning. When I press the power button, the power LED comes on for about 5secs and turns off. The fan also doesn't spin at all during this time. But, if I press the power button, and then manually spin the fan, the laptop boots up and the fan starts spinning on its own. Even if I do this, and the laptop boots up, it turns off (hard shutdown) after some time between 10secs and 1hour randomly. I've tried checking the fan voltage and it's at zero volts when I press the power button without spinning it, but when I spin the...
                                            08-17-2024, 02:19 AM
                                          • thedigi321
                                            I have an LG 50PN4500-UA turns off and on randomly with 2 flashes before turning on
                                            by thedigi321
                                            showing power does nothing randomly turns on with 2 flashes: https://youtu.be/ZHME8GthErc
                                            Hello all I have an issue with my tv. I have had it for about 5-6 months because when I moved apartments the previous owner left the tv. and I got it for free it is a plasma tv and looks nice enough. an issue that started to happen was that it would kick off randomly but I could still turn it on well about a month or so I assumed the power button went out so I got a universal remote and programmed all lg codes and nothing just the solid red standby light so fast forward to a week ago...
                                            12-18-2019, 10:00 PM
                                          • Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                            by Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                            03-15-2024, 09:37 AM
                                          • www
                                            LG L192WS-BN backlight turns off after 1 second
                                            by www
                                            I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                            I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                            03-24-2024, 05:26 PM
