DYNEX DX55L-150A11 Randomly turns off
  • dskall
    • Oct 2016
    • 2905
    • usa
    #41
    Re: DYNEX DX55L-150A11 Randomly turns off
    I had low 357v on main cap. Replaced out of tolerance feedback resistors. Don't remember numbers but three in series on back of board. Brought it up to 391v.
    • freakaftr8
      • Oct 2012
      • 3743
      That makes perfect sense low voltage on a main cap means low primary which means any spike in current that the secondary can't keep up with will cause a shutdown on a feedback circuit since the power supplies working in overdrive trying to regulate all voltages and keep a good voltage going to all secondary outputs
      • dskall
        • Oct 2016
        • 2905
        • usa
        #43
        I didn't post a confirmed fix because I hadn't run more than about an hour. But it was shutting off at that time around every 20min. I made both of the repairs at the same time. When I was testing voltages at ic it would shut down. Maybe the fix was the low voltage and not the ic. I have it running for several hours now with no shutdown. I have no good inputs to test with except to take it to living room and hook up. My wife getting tired of lifting them. Maybe I should help her. LOL
        • freakaftr8
          • Oct 2012
          • 3743
          So sure enough. Power across the filter is 355vdc. Seems low. Those 3 power resistors are supposed to be .15 ohm. Well they are reading .28ohm. This would cause the low voltage on filter caps Right?
          • dskall
            • Oct 2016
            • 2905
            • usa
            #45
            I will pull my board and post where they are. They are smd resistors on back of board
            • dskall
              • Oct 2016
              • 2905
              • usa
              #46
              R804,5,6 Are the feedback resistors for N801 which is the pfc controller NCP1653A. In series about 1.9m
                That is the typical failure when you have low Boosted PFC Voltage, common failure in SAMSUNG TV and causes the backlights to flash, but the sad part is that people on web said to cut the jumper wire to fix the problem when in actually it disable the LOW Boost Voltage shutdown circuit. The cause is the resistors in the PFC OUTPUT Voltage control feedback.
                  You have to subtract the probe leads resistance from the reading to get the resistance value when measuring in low Ohm.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    ThatsThat's something I always forget. Dumb move on.my part. Ok well these three resistors two of them for the feedback is a 620k and one is a 680k. One of the 620K ohms were reading 590 k. Anything but a 680 k. Power at the filters are now 406v. No shut down yet. Hopefully we may be onto something. Dskall I believe the low PFC is truly the cause now. I'm leaving the TV on all night will know more in the morning
                    • Burningstariv
                      • Mar 2017
                      • 7
                      Waiting to hear back from your update freak, I'm already a noob when it comes to electronics and I'd hate to fix one part and have to do more. I dont even know if i know how to change a resistor.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Okay the update. It's still working. No shutdowns at all last night or this morning. I also powered it down after being on for hours and then power it back up.
                        I'm fairly confident now that this power supply has a problem with PFC feedback. When the voltage goes lower than acceptable the thermistor gets extremely hot. When this starts to happen the voltage goes low on the primary caps and the power supply struggles to keep the TV working. 391 - 407v seems optimal when this power supply is functioning in its on state. Any less than that I would look at the feedback resistors that dskall had pointed out
                        R804 R805 R806. in SERIES these should equal 1.95mohms
                        • Burningstariv
                          • Mar 2017
                          • 7
                          So I bought the pwm controller is this the same as the pfc you are talking about freak or is that another part. Also what resistors would you recommended if those 3 are bad also.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Well it depends on how you feel about your soldering skills if you want to pull and replace that pwm controller. It is kind of a chore considering their 16 pins. But I'm somewhat confident that maybe this controller is not bad to begin with. The resistors I am talking about if you look at the back side of the board. You're going to need to order two 620k And1 680k smd resistors. I believe the rated at 1 watt.
                            What I would do is place a voltmeter set to DC and check the leads of the main filter cap there are two of them you can check either one with the TV power on. Tell us what the voltage is reading off of that main filter cap period black lead to negative side red lead to positive side
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              #54
                              I just used regular 1/8 watt resistors. The current on feedback circuit should be quite low. I had thought maybe bad thermistor because it was getting hot. Haven't checked it after the repair.
                              • Burningstariv
                                • Mar 2017
                                • 7
                                I'm confident in my soldering skills. I plan on getting 1 of these
                                http://www.ebay.com/itm/25pcs-1-8-WA...-/182442959957
                                and 2 of these
                                http://www.digikey.com/product-detai...RCT-ND/2022737
                                I'll go ahead and check the main filter cap before I purchase any further parts including the ones above.
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  #56
                                  Do you want to cancel order for controller as I don't think it is the problem.
                                  Your digikey is for 620ohm should be 620kohm
                                    BTW, to trim the output Voltage you can vary the resistance of the resistor that is connected in series to those 3 high Ohm resistors to GND, it will be much lower resistance usually around 20~50K Ohms range depend on the required feedback Voltage on that resistor to get 390VDC output, the DCV on that resistor is also very low since it is part of the Voltage divider circuit.
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      Well this is a confirmed fix. Budm and dskall are correct. I have replaces both "6203" resistors because of drifting values. This in turn brought the high voltage from 355 volt to 407 volt. No more shutdowns.
                                      • cyberthief
                                        • Apr 2017
                                        • 8
                                        I am completely new to all of this but I am not afraid to fry a TV that is already not working. I appreciate all the effort you guys have done and figuring out the same issue I am currently having with my TV. Could I bother one of you guys to identify in a picture which were the parts that were replaced for the fix. I would greatly appreciate it, thank you.
                                        • dskall
                                          • Oct 2016
                                          • 2905
                                          • usa
                                          #60
                                          What voltage do you get across your large capacitor on power supply?
                                          • cajoeg
                                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                            by cajoeg
                                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                            02-10-2025, 04:01 PM
                                          • nieljosiah
                                            HP Notebook - 15-ba017ax (LA-D711P Motherboard) turns off randomly after some time
                                            by nieljosiah
                                            I've had this laptop for 8-9 years, and about a week back, it started malfunctioning. When I press the power button, the power LED comes on for about 5secs and turns off. The fan also doesn't spin at all during this time. But, if I press the power button, and then manually spin the fan, the laptop boots up and the fan starts spinning on its own. Even if I do this, and the laptop boots up, it turns off (hard shutdown) after some time between 10secs and 1hour randomly. I've tried checking the fan voltage and it's at zero volts when I press the power button without spinning it, but when I spin the...
                                            08-17-2024, 02:19 AM
                                          • thedigi321
                                            I have an LG 50PN4500-UA turns off and on randomly with 2 flashes before turning on
                                            by thedigi321
                                            showing power does nothing randomly turns on with 2 flashes: https://youtu.be/ZHME8GthErc
                                            Hello all I have an issue with my tv. I have had it for about 5-6 months because when I moved apartments the previous owner left the tv. and I got it for free it is a plasma tv and looks nice enough. an issue that started to happen was that it would kick off randomly but I could still turn it on well about a month or so I assumed the power button went out so I got a universal remote and programmed all lg codes and nothing just the solid red standby light so fast forward to a week ago...
                                            12-18-2019, 10:00 PM
                                          • Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                            by Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                            03-15-2024, 09:37 AM
                                          • www
                                            LG L192WS-BN backlight turns off after 1 second
                                            by www
                                            I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                            I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                            03-24-2024, 05:26 PM
